[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibt‘s eigentlich schon passende ATX3-Netzteile in SFX-Bauform für die neuen Grafikkarten? Hab keine Lust, in ein stärkeres ATX2-NT zu investieren. Wenn schon, dann dann den neusten Standard.
NDA Bruch? :P
Laut Igors comment, wäre das Video 1 Tag zu früh von MSI.
Von Zotac gabs schon vor 1 oder 2 Wochen ein unboxing video von der amp extreme airo
Prima, danke. Das werd ich mir mal in der 850W-Variante ordern.
EDIT: Sind zwischenzeitlich auch schon weisse 4080/4090 gesichtet worden?
Leider konnte mir da bisher niemand eine antwort drauf geben ob bei dem 4 x 8 Pin Adapter zwingend auch alle 4 x 8 Pin Kabel belegt sein müssen
weil ich brauch ja nur 3 x 8 Pin für die 450 Watt und nich 4 x 8 Pin.
KFA2 ist da recht eindeutig. Ganz unten bei requirement: https://www.kfa2.com/kfa2/graphics-card/40-series/4090-series/geforce-rtx-4090-sg.html
  1. PSU with native 450W PCIe Gen5 16-pin power connector, or minimum 3x PCIe 8-pin power connectors (use with included adapter)
    *450W PCIe Gen5 16-pin power connector or 3x PCIe 8-pin power connector when running in stock (450W TGP). For overclocked settings beyond 450W TGP, 600W PCIe Gen5 16-pin power connector or 4x PCIe 8-pin power connector will be required.
Der Adapter hat 4x8pin, du kannst aber auch 3x8 benutzen. Dann ist halt bei 450W Schluss.
@CloudStrife81
Wo ist eigtl. die 1200W Variante die Asus mit angekündigt hatte?
Mal gespannt, was in 7 1/2 Stunden passiert :)
Yep, glücklicherweise bin ich nicht so Lärmempfindlich, zocke eh immer mit Kopfhörern, und ich muss mich jetzt auch nicht (gleich) in ne Benchmark Table eintragen, von daher bin ich da mittlerweile enspannter, die kann auch ne ganze Weile auf Luft laufen.
Das letzte Mal habe ich wie gesagt noch erst ne Weile abgewartet für welche Karte mein Lieblingsblock wohl kommt und dann hatte ich keinen Bock mehr zu warten und habe mir die EVGA geholt weil ich Cyberpunk zocken wollte damals :d Und letztendlich ist sie auf Luft geblieben weil es zu lange gedauert hat.
Dieses Mal hole ich mir ziemlich eine Karte die mir zusagt (FE oder Suprim X stehen vorne auf der Liste derzeit) und schaue dann, ob und wann es einen guten Block dafür gibt. Ich habe Ende des Monats 2 Wochen Urlaub und da möchte ich schön zocken und nicht immer noch auf die perfekte Combo warten.
Das kommt mir doch sehr bekannt vor. Damals wollte ich auch die Asus Strix 3090 (auch vor allem wegen den 2x HDMI) aber wegen dem AGB hatte ich nur 31,5cm Platz, die Strix aber über 32cm. Und den AGB zu verlegen war kaum möglich und mir auch zu stressig damals, weil ich dazu das halbe System hätte auseinanderbauen müssen. Also wurde es die EVGA 3090 FTW.
Diesmal war gleich klar, das außer der Founder keine Custom passen würde, also musste sich der AGB bewegen. Und da ich eh einen 7950X holen wollte und dafür alles auseinanderbauen musste, habe ich gleich den AGB versetzt. Jetzt stehen mir immerhin 34 cm zur Verfügung, mehr war beim besten Willen nicht drin und wo anders kann der AGB nicht hin ohne ein ganz großen Fass aufzumachen.
Also Liste checken...
Und wieder ist die Strix raus. Und die TUF :motz:Das schränkt meine Wahl doch ein. Die Suprim X müsste passen aber die da reinzuzirkeln könnte spaßig werden. Daher steht die FE bei mir ganz vorne auf der Liste aktuell.
Was den Adapter angeht...ich würde es nicht mit 3x8-pin versuchen, das Ding ist ein Monster und die Adapter sind eh schon kritischen Blicken ausgesetzt und mit Fragezeichen behaftet. Ich halte es für ein großes Risko. Technisch könntest Du Glück haben und die Karte merkt es nicht, aber dann würde ich mich höchstens mit Undervolting beschäftigen und zusätzlich das PT begrenzen.
Darf ich deine Liste bitte in den Starpost übernehmen? :)
Das Corsairkabel ist in den USA verfügbar
Hoffentlich dann heute auch bei uns.
Doppelt so schnell wie eine 3080. Das wäre natürlich heftig....
Ich sollte mit meinem Dark Power Pro 12 1500W glaub ich so gerade auskommen :) BeQuiet soll so langsam mal das dumme Kabel rausbringen :)
Anhang anzeigen 798699 Anhang anzeigen 798700
anschlüsse hab ich genügend :)
PS. "Adapter" sollte ich dann 4 Lanes nehmen mit jeweils 1 Pin zum Adapter oder langen 2 Lanes ergo 4 Pins zum Adapter ?
ich habe das Thema schon eine Weile mit Hr. Marquard bzw. Hr. Badorrek vom be quiet Support im Fokus.
für die DP Pro 11 bzw. 12 Serie gibt es dieses 12Pin Kabel
das Single 12Pin Kabel hatte ich bei der 3090FE kostenlos bekommen, ich hab mir das neue gekauft und bereits eingebaut.
Das ist aber nicht das neue 12VHPWR oder ?
-> es gibt kein 12VHPWR für die alten Netzteil Serien.
im Falle von "be quiet!" gibt es dieses Kabel für deren Netzteile was die Leistung wie das 12VHPWR (kompatibles Netzteil mit genügend Leistung vorrausgesetzt) problemlos liefert
(aber eben ohne direkte Kommunikation mit dem Netzteil)
und ja das funktioniert.
es gibt von be quiet! nur dieses Kabel was die Leistung wie das 12VHPWR aber problemlos liefert (aber eben ohne direkte Kommunikation mit dem Netzteil)
Da soll doch neues Kabel kommen
Nein, sag mal soll ich Dir die kommunikation mit dem Technischen Support weiterleiten oder glaubst Du mir nicht.
das ist das neue Kabel, das "alte" war nur an einen Netzteil PCIe Anschluss angebunden, das neue an zwei.
die bisherigen Netzteile von be quiet! der 11/12 Serie unterstützen schlicht und ergeiffend keine Sense Pins.
Aber es kommt ein"neues"Kabel. Da ich noch kein 12 pin Kabel habe warte ich auf das neue 2x12pin auf 12VHPWR
Es kommt kein neues Kabel, da die Netzteile keine Sens Leitungen unterstützen.
siehe Aussage von be quiet! anbei:
Und woher weiß die GPU wieviel Watt sie ziehen darf? Ich hab den neuen Stecker so verstanden: Neue 3.0PSU=Kommunikation zwischen GPU und PSU wieviel Watt geliefert werden kann. "Alte"-PSU=Die Sense Kabel werden so "verknotet", das die GPU "weiß" das Sie dauerhaft 600 ziehen darf. Daher wäre ich bei einem "nur" 12-Pin Kabel weiterhin skeptisch.
Den Karten liegen doch auch Adapter bei, die haben auch keine Sense Leitungen. Das muß ja auch funktionieren.
Aus dem Be Quiet Thread:
Aktuell bieten wir das 12 Pin Kabel an welches für die 30xx Founders Edition angedacht war.
Dieses kann im Ersatzteilshop bezogen werden, in Einzel- oder Dual-Ausführung.
In naher Zukunft werden wir hier noch ein 12VHPWR Kabel releasen.
Da die Karten aber aktuell noch nicht zu bekommen sind, müssen wir uns alle noch etwas gedulden.
VG
Marco
Guter Punkt. Die Stecker der Adapter habe ich mir noch nicht weiter angeschaut. Müsste man mal sehen ob die 12+4 haben.
Dann glaubst wohl meiner Support Anfrage.
PS. Aus deiner Anfrage geht hervor das du ein DP11 hast. Vielleicht kommt da ja nix für
Hier auch die Infoseite von BeQuiet dazu:
Und der passende Thread im Forum:
Ähnliche Themen
