[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nein, bei den PCBs fehlt doch ein Stück, sind das die Founders?
Die 3090er Kühler waren viel Länger, teils auch das PCB.
Ne die sind einfach in die Höhe statt in die Länge gewachsen. Sonst geht das mit dem Through-Blow Design nicht wenn der PCB zu lang ist.
Bin fairerweise kein großer Fan von diesen "fetten" PCBs. Alles was großartig über den Rand der PCIe Slotblende drübergeht ist einfach zu groß :haha:
Aber so lasse ich leider die Finger davon. Sicherheitshalber 😃
Wobei dort eher der Händler Mist gebaut hat, es ist ja auch nicht so, dass im Netz viele Meldungen zu finden wären, wo User Probleme mit der Garantie im Fall der Fälle hätten mit einer Karte von Inno3D.
Inno3D ist mit einer der ältesten Hersteller von Nvidia Grafikkarten am Markt. ;)
  • Danke
Reaktionen: SH
Sehe ich ähnlich. Nachdem EVGA ja weg ist, wird das Risiko beim Umbau von Luft- auf Wasserkühlung bei jedem Hersteller deutlich höher sein als mit einer fertigen Karte wie der Frostbite.
Gestern im MSI Stream habe ich mir die neue Suprim angeschaut. Wahnsinn was die dort mit Heatpipes und Vapor Chamber aus dem Hut gezaubert haben. Ich möchte aber nicht einen zweiten Suprim Luftkühler Kühler hier sinnlos im Schrank verstauben lassen. Auch wenn es preislich wahrscheinlich keine keine Rolle spielt, diese Verschwendung mag ich nicht mehr unterstützen.
Das ist korrekt. Aber dann doch lieber MSI oder Asus. Karte einfach direkt an die Firma schicken ohne den Händler 👍
Also sehen die PCBs doch nahezu identisch aus.
Richtig. Daher wundert es mich, warum Wakü Hersteller so lange brauchen und noch nichts auf Lager haben.
Ich bin auf das PCB der Strix noch gespannt 😃
Ich rede von den Lukü Karten, Wakü interessiert mich nicht.
Wasserkühlung hat noch nie mehr Sinn gemacht als mit der Ada/Lovelace Generation.
Immerhin wird mal mit der Inno3D Frostbite direkt eine passende Karte kaufen können. Zusätzlich würde ich aber auch gerne sowas wie eine MSI Sea Hawk sehen. Ich meine das war damals eine Kooperation mit EK. Auch Asus hatte mal was kompaktes im Angebot. Rein vom PCB müssen die Karten nicht so übertrieben groß sein.
WAS EIN KLOTZ! :)
VidoeCardz.comLengthWidthHeightVolume
Gigabyte RTX 4090 GPU Size
RTX 4090 AORUS MASTER358.5 mm162.8 mm75.1 mm4,383 mm³
RTX 4090 GAMING340.0 mm150.2 mm75.2 mm3,825 mm³
RTX 4090 WINDFORCE331.0 mm150.0 mm70.0 mm3,476 mm³
RTX 2070 Mini-ITX170.0 mm121.5 mm42.1 mm871 mm³
RX 6400 Low-Profile182.0 mm69.0 mm36.0 mm452 mm³
wird dann bei einigen eng mit der seitenwand und mit der tiefe.
das macht es noch heftiger :fresse:
wtf
Eine etwas eigenwillige Interpretation eines "full-cover waterblock" auf der Colorful Neptune Series. :oops:
Hätte nicht gedacht , dass es wirklich mal Sinn macht einen Big Tower zu haben wegen dem überbreiten PCB .
Das Problem mit den AIOs an den Karten ist, dass man nicht weiß, wie zuverlässig die nach 1-2 Jahren noch funktionieren (auch werden da zumeist nicht die hochwertigsten Pumpen verbaut, jedoch kann man die Lüfter nach Belieben tauschen). Hätte lieber eine mit Luftkühlung aber da sind die Temperaturen dann schlechter, gerade bei 450+ Watt. Ich denke wir müssen erstmal die Tests abwarten, um zu schauen, welche 4090 nun die Richtige ist.
wenn man einfach ein bracket braut wo man 2x 120er lüfter reinschnallen kann (idealerweise mit einem schnellen Mechanismus) dann könnte man sich als hersteller in zukunft diverse reparaturen sparen. dann schickt man dem käufer 2 neue lüfter die er selbst schnell wechsel und gut ist. dazu ist die kühler besser.
nein, mann baut solche ziegelsteine wie gigabyte...
Mal angenommen, dass NBB die Founders Editions hier wieder vertreiben wird: Konnte man auf der Seite bei den letzten Phasen großen Andrangs noch einigermaßen normal bestellen oder war auch stets alles ausverkauft bevor überhaupt der Bestellbutton online gegangen ist?
Das hängt allein von der Verfügbarkeit und der Nachfrage ab, das weiß man jetzt noch nicht.
Andere Gerüchte sprechen auch davon, dass der Vertrieb der Karten bald über Apple erfolgen wird. :d
Gibt es eine Quelle wegen Apple? Oder nur ein Scherz? :)
Das hatte doch Steve in seinem Video erzählt, ob es ein Scherz war weiß ich nicht
Ich meine jetzt eher im Bezug auf irgendwelche Tricks, die Leute angewandt haben. War nie in der Materie drin, aber habe nebenbei mitbekommen, dass bei Ampere Leute da mit irgendwelchen versteckten Links o.ä. rumgetrickst haben. Wollte nur wissen ob NBB das letztendlich mal unterbinden konnte.
Edit:
Hier vielleicht ein kleiner Hinweis auf die Stabilität der 8-pin auf 16-pin PCIe-Adapter. Zotac gibt nur für bis zu 30 Ab- und Ansteckvorgänge Garantie. :LOL:
https://www.zotac.com/product/graphics_card/zotac-gaming-geforce-rtx-4090-amp-extreme-airo
4x 8-pin-to-12VHPWR cable (Limited service life with up to 30 connect / disconnects)
  • Haha
Reaktionen: SH
Ähhh Nein ? MSI nur über Händler, Asus im Ausnahmefall direkte RMA.
Bei mir gings auch nur über den Händler, und das bei einer Karte (RTX 3090 TUF) die DOA war und nicht weniger gekostet hat als die 4090 TUF kosten wird.
Obwohl ich zur Nacherfüllung aufgefordert und daher komplett eingesendet habe kam dann ein Austausch von Asus komplett OHNE OVP und Zubehör.
Achja, gedauert hat der Spaß dann ca. 6 Wochen.
Das ist mal ein heftiger Sprung von 8nm auf nur 4nm :oops:(y)
Hab seit Freitag ein Gerät mit 4nm :fresse:
Cyperbunk 4K 100 FPS Max Settings mit RT. Ich will diese KARTE :)
Wieviel geht mit der 3090 (nur Non-TI)?
Ca. 36-43 FPS
Edit @Dwayne_Johnson
Kleiner Vorgeschmack :)
2-3x so schnell als eine 3090 TI in Cyberpunk.
Ähnliche Themen
Antworten
6K
Aufrufe
395K
