dante`afk
Legende
- Ort
- New York
- 9950x3d
- ASUS ROG Crosshair X870E Hero
- 2x mora420, 4x d5, aquacomputer/watercool arsenal
- G.SKILL Trident Z5 Royal Neo Series 64GB 6600 CL28
- rtx5090 FE
- samsung neo g9 49" 240hz, 2x 27" 120hz
- NVMes only
- phanteks 719
- bequiet 1500w dark power 12
- Keyboard
- CM masterkeys pro RGB - red mx cherries
- Mouse
- roccat pure
- w11 x64
- Webbrowser
- chrome
- Internet
- ▼2 Gbit ▲2 Gbit
Apex XI auch.
das dark wohl auch, suppi
M.2 / U.2 Slot Breakdown (Are all from the PCH and Not the CPU) So this tells me the GPU still runs at X16 off the CPU.
M.2 Lane Distribution
M.2 Key-M (110mm, Top, PM1) – x4 from Z390 PCH
M.2 Enable/Disable is set within the BIOS
This M.2 Key-M slot shares lanes with the U.2 port. Installing an M.2 device will disable U.2 port PU1.
M.2 Key-M (110mm, Bottom, PM2) – x4 from Z390 PCH
This M.2 Key-M slot shares lanes with PE3. Installing an M.2 device will disable PCIe slot PE3.
M.2 Key-E (32mm) – x1 from Z390 PCH
