TM30
Legende
Laut den Features ein recht interessantes Board, nur laut Boardsuche gibts hier nicht mal nen Sammelthread?!
Kann mir kaum vorstellen, dass es keinen interessiert?
Ist doch sicherlich nen gutes Board für nen "High-End" HTPC? Die onboard 128MB GDR3 RAM für die IGP sollten ja nen ordentlichen Performanceschub geben...
http://us.dfi.com.tw/Product/xx_pro...p?PRODUCT_ID=6199&CATEGORY_TYPE=LP JR&SITE=US
http://preisvergleich.hardwareluxx.de/deutschland/a364099.html
Specification
CPU
# AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron AMD® AM2 processors: Athlon series / Sempron
# HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for AM2)
# AMD OverDrive provides tuning options using the new “Advanced Clock Calibration” overclocking feature.
# Socket 940 AM2+ 65nm
Chipset
# AMD chipset - Northbridge: AMD 790GX - Southbridge: AMD SB750
System Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667/800/1066 MHz DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 2 PCI Express (Gen 2) x16 slots - Hybrid CrossFireX - combination of the integrated graphics and a discrete graphics card in a PCIE slot (8-lane port). - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports) bandwidth
# 1 PCI Express x1 slot
# 1 PCI slot
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit SPI flash memory
Graphics
# Integrated ATI Radeon HD 3300 graphics core
# Onboard graphics interface - HDMI port for both digital audio and video HD display - DVI-I port for digital LCD display
# Microsoft® DirectX 10
# Hybrid CrossFireX technology combines the onboard GPU and a discrete PCIE graphics card
# Onboard Performance cache for added performance
Audio
# Realtek ALC885 8-channel HD Audio Codec
# High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN
# Marvell 88E8056 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Serial ATA with RAID
# Supports up to 6 SATA devices
# SATA speed up to 3Gb/s
# RAID 0, RAID 1 and RAID 0+1
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Rear Panel I/O
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 HDMI-out port
# 1 coaxial RCA S/PDIF-out port
# 1 optical S/PDIF-out port
# 1 DVI-I port
# 4 USB 2.0/1.1 ports
# 1 RJ45 LAN port
# Center/subwoofer, rear R/L and side R/L jacks
# Line-in, line-out (front R/L) and mic-in jacks
Internal I/O
# 4 connectors for 8 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 front audio connector
# 1 CD-in connector
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 1 4-pin 5V/12V power connector (FDD type)
# 1 front panel connector
# 6 fan connectors
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# microATX form factor
# 24.5cm (9.64") x 24.5cm (9.64") All specifications above are subject to change without prior notice.
Specification
CPU
Chipset
System Memory
Expansion Slots
# 1 PCI slot
BIOS
# Award BIOS
# CMOS Reloaded
Graphics
Audio
LAN
IDE
Rear Panel I/O
# 1 HDMI-out port
# 1 DVI-I port
# 1 RJ45 LAN port
Internal I/O
# 1 CD-in connector
# 1 IrDA connector
# 1 CIR connector
# 6 fan connectors
Power Management
# Wake-On-Ring
# Wake-On-LAN
Hardware Monitor
PCB
