Techtrancer
Urgestein
AMD's Shanghai proffers 12 cores, HyperTransport 3.0
If your interest in processor speeds doesn't extend much beyond "is it fast?" then these juicy tidbits likely aren't for you. That said, AMD is certainly getting excited about its upcoming Barcelona successor: the 45nm Shanghai. The main points of interest out of the gate are HyperTransport 3.0, which was nixed late in the game on Barcelona, and six cores, which are meant to pit the chip up against Intel's upcoming six-core Dunnington chip. Where things get really exciting is a few months after Shanghai's late 2008 debut, when AMD plans do release a twin-die version, with 12 cores of happiness connected by HyperTransport 3.0. What does all that mean? Beats us, but we hope it's fast.
LINK ==> http://www.engadget.com/2008/04/18/amds-shanghai-proffers-12-cores-hypertransport-3-0/
Dodeca-core: The Megahertz Race is Now Officially the Multi-core Race
AMD engineers reveal details about the company's upcoming 45nm processor roadmap, including plans for 12-core processors
"Shanghai! Shanghai!" the reporters cry during the AMD's financial analyst day today. Despite the fact that the company will lay off nearly 5% of its work force this week, followed by another 5% next month, most employees interviewed by DailyTech continue to convey an optimistic outlook.
The next major milestone for the CPU engineers comes late this year, with the debut of 45nm Shanghai. Shanghai, for all intents and purposes, is nearly identical to the B3 stepping of Socket 1207 Opteron (Barcelona) shipping today. However, where as Barcelona had its HyperTransport 3.0 clock generator fused off, Shanghai will once again attempt to get HT3.0 right.
Original roadmaps anticipated that HT3.0 would be used for socket-to-socket communication, but also for communication to the Southbridge controllers. Motherboard manufacturers have confirmed that this is no longer the case, and that HT3.0 will only be used for inter-CPU communication.
"Don't be disappointed, AMD is making up for it," hints one engineer. Further conversations revealed that inter-CPU communication is going to be a big deal with the 45nm refresh. The first breadcrumb comes with a new "native six-core" Shanghai derivative, currently codenamed Istanbul. This processor is clearly targeted at Intel's recently announced six-core, 45nm Dunnington processor.
But sextuple-core processors have been done, or at least we'll see the first ones this year. The real neat stuff comes a few months after, where AMD will finally ditch the "native-core" rhetoric. Two separate reports sent to DailyTech from AMD partners indicate that Shanghai and its derivatives will also get twin-die per package treatment.
AMD planned twin-die configurations as far back as the K8 architecture, though abandoned those efforts. The company never explained why those processors were nixed, but just weeks later "native quad-core" became a major marketing campaign for AMD in anticipation of Barcelona.
A twin-die Istanbul processor could enable 12 cores in a single package. Each of these cores will communicate to each other via the now-enabled HT3.0 interconnect on the processor.
The rabbit hole gets deeper. Since each of these processors will contain a dual-channel memory controller, a single-core can emulate quad-channel memory functions by accessing the other dual-channel memory controller on the same socket. This move is likely a preemptive strike against Intel's Nehalem tri-channel memory controller.
Motherboard manufacturers claim Shanghai and its many-core derivatives will be backwards compatible with existing Socket 1207 motherboards. However, processor-to-processor communication will downgrade to lower HyperTransport frequencies on these older motherboards. The newest 1207+ motherboards will officially support the HyperTransport 3.0 frequencies.
Shanghai is currently taped out and running Windows at AMD.
LINK ==> http://www.dailytech.com/Dodecacore...fficially the Multicore Race/article11531.htm
AMD kündigt Prozessoren mit bis zu zwölf Kernen an
von Christian Kahle für WinFuture.de
Der Chip-Hersteller AMD hat gestern seine Roadmap für Prozessoren vorgestellt, die unter dem Code-Namen Shanghai entwickelt werden. Diese werden in 45-Nanometer-Bauweise gefertigt und sind mit bis zu zwölf Kernen ausgestattet, so das Unternehmen in Sunnyvale.
Die ersten CPUs der neuen Baureihe sollen noch in diesem Jahr auf den Markt kommen. Der Socket für die Chips ist nahezu identisch mit dem des aktuellen Barcelona-Prozessors. Auch HyperTransport 3.0 ist enthalten.
Als eines der ersten Produkte der Serie will AMD den Istanbul-Prozessor in den Handel bringen. Mit seinen sechs Kernen ist er als direkter Konkurrent zu Intels Dunnington-Chip konzipiert, der ebenfalls in 45-Nanometer-Bauweise gefertigt wird.
Einige Monate später sollen CPUs mit zwölf Kernen verfügbar sein. Die Cores sind dabei auf zwei zusammengeschlossenen Dies angeordnet. Ein Design mit zwei Dies hatte AMD bereits für die K8-Linie entwickelt, später aber ohne Begründung verworfen. Stattdessen konzentrierte man sich auf die Entwicklung der nativen Quad Core-Architektur Barcelona.
Die beiden Dies im Shanghai-Prozessor werden über HyperTransport 3.0 miteinander kommunizieren. Außerdem ist ein Dual-Channel-Memory-Controller integriert. Abwärtskompatibilität zum Socket 1207 ist nach Angaben des Herstellers gegeben. Die volle Leistungsfähigkeit kann der Chip aber erst auf neuen Socket 1207+-Boards bereitstellen.
LINK ==> http://www.winfuture.de/news,38847.html
AMD-Prozessoren mit 12 Kernen geplant
Wie bereits am Donnerstag bekannt wurde, plant der Chiphersteller AMD noch in diesem Jahr die Markteinführung eines 12-Kern-Prozessors.
Vorläufig trägt er den Codenamen Shanghai.
Basierend auf der 45nm-Bauweise, soll dieser Chip einen nahezu identischen Socket wie der aktuelle „Barceolna”-Prozessor besitzen. Ebenso soll der „Shanghai”-Chip HyperTransport 3.0 zur Kommunikation zwischen den Kernen verwenden.
Als erstes derartiges Produkt plant AMD, den „Istanbul”-Prozessor auf den Markt zu bringen. Er soll zwar zunächst nur 6 Kerne besitzen, gilt aber dennoch als Vorläufer des „Shanghai”-Chips.
Bereits mit der K8-Linie war man schon in diese Richtung aktiv. Jedoch ht man eine Weiterentwicklung dieser Technologie unbegründet verworfen.
Über den „Shanghai”-Prozessor ist bekannt, dass dieser einen Dual-Core-Memory besitzen soll. Ebenso soll er eine Abwärtskompatibilität zum 1207-Sockel besitzen („Barcelona”). Seine volle Leistungsfähigkeit wird er jedoch wohl erst auf den neuen 1207+-Boards entfalten können.
LINK ==> http://nexem.info/
Eight cores on 45 nanometres
After the Barcelona K10 design scheduled for 2007 AMD plans to reveal a new chip codenamed Shanghai in 2008. The new chip will have improved K10 marchitecture, more L3 cache memory and faster clock speeds. It is scheduled for the first part of 2008.
One of the key things is that it will be made in 45 nanometre marchitecture and this will enable AMD to go eight core on the same socket. The first reports claim that the eight core won't be a native design, but rather two 45 nanometre chips on the same socket.
So there might be some hope for AMD shareholders after all.
LINK ==> http://www.fudzilla.com/index.php?option=com_content&task=view&id=480&Itemid=1
