[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kabel kontrollieren ist aber auch nicht das Klügste was man machen kann...Was soll das bringen außer unnötig Steckzyklen zu addieren? Wenn es angekokelt ist, merkt man das schon und ist dann eh zu spät. Ich würde empfehlen das so wenig wie möglich ein und auszustecken und mit einer neuen GPU auch das Kabel mit auszutauschen.
Ist doch nur ein optisches Problem. Schwarzes Isolierband rum und fertig! Was alle gleich immer haben... :fresse2:
Hier ist der Stecker nicht richtig drinne.
Das ist dann schon User Error. Die Diskussion Stecker selber ist ja im anderen Thread ausreichend diskutiert worden mit dem Ergebnis brauch mehr Sicherheit und natürlich die Minderheit die sagt zb. kauft euch ein Wireview pro 2 :d
Nee, echt? :d
Dass man überhaupt so eigens-dämliche Bilder postet :sneaky:
Und k.A. was mit dem System passiert ist oder wo es steht. Die Lötstellen (insbesondere die freie Ader) sehen nicht gut aus (korrodiert)
Entweder ist mal was drüber gelaufen oder das Haus steht am Meer (toxische bzw. salzige Meeresluft) :haha:
Also die Doofen :fresse:
hast recht eigtl. ich zieh den nie ganz 'raus sondern wackel nur mal kurz dran, alle halben jahre mal. und beobachten des spannugsabfalls in hwinfo ist auch ganz hilfreich. ist aber unverändert, gutes zeichen eigtl. trotzdem schwirrt das oft im hinterkopf herum... nerviges thema einfach 😤
Weil er nach dem Schmelzen versucht hat den Stecker abzuziehen.
Etwas merkwürdig ist auch das Tierhaar, bei einem Kunden hat mal der Studio-Kater seine Marke auf den Chipsatz gesetzt, das sah dann nach ein paar Wochen ähnlich aus, vor allem hat das Board dann beim Riechtest nach dem Ausbauen penetrant nach Katzenpipi gerochen.
Klingt auch logisch. Ohne den Stecker abzuziehen wird man eventuell verschmorte Kontakte wohl kaum sehen.
Wird wohl kaum ein "vor dem Abziehen" Doku-Foto sein.
Ich hab vor 3 Wochen eine gebrauchte 4090 FE vom Erstbesitzer gekauft, er ist die Karte mit 450W Power Target gefahren und war auf BeQuiet NT angesteckt. Sollte also jetzt bei meinem BeQuiet NT das identes Kabel sein wie vorher.
Vor 2 Jahren den Stecker reingesteckt und nicht mehr dran gerüttelt ... bisher keine Probleme mit dem Stecker ^_^
Ich glaube die Stecker Problem Leute sind einfach die Montagsprodukte von Gott wie mein Opa immer gerne gesagt hat 😏
Kann dir diesen Chinesen empfehlen.
Lol die Storys von euch sind so gaga.
Wobei mich das wundert, mit etwas Geduld bekommt man 5090er ja auch schon etwas über 2000€, wenn man sich auf Geizhals bissl auf die Lauer legt und Händlerangebote rechtzeitig mitbekommt.
In € / Rechenleistung bzw. € / VRAM ist das dann eigentlich besser...
Wurde doch inzwischen mehrfach erläutert, die 4090 lässt sich wohl recht easy mit VRAM für KI aufrüsten und die 5090 eben nicht.
Deswegen die hohen Gebrauchten Preise.
Aktuell hört man auch in Österreich von diesem Vorgehen, hier kommst der Schinese aber auf Italien angreist um die Karten einzusammeln. Kurios.
Die Chinesen sind echt angenehme 4090 Käufer :hail: Fahren zur Not durch die halbe Republik und verhandeln nicht :d
ist halt immer nur so die frage, was man damit unterstützt... allerdings glaub ich, dass ich bei so einem angebot auch nicht lange überlegen würde, meine doppelmoralscheinheiligkeit ist also auch für die katz :d
Ich kaufe sogar Nestlé Produkte und werde in der Hölle definitiv mit warmen Armen begrüßt. 🫶
Wenns danach geht, musst aufhören zu atmen, in dieser Welt.
Selbst beim Kacken untersützt du Leute, die du eigentlich nicht unterstützen willst. Ist so. :fresse:
darf man eigtl echt nicht drüber nachdenken...
Genau, einfach ganz locker bleiben dabei und alles flutscht.
Die Sache mit dem Gewissen ist sowieso überbewertet und dank Klimawandel sind wir schon bestens vorkonditioniert für die Hölle.
Hat jemand eigentlich in letzter Zeit nochmal 2k+ für seine 4090 bekommen? Oder sagt da auch der Chinese nein?
Kann jemand ausfindig machen, ob "der Chinese" einen Verwandten in Portugal hat? :)
Hier werden mir lediglich €1550 angeboten. Wobei das wahrscheinlich ein Lockangebot ist und der Preis auf 1400 gedrückt wird, wenn ich dort bin.
Was sind denn eigentlich momentan die Marktpreise für eine "billige" RTX4090 von Inno3d an einen Gamer-Kollegen?
Glaube die 2000€ sind jetzt auch hier vorbei
1700/1800 wären auch gut ;)
Obwohl auch 1.7k immer noch verdammt Scheiße gut sind wenn man berüchtigt wie alt die Karte inzwischen ist…
Das definitiv! Und vor allem kann man die Karte u.U. sogar mit Gewinn weiterverkaufen, wenn man im Sommer 2023 und teils auch noch später für manches Modell nur noch um die 1.500 Euro gezahlt hatte.
Hmmm, 1,7k ist irgendwie sehr verlockend. Aber irgendwie habe ich nix was die 4090 nicht schafft, spiele eh zu wenig oder habe sonstige Gründe mir die 5090 dann schönzureden :ROFLMAO:
Dann wird’s Zeit zu wechseln auf eine 5060.
Ähnliche Themen
