[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Corsair 1000W gibt es als SFX sowie auch als SFX-L.
jap, 1x 80 Plus Platinum und 1x 80 Plus Gold zertifiziert
hat hier wer empfehlungen fuer small form factor PSUs fuer OC'd cpu + 4090 ?
In der Schweiz ist das Loki 1200W Titanium relativ billig. Habe auch letztens aus Langeweile mit dem Gedanken gespielt aber warte lieber bis interessante CPUs auf den Markt kommen.
Naja, aktuell würde ich auch schauen, dass man den überarbeiteten 12V-2x6 PIN bekommt, das ist bei Corsair z.B. leider noch nicht der Fall, soweit ich das überblicke.
Ich hatte aber bisher mit überhaupt keiner Variante Probleme, weder BeQuiet noch Corsair, ASUS oder eben auch den beigelegten Adaptern.
Was ich noch nirgendwo verbaut habe, ist ein 90° Winkel. Ich hab zwar einen CableMod auf dem Schreibtisch liegen, aber nach dem Eklat, ist der direkt in der OVP geblieben
Ich habe gerade gesehen, dass es von Seasonic inzwischen ein 90° Kabel gibt. Ich habe noch ein 12VHWPR 90° Kabel drin, das sollte ich vermutlich besser gegen den neuen Stecker austauschen weil die konstruktionsbedingt besser sind? Wäre dann glaube ich Kabel Nummer 4 seit es diesen blöden Stecker gibt 🫠 Soweit ich das auf der Herstellerseite sehe, sollte das Kabel ja für mein Prime TX 1000 kompatibel sein.
Also wenn das aktuelle Kabel läuft würde ich da nix mehr tauschen. Vielleicht wenn eine neue GPU rein kommt aber sonst...
Ich werde das neue Kabel bestellen und tauschen wenn ich die Kiste das nächste mal so anfasse, dass ich das aktuelle neu anstecken müsste.
Aus völliger Langeweile könnte man das wohl tun…
Wird echt Zeit für die 5090, die Leute werden wohl langsam gaga und kaufen sich nun 5 Kabel, damit das Geld (ohne Sinn und Verstand) bloß ausgegeben wird, nunja. 🤣
von BeQuiet gibt es auch 2 solcher Kabel, aber eben nur reversed
Bei mir stand das vor kurzem nur zur Debatte, da die originalen Adapter ganz schön an den Kabeln gezogen haben und da hab ich sie eben durch originale von BeQuiet getauscht. Da ich allerdings ASUS Karten habe, konnte ich das reversed nicht verwenden und musste weiterhin auf dem alten Standard bleiben
Und wenn ich dann die 5090 kaufe brauche ich das Kabel eh und es ist ausverkauft, weil das ganze Luxx eins bestellt hat 😅 Kenn den Scheiß doch.
Läuft seit nun fast 2 Jahren bei mir mit der ollen Krake ohne Probleme, das 90 Grad Kabel liegt seit langer Zeit daneben und wird nun erst mit der 5090 Verwendung finden:
Hatte mir schon überlegt statt der Temperatur folgendes Bild anzeigen zu lassen, hat was:
Ist es irgendwie möglich einen Hdmi Ausgang der Gpu als Soundausgang zu nutzen für eine Soundbar?
Machen das nicht alle mit einem AVR so?
Bild Dublizieren. Dann wird auch der Ton mitgeschickt.
Fragt sich halt nur, ob das auch funktioniert wenn Du 480hz anzuliegen hast (ich hab keine eigenen Erfahrungen in der Sache).
Ja, geht problemlos.
Ich meinte ohne irgendetwas dazwischen.
Hatte es probiert aber windows erkennt da nix wenn ich die Soundbar anschließe an den Hdmi.
Wäre da ein Wireview nicht inzwischen preiswerter gewesen?
Im Nachhinein ist man immer schlauer. Ich hab dummerweise bei Cablemod gekauft, die Austausch Frechheit wo man jedesmal bei den diversen Rückrufen noch die utopischen Versandkosten selber zahlen durfte ist hier ja bekannt. An nem Wireview hab ich aber eigentlich auch kein Interesse, ich will einfach nur ein Kabel mit 90° Anschluss das funktioniert und nicht abbrennt :fresse:
Thermal Grizzly warnt davor, dass der WireView Pro GPU im Betrieb sehr warm werden kann. Bei einer luftgekühlten Grafikkarten kühlt der Luftstrom der Lüfter auch den WireView Pro GPU. Dennoch kann dieser bis zu 60 °C warm werden. Bei einer wassergekühlten Karte spricht der Hersteller sogar von bis zu 100 °C. Auf welche Grenzwerte der WireView Pro GPU hinsichtlich der Warnung vor zu hoher Temperatur und Stromstärke eingestellt ist, ist nicht bekannt.
:unsure: :oops::rolleyes2:
Das "neue Treiber-Archiv" ist eine einzige Katastrophe... :rolleyes2:
Bis man mal dort ist, wo mal hin will, muss man x-mal klicken. Die angelegten Favoriten, der alten Ansicht funktionieren leider nicht mehr
Wieder so ein "neuer = schlechter"... :cautious:
Treiber Archiv? Wozu wird das genau benötigt?
RTX HDR soll jetzt auch im Multi Monitor Setup funktionieren mit dem neuen Nvidia App Update. Nett
Hm, ok, klingt übel.
Ich nutze einfach immer Deskmodder, die sind die ersten die einen neuen Treiber melden. CB und Luxx zb sind da immer recht spät, manchmal kommt auch gar keine Meldung…
Und dann paar Klicks: bäm. Bringt mich jetzt nicht um. 😏
Wäre auch eine Alternative - die Treiber schön gelistet mit Releasedate, ohne Schnick-Schnack und ohne Mega-Platzverschwendung (bei NV)
Vom alten Layout hab ich grad keinen Shot da, aber mal muss die Seite stark verkleinern, um "bissl Content" auf die Seite zu bekommen :rolleyes2:
Ähnliche Themen
