[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Oktober 5090 :d und dann noch jetzt für DE neue karten der alten gen. und das auch noch vor dem Sommer ! `
Entder haben die (Nvidea) die CBE legalisierung sehr genossen ^^ oder die infos bzw Launch für next gen für dieses jahr sind falsch :/
Ich komme bei solchen Sachen nicht mit Logik, macht keinen Sinn. Es kann alles sein... 4090 Ti, Super, D... 4080 Ti... Vielleicht wollen sie auch nur mal Werbung für ihre zuletzt veröffentlichten Karten machen. Ist ja das gleiche Bild.
Was steht beim Bild dabei ?!?
"Eclipse2024"
Vielleicht auch nur ein Hinweis auf die Sonnenfinsternis vom 8.April, wer weiß das schon... 🤣
Wollte nochmal ein Kleines Update geben bezüglich meiner 4090
Heute kam die Mail das meine 4090 versendet wurde von Kris-fix und MODDIY hat eben per paypal die kosten von 202,30€ überwiesen bzw gesendet nachdem ich ihnen die rechnung geschickt habe
Also wirklich wirklich unkompliziert und wirklich ein Toller Support kann man nix sagen
Ja hört sich super an so sollte es laufen. Hört sich fast schon zu gut an und nvidia bezahlt die Schäden bestimmt hinten rum anstandslos.
theoretisch könnten sie das machen, die würden es nicht mal merken aber selbst dafür ist sich lederjacket zu schade.
Ja oder meint Ihr kabelmod US oder moddy schenkt euch einfach Geld obwohl Sie es bestimmt auf einen Anwendungsfehler schieben könnten
200 euro sind selbst für cablemod peanuts. aber dennoch löblich dass sie es überhaupt machen. das muss man denen wirklich lassen
Ja ich war auch total überrascht wie unfassbar Kulant sie waren die Kostenübernahme kam von MODDIY selber ich habe kein wort gesagt sondern wollte lediglich den Vorfall melden
Ja solche Brandfälle können ja böse ende und da möchte keine Firma rufschäden erleiden. Für mich ist die Schuld bei nvidia wenn 2-3 Spezialisten kein sicheres Produkt zustande bekommen
Ohne AIDA64 und der Volt anzeige vom 16pin hätte ich Safe nicht so schnell Reagiert mit dem PC runterfahren und wer weiß was sonst alles passiert wäre
Wäre undenkbar gewesen, in der Miningzeit…
Die GPUs waren monatelang unbeaufsichtigt und ich war auf Kreta (ok, nur zwei Wochen)
Trotzdem hatte ich manchmal böse Albträume (DECT200 zeigt mehr als 100 Grad Raumtemperatur an)
Zu Minigzeiten gab es noch keinen 16pinn (Gottseidank) Ich will nicht wissen wieviele GPU Farmen dann abgefackelt wären oder Defekte GPUs es gegeben hätte
Habs auch nochmal getestet mit Speedtest Belastungstest.
Bei Stock (1,05 V) und geht fast ins PL 11,822V laut neuste Aida und bei meinem UV Setting ( 0,975V) liegt
es bei 11.9+. Könnte ggf. ungesund sein wenn man dauerhaft bis 1,1V hoch zieht und 600 Watt PL.
Vielleicht hat auch deswegen Nvidia bei den neuen Karten auf max. 1,07V reduziert.
Ich werde es sehen wenn meine 4090 morgen wieder da ist und das neue BeQuiet kabel nutze wo da die werte liegen aber alles bis 11,825+ sollte im grünen bereich liegen
Wobei 11,8V bei mir nur jenseits der 520watt+ lagen sonst bin ich immer bei 11,9 bis 12v gewesen
Gut das ich als UV Nutzer diese Wattzahlen und Probleme nicht kenne. :d
Komm auf unsere Seite! Du kannst ja ein Teelicht in dein Gehäuse stellen, nur um warme/schmelzende Kabel und Anschlüsse zu simulieren... :fresse2:
Jens berichtet : „Mein erstes schönes Auto war ein Mercedes S500, mein zweites schönes Auto war ein Mercedes SL500,
Auf einem Trip nach Vietnam schloss sich Huang einer kleine LAN-Party lokaler Gamer an.
Evtl. kommt die 4090D zu uns, den Treiber kann man schon bei Nvidia downloaden.
Könnte sein, die ist ja von der Verschärfung der Regeln zum Export für Elektronik nach China betroffen... Die US Regierung hat sich doch nicht so leicht austricksen lassen und irgendwo müssen die Karten dann ja hin 😉
Eigentlich auch völlig egal was da jetzt kommt so lange da nicht 5090 drauf steht bewege ich mich kein Stück.
Letztes Jahr Herbst hätte ich auf eine 4090 Ti noch Lust gehabt so kurz vor EOL können die sie jetzt behalten.
Die haben schon was aus der 3090 Ti gelernt. Dass das läuft wenn man das so macht.
Gab genug Unwissende (oder Trottel), die sie zum ungefähren Preis der 4080 noch über Nvidia gekauft haben, anstatt sich eine 4080 zu holen.
Der Preis VPN 2249€ n halbes Jahr vor Release der 4090 war stattlich und nur für Leute die zuviel Geld haben oder besondere Fans
Ähnliche Themen
