[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Schrieb er doch, am Geruch und an der Spannung. Du hast es sogar selbst zitiert. :fresse:
Ah sry, am Handy nicht gesehen :d.
Edit: Bei den Karten sollte dann doch auch gleich die Spannungs-LED leuchten oder? Glaube rot oder weiss?
Selbst bei 11,6V war ich noch Ingame ohne Probleme und habe dann einfach den powerknopf am PC gedrückt und habe sofort das kabel rausgezogen und es kam erst die Rote LED wo ich das kabel abgezogen hatte
Kabel war seit Anfang Dez im Einsatz
Also bei mir sinkt der 16 Pin Voltage auch bisschen ab bei Stock auf 11,9 V laut GPU Z @ 400 Watt.
Ursprünglich im Idle steht diese bei 12,2V
Bei UV Setting bleibt es genau auf 12V @ 286 Watt.
Kurz mal mit Superposition angetestet.
Bei mir genauso, geht teilweise auf 11.925V runter, normal bei 12.02V und Idle bei 12.083V. Ab welchem Spannungsabfall wird es denn bedenklich, das was nicht stimmt?
Also ich hatte bei über 520watt ca 11,85-11,86
Alles bis 300-350watt waren immer so 11,9-12V
Bei mir genauso, geht teilweise auf 11.925V runter, normal bei 12.02V und Idle bei 12.288V. Ab welchem Spannungsabfall wird es denn bedenklich, das was nicht stimmt?
Ich würde jetzt nur aus meinem Fall sagen alles unterhalb von 11,8V würde ich mir gedanken machen
Ok, also sollte 11.925V noch ein normaler Spannungsabfall sein oder?
Also bis auf 11,9 V gehts bei mir auch @ Timespy Extreme.
Bei CP 2077 Benchmark war ich bei 12V
Schon ein bisschen nervig ,dass es plötzlich passiert , obwohl Jemand die Karte Monate drinne hat.
Ist schon alles bisschen komisch. Meine Karte seit Release drinne zusammen mit dem Corsair Kabel.
Bisher nichts passiert. Hoffen das es so bleibt. Eigentlich müsste man einen Rückruf machen und
alle Karten safe machen mit dem verbesserten Anschluss. Ist alles schon ne schweinerei...
Ich hab ein MODDIY mit geraden Steckern (20cm) seit 02/23 im Einsatz und noch keine Probleme bemerkt. Ich hatte auch schon die Karte zwei mal in ein anderes Case umgezogen.
Liegt es vielleicht am gewinkelten Stecker?
Ich hatte eher Probleme mit den original Kabel von Corsair, das funktionierte einfach gar nicht.
Es liegt eher an minderwertiger Qualität dieser Adapterlösungen von Drittherstellern.
Und solange die User das nicht einsehen wollen, wird es neue Fälle geben.
Ich konnte es auch nicht verstehen hatte von MODDIY auch schon zu beginn der 4090 ihr kabel aber eben 2x8pin auf 1x16pin
Jetzt wo ich mein neues Bequiet hatte was ATX 3.0 und nativ den 16pin hat hab ich wieder das kabel dort gekauft nur also 16pin auf 16pin
Der EZB-Rat äußert im Reuters-Interview die Meinung, es gebe unvermeidbare Risiken
Die sicherste Verbindung scheint und das ist nicht mal eine Überraschung, das native 16pin auf 16pin Kabel eines ATX 3.0/3.1 Netzteiles zu sein.
Fälle in dieser Kombination sind glaube ich bisher noch nicht auf getreten.
Ich nutze noch ein mit Liebe erstelltes teures cablemod Kabel ohne 90 Grad Stecker und versuche nachts nicht daran zu denken :) bitte Jens erstelle die 5090 ohne high risk Stecker
Gab es da nicht mal was, dass die 16 PIN Netzteil-Seite geschmolzen ist?
Aber klar, kann man an beiden Enden ungeschickt stecken.
Hatte ich bei meinem Gigabyte NT gehabt
Und dort hattest du den Stecker nicht korrekt drinnen gehabt am NT?
Edit:
Das Problem wird hier wie auch an dem Fall oben mit dem BQ gewesen sein, dass dies beides ATX3.0 Geräte der ersten Generation waren, die noch nicht die Stecker Revision mit den verkürzten Senspins hatten.
Das Ding ist: wenn da unglückliche Toleranzen drin sind wie beim bekannten chinesischen Kabel Anbieter, so dass der Stecker in der Aufnahme wackelt, dann kannst du das am Anfang sauber und dicht einstecken. Hilft dann nicht. Weil, wenns wackelt, dann wackelt es.
Ich kontrolliere 1-2 mal die woche immer das der 16pin am NT und in der GPU richtig drin sitzen tut daher würde ich das ausschließen
Ob das Standart 16 Pin Bequiet kabel schon die neue Revision hat von dem Stecker kann ich schlecht sagen aufjedenfall habe ich mir das 90° BeQuiet kabel gekauft und das kam erst vor kurzen auf dem Markt von daher gehe ich aus das dieses Kabel DEFINITIV! schon die neue Revision haben muss
Nutzt einfach keine Drittanbieter Adapter (gilt auch für das Bauer Ding) sondern die Kabel von NVidia oder den Netzteilherstellern. Im besten Fall noch ohne Winkel in einem ausreichend großen Gehäuse (ich nutze eins mit, aber gibt ja hier genug Schisshasen) und dann ist Ruhe.
Die nVidia 4-Ender sind auch nicht optimal. Bocksteif, teilweise schlecht entgratet und damit schlecht einsteckbar. Das hat mich ja überhaupt erst zum Kabel vom Netzteilhersteller getrieben. Theoretisch hätte man aber mit den Kabeln zumindest einen Anspruch auf Garantie. Theoretisch. Praktisch gibts dann schon wieder FAQ die zeigen wie die Kabel eingesteckt sein müssen. Da riecht man immer schon Lunte, dass das dann die Begründung für die Garantieablehnung ist. Kann nur falsch eingesteckt gewesen sein.
Es ist einfach ein Trauerspiel. Egal wieviel Geld du ausgiebst, am Ende bist du der Depp wenn ein Schaden auftritt.
Bisher tut mein Fasgear Kabel noch was es soll, und das wurde mittlerweile sicher auch schon 20+ Mal aus und eingesteckt wegen mehrfachen Mainboard und NVMe SSD Wechseln wegen defekten Boards.
Kann aber natürlich trotzdem was passieren wenn es blöd läuft.
Vielleicht hat aber auch die ständige "Überprüfung" dazu beigetragen, dass es Probleme gab?
Mach ich (fast) genau so, alle 8-10 Monate gucke ich mal nach ob alles in Ordnung ist. 😏
Das liegt aber daran das ich Original Hersteller Kabel verwende, bei Moddiy oder Cablemod Zeugs würde ich auch 1x Tag gucken ob alles in Ordnung ist. 🤣
Ich schaue Lediglich Optisch ob der Stecker noch voll drinsteckt das dauert wie lange 5-10sek xD pro seite
Aber hat mir in dem fall auch nix gebracht xD kann nur besser werden mit dem BeQuiet
Ähnliche Themen
Antworten
7K
Aufrufe
489K
