[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das Interface ist - dort wo es nötig ist - ja auch massiv schneller geworden, aber halt mit effizientem und sau teurem HBM. Im Gaming Bereich hat man zuletzt immer noch Wege gefunden die Notwendigkeit dafür zu umschiffen. AMD hat eigentlich den interessantesten Wandel vollzogen, von der einzigen Mainstream HBM Karte hin zu maximal 256-Bit, dafür mit Infinity Cache.
Irgendwann hat 384bit auch mal angefangen, da gab es sicher die gleichen Diskussionen
Kann mich nicht erinnern, dass das bei der 8800 GTX jemand interessiert hätte. Da waren die Transistoren noch so grob, die Anzahl der Einheiten noch so gering. Da hat das 384Bit-SI noch sehr entspannt dran gepasst.
Auch ist der Ram deutlich niedriger getaktet gewesen im Vergleich zu jetzt. Kannste also gar nicht vergleichen mit heute.
Hat hier jemand eine Gigabyte 4090 Aero oder Gaming OC? Wenn ja, welches Delta gibt es zwischen Eurer VRAM Temp und der GPU bzw. Hotsport Temp? Könnt auch gerne die absoluten Werte posten, aber mir geht es um den Unterschied.
In allen Reviews zur Karte liegt die VRAM Temp über 10° unter der Hotspot Temp. Bei mir sind sie gleich. 78° Hotspot und 78° bis 80° VRAM Temp. Jetzt nicht besorgniserregend, aber ich kenne das so, dass die VRAM Temps eher den GPU Temps ähneln, also bspw. 65°GPU/75°HS/65°VRAM. Bei mir sieht es so aus: 68°/78°/80°.
Ist auch egal ob ich den VRAM übertakte oder nicht, die Temps sind immer gleich. Ist da ein WL Pad verrutscht oder was ist los? Möchte den Kühler aber ungern runter nehmen.
Ich habe eine Gigabyte 4090 Gaming OC. Was soll ich da testen? Idle? Eine bestimmte Last?
Aber ich sags dir gleich, die bleibt auf 450W und einen Furmark sieht die auch nicht. Ich hab mich von den Bruteforce Geschichten komplett verabschiedet. Macht einfach keinen Sinn.
/edit: Ach, VRAM... guten Morgen, habe die ganze Zeit VRM gelesen. :fresse:
Bei dem Sprachgebrauch fällt mir eher "Slip mit Seiteneingriff" ein.
Moin, jemand der helfen will in diesem Thread, sowas gibt es noch? :)
Also brauchst nix wildes zu machen. Einfach bitte ein Game starten dass die Karte auslastet (97%+) und mir kurz einmal die Temps nennen (GPU/Hotspot/VRAM) und wie hoch Deine Lüfter drehen im Silent BIOS. Vielleicht so nach 20 min. Eilt jetzt auch nicht, einfach wenn Du das nächste Mal sowieso zockst. Das wäre super, vielen Dank! :)
Edit: Und bevor einer kommt, mir ist wie gesagt klar dass jedes System anders ist und man die Temps nicht direkt vergleichen kann. Geht mir auch nur um den Unterschied zwischen diesen drei Werten. Der scheint mir bei meiner Karte nicht in Ordnung zu sein (VRAM so warm wie der Hotspot, sollte laut Reviews 10° niedriger sein).
@Gurkengraeber
Also das mit dem Zocken mit Belastung dauert noch etwas. Vielleicht nehm ich dazu einfach den Cyberpunk Benchmark oder sowas.
Hier schonmal ein paar Runden 3D Mark Timespy Extreme und vorher komplett kalt und idle. Allerdings nicht im Silent BIOS:
Idle
Nach 3D Mark Runden
Die Tendenz siehst du aber: bei mir ist der Speicher recht kühl. War auch einer der Gründe warum ich diese Karte gewählt habe. Was aber auch klar ist, kurz nach der Last braucht der Speicher länger zum herunterkühlen bzw. erstmal fällt die Temperatur der GPU schneller als die vom VRAM
/edit: wo kam denn eigentlich der Slip Spruch her? Getippt hab ich den gerade eigentlich nicht? :alien:
Das war schon in meinem Post, aber ich kann nicht sagen woher das kam... zu viele Fenster offen?
Ok, aber die 62° sind ungefähr auch das, was in Reviews raus kam. So alles bis 65° scheint bei der Karte normal zu sein und die Aero verwendet ja auch das Kühlkonzept. Und nun steh ich da mit 80°. Bis 70 oder selbst niedrige 70er Werte wäre es mir noch egal gewesen, aber so? :(
Idle hab ich 34°, das passt.
Zurück schicken als defekt oder damit leben? Weiß nicht ob ich den Kühler abmachen möchte. Wie war das bei Gigabyte, verliert man damit die Garantie? Hmmm...
Wie gesagt: ich nutze nicht das Silent BIOS. Hab ich nie. Vielleicht ändert das was. Ich probiers aus.
Ah ok. Hab es jetzt nochmal mit dem OC BIOS probiert. Nach 20 min Witcher 3 mit RT (99% Auslastung) hatte ich 65°/75°/70°. Wenn Du es nochmal mit dem Silent BIOS testen könntest wär das cool, danke.
Aber dann ist das absolut im Rahmen bei mir allerdings drehten die Lüfter auch mit 1.700RPM. Dabei überraschender Weise immer noch angenehm vom Geräusch her, mir aber trotzdem zu laut. Ich würde diese Temps auch mit dem Silent BIOS erwarten (ca 1.300RPM). Die Aero ist immerhin eine der größten 4090.
Ich teste nachher (heute) nochmal. Versprochen. Aber der Kühler der AERO schaut auf den Bildern die ich bisher so finden konnte schon noch ein wenig anders aus als der der Gaming OC. Und man muss sagen, dass der VRAM der Gaming OC eigentlich "unnötig" stark gekühlt wird. Mir war das damals wichtig, weil ich vorher eine GB 3080 hatte und die war das genaue Gegenteil. Da sind die VRAMS den Hitzetod gestorben.
Im Grunde scheint die Aero da ein gutes Mittelmaß zu haben. Aber um ganz sicher zu gehen müsstest du eigentlich auch noch Werte von einem Aero 4090 Besitzer haben. Das Blöde ist nämlich, dass gerade bei Gigabyte entweder von Anfang an alles passt, oder du dann auch keine Hilfe mehr kriegst.
Ah ok, dachte die Aero ist baugleich zur Gaming OC abgesehen vom Shroud. Hatte jetzt aber nicht weiter nachgeforscht.
Also eigentlich passt alles. Die Karte ist echt sehr leise was fiepen und rasseln (nicht vorhanden) angeht, taktet @ stock ok (2.760MHz) und mit voller Lunte auf 3045MHz/1.550MHz. Für den 24/7 Betrieb habe ich sie mit 2.940/1.500MHz laufen ohne das PT anheben zu müssen. Die Temps bleiben im Vergleich zu stock unverändert.
Naja und wenn man sie vertikal einbaut ist sie auch in nem White Build zu gebrauchen, die Backplate ist ja leider silber. Das kostet nochmal 2°, aber das ist ok.
Einzig halt die Silent BIOS Kühler Performance gefällt mir nicht, muss jetzt überlegen ob ich mit dem OC Bios leben kann oder nicht. Wie hoch drehen die Lüfter denn bei Dir mit dem OC BIOS?
Es beginnt. Ich habe leider kein Witcher 3 installiert derzeit. Deshalb hab ich mal Cyberpunkt 2077 angeschmissen. Aktueller Patchstand. 4K, DLSS automatisch, Frame Generation an, kein Pathtracing, kein FPS Limit und auch kein VSync.
Zu beachten bei der Sache: ich nutze ein Fractal Torrent mit 3x140 mm Phanteks M25 im Boden, 1x Phanteks 140 mm M25 im Heck und 3x Phanteks T30 120 mm Lüfter auf dem Radiator für den CPU Kühlkreislauf (gedeckelt bei 2000 rpm). Meine Lüftersteuerung ist recht rudimentär und orientiert sich an der CPU Temperatur. Das heißt die Kiste ist für Wasserkühlungsverhältnisse eher laut und lüftet durch. Es ist nicht Freeair, aber nicht weit davon entfernt. Also je nach Lüfterkurve und Gehäuse könnte das woanders deutlich wärmer werden.
Erstmal OC BIOS, aber dennoch 450W Limit:
Du siehst also, die Temperaturen sind im grünen Bereich, Dafür rödeln die Lüfter mit fast 1900 und 1700 rpm.
Delta zwischen Chip (nicht Hotspot) und VRAM ~ 2-3°C unter Vollast
und hier noch der gleiche Akt mit der 4090 Gaming OC im Silent BIOS:
Temperaturen auf dem Chip und dem VRAM etwas höher, aber so im Bereich 3-4°C. Lüfter beide bei ca. 1500 rpm.
Delta zwischen Chip (nicht Hotspot) und VRAM ~1°C unter Vollast.
@Gurkengraeber schau dir wirklich bei Gigabyte auf der Seite mal die Kühler an. Der der Gaming OC wirkt mir deutlich dicker / höher von den Lamellen her und ist gerade im hinteren Bereich massiver als der der weißen 4090. Da erinnert der Kühler eher an die Windforce. Wobei ich mir nicht sicher bin ob das wirklich der Kühler der Windforce ist. Der Shroud ist sicher anders. Ich meine den "Metallblock".
Es wäre wirklich interessant wer sonst noch die weiße 4090 von Gigabyte hat. Es scheint wohl Unterschiede zu meiner Gaming OC zu geben.
/edit: wobei die Maße der Karte es nicht hergeben. Müssten sich also doch relativ ähnlich sein. Ich weiß es einfach nicht. Wenn das doch der gleiche Kühler ist, dann sollte dein Speicher aber besser gekühlt werden. schwieriges Ding.
Hier steht nochmal dass es der Windforce Kühler sein müsste: https://videocardz.com/press-releas...-white-geforce-rtx-4090-aero-oc-graphics-card
Also könnte man nach Temperaturen der Windforce Modell suchen.
Deckt sich das mit deiner? https://www.hardwareluxx.de/index.p...lle-der-geforce-rtx-4090-im-test.html?start=6
Kannst du nicht testweise die gleiche Karte irgendwo auftreiben?
Wäre ja nicht der erste Mal, dass WLPads nicht richtig aufgebracht waren
ASUS ist sogar so "geil", dass sie WLPads (anscheindend zu Dünne) bei der Strix da anbringen, wo es nix zu kühlen gibt :fresse:
Da bin ich leider nicht der Einzige...
Wow also erstmal vielen Dank für Deine Mühe @FR4GGL3
Also die Kühler der Gaming und der Aero ähneln sich sehr stark finde ich (Anzahl Heatpipes usw), sind aber nicht identisch. Verrückt was für einen Aufwand Gigabyte da betrieben hat, so viele unterschiedliche Kühler zu designen. Kann doch nicht wirtschaftlich sein. Die Aorus hat ja auch nochmal n Anderen.
Windforce:
Aero:
Gaming:
Jedenfalls sind Deine VRAM Temps echt super im Vergleich zu meinen. GPU und Hotspot passen irgendwo.
Also vermute ich doch ein verrutschtes oder fehlendes WLP oder so. Ach man, irgendwas ist ja immer. :fresse:
Die Möglichkeit hab ich leider nicht. Kenne zwar Leute mit 4090ern aber keine mit der Aero.
Dann aber direkt zurückschicken wenn du noch kannst. Von Gigabyte wird da sicher nichts kommen, solange alles stabil läuft.
Denn ich habe deine Eingangsfrage nochmal gelesen. Der VRAM ist bei mir immer 11-12°C unter dem Hotspot. Ich bin auch insgesamt sehr zufrieden mit der Karte. Hat zwar nicht den goldenen Chip vom Takt her, ist aber von den Temperaturen und vom Fiepen her das was ich wollte.
Wenn ich die jetzt zurück schicke, fiept die nächste garantiert wie Sau! :d
Ich mein ne Woche Widerrufsfrist hab ich noch, werde heut abend hier im Raum mal ordentlich einheizen, so ne schöne Sommer Temp entfachen und dann nochmal testen. Solange der VRAM unter 85° bleibt wär das ok für mich. Zwar 20° zu hoch aber immer noch weit vom Threshold entfernt. Am Ende muss die Karte ja auch nur bis Blackwell halten. :lol:
Edit: Ich habe übrigens keine Siegelaufkleber auf den Schrauben gesehen, also vielleicht mach ich die im Zweifel doch mal auf.
Auch komisch. Meine Gaming OC hat ein Siegel auf einer der Kühlerschrauben
Bei den Gigabyte Karten hätte ich keine Angst vor fiependen Spulen. Vor allem anderen, aber nicht vor den Spulen.
Ganz ehrlich: tu das Ding wech. Würde mich nicht wundern, wenn das einer mal unter Wasser gesetzt und dann wieder zusammengepfuscht und zurückgesendet hat. Da stimmt doch was nicht.
Was mir noch aufgefallen ist @FR4GGL3 , Deine Lüfter drehen mit beiden BIOS höher als meine. Im Silent BIOS kommt der Lüfter auf maximal 1.300RPM, im OC BIOS liegt er so bei 1.550RPM.
Ich hab den mal mit 1.700RPM drehen lassen, da bleibt der Speicher dann auch unter 70°. Wann hattest Du Deine Karte gekauft? Evtl. andere BIOS Version?
@Gurkengraeber Also zum Einen ist meine Karte aus Herbst 2022. Habe die ja damls zum Erscheinen gekauft. Und natürlich nie das BIOS geändert. Und es ist eine Gaming OC. Da werden sie bei deiner später erschienen Karte sicher irgendwas überarbeitet haben.
Ja nur, sollte die Karte offen gewesen sein und es ist irgendwann mal was anderes... mei, Gigabyte findet zwar ohnehin einen Grund aber wenn die schon offen war, dann wird das vermutlich nicht gut ausgehen.
Habe die Karte während eines Meetings jetzt nochmal ne Stunde richtig schwitzen lassen. Hitman 3 in 4K mit RT und ohne DLSS und PT auf 133%. Übertaktet auf 1500MHz (VRAM). Der blieb permanent unter 83°C im Silent BIOS (Lüfter auf 1.550RPM). Nach Eurem Input sollte das ja dann klar gehen, danke nochmal dafür.
Dass die mal offen war kann ich jetzt nicht sagen, sieht alles "unberührt" aus. Heißt nix, wäre jetzt aber auch kein Drama für mich.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
