[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hi, hat die ASUS 4090 TUF non OC das gleiche 600W Powerlimit wie die OC Variante? Ich such mich tot und finde dazu nichts.
Roman hatte es in einem Video gezeigt und ich habe es selber mit dem Corsair Kabel erlebt: es steckt wunderbar, aber wenn du minimal dran wackelst. Dann siehst du anhand der Status Led am Stecke, das sie sich auch nur bei minimaler Bewegung vom.status "alles gut" zu "keine Verbindung" wechselt. Der Stecker ist dabei bombenfest und korrekt drinnen. Man sieht es definitiv nicht.
Danke dafür. Nach einer User-Bestätigung des Roman-Videos zum Corsair-Stecker habe ich gesucht. Dann bleibt der Adapter, der bei meinem HX1500i dabei war, in der Kiste. Unabhängig davon, wie die Antwort auf die Frage ausfällt, ob er 450 oder 600 W durchlässt.
Ist der Plan ok, stattdessen drei 8-Pin-Kabel vom Netzteil mit dem 1x12 HPWR zu 3x8 Pin WireView zu verwenden? Lassen sich der 4080 Super auf diesem Weg 600 W zuführen (wenn die beim EVC2-Overvolting angefordert werden und das Karten-BIOS nach Flash das erlaubt)?
Eben nicht. Roman hatte es in einem Video gezeigt und ich habe es selber mit dem Corsair Kabel erlebt: es steckt wunderbar, aber wenn du minimal dran wackelst. Dann siehst du anhand der Status Led am Stecke, das sie sich auch nur bei minimaler Bewegung vom.status "alles gut" zu "keine Verbindung" wechselt. Der Stecker ist dabei bombenfest und korrekt drinnen. Man sieht es definitiv nicht.
Kannst Du das Video mal verlinken? War es das wo er sich über den Stecker beschwert hat, weil sein eigenes Produkt auch Gefahr läuft, damit nicht 100% sicher zu sein?
TLTW: Sprungmarke 13:16
Ja normal schon. Andere hatten damals die non OC bekommen und konnten das selbe einstellen wie ich mit der OC.
Aber nicht die OG Varinate https://geizhals.de/asus-tuf-gaming-geforce-rtx-4090-og-oc-a2946392.html
Diese hat einen abgespeckten Kühler und ein PL von glaube 520 Watt .
Egal ob non OC und OC .
Musst dann schon diese kaufen.
Danke euch, dann wird’s die non OC.
Die OG kommt nicht in Frage, ich will den dicken Kühler :d
Mir auch unverständlich, warum die OG aktuell 183€ teurer ist, als die Ur-TUF (beide Non-OC)
manche games wollen einfach nicht
3440x1440 DLSS Q + HDR mod + RT High full
300w. ende. 142 nicht mehr haltbar
ahhhh mit der option "ray tracing increase samples count" geht mehr saft
Ja die HDR Umsetzung von dem Mod war echt klasse.
Habe damit letztens auch nochmal die Ultimate durchgespielt nachdem ich
den ersten Durchlauf Alan Wake 2 hinter mir hatte.
an die asus 4090 karten besitzer, wie steuert ihr die rgb beleuchtung der karte, mit welcher software?
Armory Crate?
an die asus 4090 karten besitzer, wie steuert ihr die rgb der karte, mit welche software?
Kommst an Armoury Crate eigentlich nicht vorbei, wenn du mehr als nen Regenbogen sehen möchtest.
hatte meine FE ne Weile im C4 gehabt
Und warum jetzt nicht mehr?
Angeblich soll die GPU-Temp damit sehr gut sein
btw:
Hab mich immer gefragt, warum mal für ein "paar Lämpchen" zu steuern, mehr als 800MB laden muss :rolleyes2: ("Armoury Crate" alleine, ohne Aura, ohne virt PET)
schade, hatte gehoft ich könnte auch eine andere software nutzen :/
Den Nachteil mit dieser Crapware/Bloatware muss man leider in Kauf nehmen, will man alle RGB-Einstellmöglichkeiten vollends nutzen mit seiner ASUS Karte.
Danke, danke :-)(y)
Aber welches ITX-Case wäre am besten bzw. welches für beste GPU-Temp?
Hab auf die Schnelle nur einen Vergleich gesehen, wo die GPU-Temp mit dem "Dan C4" am Niedrigsten wäre
Ähnliche Themen
Antworten
6K
Aufrufe
392K
