[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja Herbst 25 wäre mir auch bissel zu spät, erst gestern mal Immortals of Aveum mit UE5 probiert, dass Teil ruckelt ja wie irre, auch mit FG und DLSS Q.
Geht von 116Fps bei mir immer sprunghaft auf bis zu 40FPS runter und das quasi ständig.
Kommen ja , aber irgendwie werden die kommenden Games bis zur nächsten gen. Flüssig laufen müssen auch wenn nicht auf Max. Settings . Bin gespannt auf Stalker 2 aber ahne schlimmes.
Stalker 2 - joa...
Bin auch auf einen "Free walk" oder "free fly" bei SDiF gepsannt, damit ich mir auch mal ganz in Ruhe die random Maps angucken kann :rolleyes2:
Denke auch das Stalker 2 ein mittleres Desaster wird und es viele Monate lang Patches benötigt um einigermaßen spielbar zu sein..,.
Nach BG3 ist es schwierig ein gutes Spiel zur Zeit zu finden, habe mich nun auf Yakuza infinite Wealth eingelassen, gute Überbrückung bis FF VII Rebirth endlich erscheint.
Vorhin mal die Release Liste für 2024 angeguckt, die ist bisher erschreckend leer.
Die 4090 will ja benutzt werden…
Hi Leute, ich leg mir grad etwas die Karten.
Ich hab folgendes Problem..
Wenn ich Windows installiere, kommt es während der Treiber-Installationen immer wieder zu Abbrüchen und Artefakten ( Maus lässt sich noch kurz bewegen dann friert das Bild ein ). Danach dann BSOD wie unten in den Fotos dargestellt.
Das selbe System lief aber vorher für 1,5 Tage „halbwegs“ normal .. hatte da beim öffnen von Programmen ab und an mal nen Unterbrechen bei der Maus Bewegung (und Programme brauchten manchmal etwas lange im Startvorgang)
Aber ein Timespy Extreme lief gut durch (ebenfalls Bild im Anhang)
Der Normale Timespy hingegen war von der erreichbaren Punktzahl bei der GPU auf 30K beschnitten (wo sie ca 38K machen sollte) - soll aber laut Foren eher nen 7950X3D CCD Zuteilungsproblem sein.
Hat jemand schon mal was ähnliches wie auf den Bildern gesehen?
Hab bereits schon einiges an Hardware getauscht (aber immer wieder die selben Probleme) ..
CPU, Mainbaord, RAM, SSD.. alles andere ist noch beim alten geblieben.
Ist das nen GPU Problem, oder kann das auch nur am Riserkabel der GPU liegen? (Da das System in nem Loop hängt, würde ich ungern mehrere Male basteln - ist sehr undankbar im V3000 plus Gehäuse 😅)
Ein Netzteil würde andere Probleme verursachen oder?
Danke für eure Hilfe ❤️
System:
AMD 7950X3D
Asus Gene X670E
Inno3D 4090 Ultra Frostbite (am Linkup - AVA 5 PCIE 5.0 Riser Kabel)
Corsair AX1600i
RAM G.Skill 8000mhz CL40 2x24GB (bereits auch schon mit verschiedenen Takten getestet) und auch schon nen 6000mhz Expo Kit getestet
Windows 10 und 11 probiert
Treiber alle auf dem neuesten Stand 👍🏼
Anhang anzeigen 965330Anhang anzeigen 965331
Hi Leute,
Ich hab das Riser Kabel nun aus dem System verbannt, nach einer frischen Windows 11 Installation wieder das selbe Problem. Windows Installation über den Stick läuft sauber durch, aber in Windows während der Treiber Installation hängt sich das System auf und friert ein. Erst ein schwarzes Bild, dann der gesamte Bildinhalt nur noch in der oberen linken Ecke (so das er nur noch die Hälfte des Bildes vom 32:9 Monitor füllt - dann friert Windows komplett ein)
das bekannte Fehlerbild mit den Artefakten und keine Möglichkeit mich in Windows anzumelden.
Würdest ihr sagen die neue 4090 Frostbite Ultra ist defekt? Oder könnte es auch im exotischen Falle das Netzteil sein? (Beim Netzteil hätte ich sicher eher komplette Abstürze mit schwarzem Bild oder?)
Danke für eure Hilfe ♥️Ich verzweifle langsam echt 🥹 durch die Wakü ist die GPU auch nicht so leicht getauscht 😵‍💫
Ja hab ich 👍🏼 hatte grad eben Kontakt mit Inno3D Karte muss scheinbar getauscht werden 😵‍💫
Hast du keine iGPU um mal zu testen?
Ich hab mir heut erst nen usb-c Kabel bestellt 🫣 ist bei dem gene ja etwas doof gelöst 😵‍💫 hatte auf das Riser Kabel gehofft nach den Tips hier 😕
Meine Frostbite ist vor kurzem gestorben. Die Symtome waren aber anders.
2024 sieht echt ziemlich mager aus an Games. Frostpunk 2 interessiert mich wohl wenn es dieses Jahr erscheint aber sonst... Glücklicherweise habe ich mit Tekken 8 und Dragons Dogma 2 zwei Games, die mir wahrscheinlich das erste Halbjahr komplett genügen werden.
@TKJBerlin
Meine Karte ist die erste Version der Frostbite. Da gab es noch nicht die zwei Modelle. Also keine Ultra.
Meine Symtome waren PC-Abschaltung unter Last. Aber nicht 450 Watt, sondern eher 220 Watt. Später startete sie nicht mehr und die GPU-IndexLED auf dem Mainboard leuchtete dauerhaft sowie keine Bildausgabe mehr.
hatte die Karte dann woanders getestet, gleiches Verhalten. Kein Bild mehr
@TKJBerlin
Na das ist ja auch mal nen herrliches Problem 😕 hoffe das unsere Karten ne Ausnahme darstellen 🫣
Wie lang hat der Austausch gedauert?
Find ich gut. Dann soll er die kaufen.
Gibt bestimmt n paar Panikverkäufer, die meinen die 4080S wäre der große Wurf und ihre Karte ist veraltet. Und dann kann man bei der 4080 n Schnäppchen machen.
Topaz Video AI - Schrecklich... :oops:
Ein Video von nur 5 Minuten mit wackeligen 1280x720 (30Hz) zu stabilisierten 3840x2160 (60Hz) zu konvertieren, dauert ca. 45 Minuten. Die GPU-Auslastung liegt aber bei nur 43% avg :cry:
Moin. Darf ich ich die Aufmerksamkeit der geballten 4090-Kompetenz bitte kurz auf auf die Fragen in diesem Thread lenken? :)
Hier sind wir aber wieder beim Thema:
High-End früher - man war mit 60 FPS zufrieden vs. High-End heute - mehr FPS bitte, nee noch mehr!
Früher hatten wir aber auch 1080p Monitore mit 60Hz und ohne VRR. Der 4k 144Hz Monitor möchte halt gefüttert werden.
Ich wäre wahrscheinlich heute noch mit meiner GTX 1080 zufrieden hätte ich nicht irgendwann 4k für mich entdeckt. Scheiss Hobby.
Ich bin immer noch 2k unterwegs aber dafür OLED. :)
Ich habe mich ASUS ROG Swift PG27AQDM OLED mit 240Hz im Dezember zugelegt.
Ich mag nicht sehr riesige displays eher 27 zoll nutzer.
Ich würde nicht mehr züruck zu VA pannel gehen. OLED finde ich super.
Ähnliche Themen
Antworten
7K
Aufrufe
540K
