[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es ist aber auch schwieriger geworden. Die Technik ist heute sehr viel empfindlicher. Früher hast du Stabilitätstests recht ausführlich machen können. Heute hast du die Chance mit entsprechenden Lasten wie Y-Cruncher und co. die CPU in kurzer Zeit zu schädigen. Also sind richtig harte Stabilitätstests einfach nicht mehr so gangbar.
Und dann kommt dazu, dass mittlerweile der Druck auf alle Softwareentwickler steigt immer schneller auszurollen. Also kommen auch da immer wieder Bugs nicht ans Licht. Und zum Schluss weiß keiner woher der Fehler kommt.
Nun gut der Speicher taktet doch auch mit Übertaktung runter auf die normal Werte.
Gibt ja viele Berichte , dass einige Leute Probleme am Desktop haben in Verbindung mit VRAM.
Habe auch den Eindruck das es meistens Leute mit einer 4090FE waren die damit Probleme hatten.
Ich hatte bisher am Desktop nie irgendwelche Probleme seit Release.
Aufgefallen ist mir nur. Warme Bude +1700 MHZ Speicher OC rennt. Kalte Bude +1400-1500 MHZ Speicher rennt.
Das ist auch so ein Thema. Bei Kalter Bude gehen dann +30 MHZ GPU Takt bei mir.
Du, theoretisch könnte es in jedem Fall auch ein defekter VRAM sein. Beim Übertakten leg ich da meine Hand nicht ins Feuer. Ich habe aktuell einen nie übertakteten defekten Prozessor hier liegen (Intel will aber den Prozessor erstatten). Sag niemals nie.
Aber der Checkerboard Bug ist schon bekannt. Von daher wollte ich das nicht verschweigen.
Habe mir den Thread mal komplett durchgelesen und das ist exakt das Problem was ich hatte. Meistens trat es auf bei Youtube oder Twitch im Window Modus aber nie im Fullscreen, was auch einige dort im Forum so beschreiben. Denke mit dem Speicher hat das nix zu tun. Werde es beobachten aber mit Firefox läufts halt. Mein OC auf dem Speicher ist auch weit von der Grenze entfernt die ich damals ausgelotet habe für meine FE (+1600)
Ich bin froh das nvidea sich mit der 5090 Zeit lässt und ich so ein wenig Geld sparen kann:) viel Spaß mit der 4080 super ti ultra
Ist das nicht schon wieder vom Tisch mit 5090 erst 2025?
Nicht das ich wüsste, wird eigentlich eher immer wieder bestätigt in den neuesten Gerüchten statt dementiert.
Thema OC:
Viele vergessen das Hardware mit der Zeit degradiert, also OC gerade in Grenzbereichen dann Probleme macht.
Also haben wir noch Zeit zum Sparen :)
Hallo.
Wir sind im Luxx. 🤣
Naja ich würde mal so 2300 oder für die FE rechnen. Hängt halt viel vom € Kurs ab der gerade nicht besonders gut aussieht :fresse: Mehr als 200$ Aufpreis zur 4090 rechne ich nicht mit. Ich denke aber, dass der Leistungssprung dieses Mal nicht so krass wird, vor allem wenn sich AMD wirklich aus dem High End zurück zieht in der nächsten Gen.
Die 4090 war nur so stark, weil AMD so konkurrenzfähig war mit den RX6000 Karten und Leaks zu RX7000 auch sehr gut aussahen, was sich dann ja aber bei Release eher als Luftnummer herausgestellt hat. Ich erwarte hier eher so einen Sprung wie von 1080 Ti auf 2080 Ti. Damals war es ja eine ähnliche Situation. AMD nicht konkurrenzfähig also nur das mindeste rausbringen. Würde mich nicht wundern, wenn die guten Chips dem KI Markt komplett vorbehalten werden, da man hier ja die meiste Kohle macht und man so auch das Zweckentfremden von Gaming Karten verhindern würde.
Ich überlege die Karte zu verkaufen.
Anscheinend kommt nur die Pny 4090 in Frage:
Laut Tests (z.b. von pcgh) ist diese mit 0,9 sone leiser als alle anderen.
Aber nicht zu einem Preis von über 2200€....
Naja wir können auch durch zwei punkte glück haben einaml denn neuen speicher gddr7 bring auf jeden fall par%.
Als zweites kann es sein das KI markt ein chiplett design bekommt und wir noch ein monolit auf jeden fall testet nvidia mit beidem.
(von Amd seite wird leider keine hielfe kommen denke ich)
Interessant.
Grade eben ist der Computer mit einem elektronischen Störgeräusch (überspannung? Hörte sich nach einem brrrz an) ausgegangen und direkt neu gestartet. Ein paar Fehler aufgrund des abgestürztzen Red Launchers und Windows wurde nicht ordnungsgemäß heruntergefahren aber kein Kernelabbild.
System:
5800x3d (Stock)
2x32gb DDR 4 3600mhz (laufen derzeit mit 2666mhz)
Dark rock slim
Rtx 4090 Ichill x3 (2500mhz@0,9v), durchschnittlicher Verbrauch: 250 Watt, Peak bei 300, Lüfter per ab auf 31% gesperrt (manuell)
Win11 pro
Dark Base 700
Straight Power 11 850 Watt Platinum
Heutige Änderungen:
Zusätzliche ssds eingebaut, somit insgesamt: 4x SATA, 2x nvme Samsung, WD, Crucial gemischt, TLC, MLC + einen neuen Be quiet Silent Wing 4 eingebaut.
Zusätzlich in Cyberpunk 2077 eine Collection für Texturupgrades + das Cyberpunk Reworked Paket installiert.
Nachdem der PC hochgefahren ist, kam kein Bild. Nach einem manuellen Aus und wieder Anschalten gab's wieder ein Bild. Keine Bildfehler und keine Errors. Es wäre sehr unwahrscheinlich, wenn die GPU überhitzt ist.
ich würde auch eher sagen netzteil , das klingt so garnicht nach gpu
Der Reihe nach prüfen:
- Stecker
- anderes Netzteil
- schauen wie sich die GPU mit einem anderen Netzteil auf Dauer und unter Last verhält.
Das Geräusch würde mich jetzt auch zum Netzteil leiten. Aber es kann durchaus Schutzschaltungen auf der GPU geben, die dir den PC abschalten. Ich hatte sowas bei einer AMD Grafikkarte mal.
Interessant.
System:
5800x3d (Stock)
Dark rock slim
Win11 pro
Dark Base 700
Heutige Änderungen:
Das deutete idR auf Kontaktprobleme in dem 230V Stromkreis hin.
Also Kontaktprobleme an den Steckern von Steckdosenleiste und NetzStromKabel des NTs. Oder Kontaktprobleme in den Schaltern von Steckdosenleiste, oder dem Netzstromschalter des NTs.
Kurzfristig Lösung ist dann:
-Rechner ausschalten,
-alle Netzstromstecker vom Netzstrom trennen,
alle Netzstromschalter(stromlos) mehrere Duzend mal schnell hintereinander betätigen, damit die Schalterkontakte wieder sauber werden,
-Kaltgerätestecker am NT komplett einstecken
Deeinstallation vom AB,
Deeinstallation vom Treiber mittels DDU, Neuinstallation des Graka Treibers mittels NVCleanstall.
Neuer TS extreme Stress Test.
Update:
Kein Bildsignal mehr.
PC manuell neu gestartet.
Seltsam....
Standardeinstellungen sind laut und ineffizient. Das Tool TuneUp von Inno3D ist auch eher wenig geeignet (Die Lüfterkuve ist noch grausamer als die, die der AB ausliest).
Wenn ich mittels TuneUp einfach nur die Taktrate der GPU und des Speichers senke, läuft der TimeSpy extreme nicht mehr durch. (Loop 11/20) freeze. Also wieder mit dem AB testen
Update2:
2070 mhz@0,87-0,89v läuft stabil durch den TimeSpy extreme.
Cyberpunk läuft jetzt auch schon länger stabil. Vielleicht klappt's ja so.
Meine SuprimX hat leider vor ein paar Tagen den Geist aufgegeben.
Habe diese eigentlich fast nur undervolted betrieben, ab und zu bei Spielen wie Cyberpunk oder jetzt bei Avatar, etwas OC aber immer mit dem 100% Powerlimit.
Joa vor 1-2 Wochen war plötzlich der Bildschirm schwarz, Ton und alles war noch zu hören, gut dachte mir nichts dabei xD, Neustart und gut.
War dann erstmal wieder Ruhe, dann jetzt am WE, wollte ne Runde Dead-Island 2 spielen, schwarzer Bildschirm nach 5 Minuten, Ton war noch zu hören.
Dann mit dem DDU Treiber runter geputzt, neuen Nvidia Studio Treiber installiert, gleiches Thema. Also das System und alle HW auf Standard gesetzt, gleiches Fehlerbild.
Da mein System mit Veam gesichert wird, mal kurz ne Neuinstallation gemacht,
Die Karte zeigt das gleiche Verhalten, bzw. mit Furmark dauert es keine 3 Minuten bis zum schwarzen Bild.
HW gecheckt und siehe da die Kabelpeitsche war verkohlt und der Stecker sah nicht mehr frisch aus.
Der Anschluss von der Karte sah auf den ersten Blick eigentlich gut aus, weiter hinten am Seasonic Netzteil, ist ein Titanium 850er, sahen die Buchsen auch etwas seltsam aus.
Naja lange Rede kurz, vor den Feiertagen natürlich alles sehr ärgerlich, die Karte hat nun einen Schuss bekommen, und geht in die RMA, bei Mindfucktory --> gar kein Bock das kann dauern.
Wird aber sicher ausgetauscht.
Seasonic, wieder mal sehr vorbildlich, hat gar nicht lange diskutiert und meinte ich bekäme so schnell wie möglich ein neues NT.
Werde mir aber nun eins mit ATX 3.0 und mit 1000 Watt holen, haben mir aber auch einen Adapter angeboten, falls ich das ausgetauschte 850er weiter benutzen möchte.
Ach ja hab mir ne PNY für nen guten Preis sichern können, sollte bald kommen.
Ansonsten muss ich sagen das GeforceNow so als Überbrückung mit Glasfaser schon auch nice ist.
Im Bekanntenkreis hat auch eine 4090 die Hocke gemacht (Gainward) und der Besitzer steht über die Feiertage ohne Karte da, konnte keinen Ersatz besorgen. Sehr ärgerlich. Hatte ihm den Rechner im Frühjahr gebaut, gab nie Problem. Dann plötzlich kein Bild mehr. Mit einer anderen Karte in seinem Rechner läufts, seine Karte bei mir eingebaut gibt ebenfalls kein Bild. Einfach tot. Naja, hab ihm ne alte 1080 von mir gegeben, kann er zumindest in Full HD ohne Details zocken. :fresse:
Aber irgendwo hier im Thread gab es noch weitere verreckte 4090. Hoffe das sind alles nur Ausnahmen.
Ja. Laut ihm gab es aber keinen Kurzschluss oder verbrannten Geruch oder so (ja, Stecker war ok :fresse: ), hab allerdings jetzt auch den Kühler usw.. nicht abgebaut. Die Graka gab aber an allen Anschlüssen kein Bild mehr aus, die Lüfter liefen allerdings an. Naja, war eine Karte von Computeruniverse, hatte mit denen noch nie Probleme. Hoffe die RMA wird nicht so lange dauern, die Karten sind ja generell verfügbar. Und so ne 1080 ist doch auch was feines, darauf hab ich in 1080p noch RDR2 gezockt. Zur not halt die Zeit nutzen und mal wieder die Excel Kenntnisse auffrischen oder so, er wirds überleben. :coffee2:
Ähnliche Themen
Antworten
7K
Aufrufe
540K
