[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bin froh, dass mir die Optik mittlerweile so egal ist und das Seasonic Kabel nutze. ^^
Die Cablemod Adapter sind doch totale Scheisse und sehen auch so aus. Seasonic hat auch ein weißes 90° Kabel und das nutze ich ohne Probleme. Sieht auch besser aus als der Cablemod Klotz.
@Thunderburne Hast du mal den "Unobtanium" Preset probiert? Muss man anscheinend per command aktivieren. Würde mich mal interessieren wie das die 4090 pusht.
Grüße danke für den Link.
Wäre cool wenn es die Tage da was für ne CFG geben würde oder das man es dauerhaft anwählbar macht.
Ich schau Mal ob ich später noch da zu komme.
Die 4090 wird aber schon so stark gefordert mit DLSS Qualität teils 430 W bei ca 70-80 FPS mehr gibt es dann nur mit AMDS FG und weniger mit. DLSS Ultraqualität ca 60FPS.
Native keine 60 FPS möglich .
Unter 60 FPS finde ich aber läuft das dann wirklich nicht so gut 60+ sollte man haben daher DLS Qualität ist max für 4K.
Soweit ich es verstanden habe ist es dauerhaft anwählbar sobald aktiviert. Man muss die Zeile bei dem Ubisoft Launcher für das Spiel festlegen.
Werde mir das Game im neuen Jahr mal mit dem Ubisoft Abo für einen Monat holen. Glaube das kostet 10€
Nachricht gelöscht
Hier in dem Video kann er es einfach auswählen. Brauchst halt den Startbefehl
"Perfekter" Anfang... :ROFLMAO:
@SaiBot62
Hab ich schon am laufen leider JPG Stark Komprimiert.
Max out mit FSR Ultra Qualität *Framegeneration
Grade so um die 60 FPS mit Fakeframes ist aber schon arg wenig :d Glaube die Option würde ich nicht nutzen fürs normale Gameplay
Du wolltest es wissen. :wink:
Muss aber sagen AMD hat das bei dem Spiel hinbekommen mit Fluidmotion.
NVs Framegeneration ist ja noch nicht mit dabei.
Mit Controller lief das gerade gar nicht schlecht.
Ja sollte ja UHD @ DLSS Qualität ( 1440p) so 80 FPS laufen laut CB Test.
Habe mir die Bilder bei CB angeschaut. Das sieht schon sehr gut aus das Game.
Texturen alles sehr hoch aufgelöst. Dann halt alles recht dichter Wald mit recht hohen LOD Level.
Klar kostet halt Leistung. Da scheint auch ne 16GB Vram Karte empfohlen zu werden , damit alles einwandfrei läuft.
Spiel an für sich soll nicht so geil sein von Story her, aber immerhin hübsch^^
@Thunderburne : Hat man bei diesem Ubisoft Spiel wieder die üblichen tausend Suchaufgaben und Erkundungssachen oder ist es bisschen interessanter gestaltet mit Nebenquests und Storyquests?
Schade...
Ca. 18% " beliebt" - Holy shit :ROFLMAO:
Hab mal Hogwarts Legacy angefangen. Läuft irgendwie unruhig das Bild.
Welche Einstellungen haben sich hier bei den 4090 Besitzer etabliert für das Game?
Ich spiele mit 4K max settings und DLSS Quality aber ohne RT. Man kann auch mit RT und dann Frame Generation einschalten aber für mein Empfinden wird das Ruckeln dadurch nur schlimmer und RT sieht auch komisch aus in dem Game. Als wenn in Hogwarts jede Oberfläche nass wäre und mit der Beleuchtung gibt es auch Bugs im RT Modus.
Aber wie schon angedeutet wirst du das Ruckeln nie eliminieren können. Besonders in Hogwarts und Hogsmeade hast du immer wieder welche. Liegt am Game, schlecht optimierte UE4 halt.
Wollte RT eigentlich nicht abschalten, aber versuch es mal dann damit. Diese Microstutter sind echt unangenehm und auch total irritierend, da fps stets ü60 liegen.
Traurig das ein spiel das so oft verkauft wurde bis heute nicht gefixxt wurde (leider hab ich es mir gleich zu anfang gekauft was die leider nicht verdient haben nach disem ergebenis). Kommt viel zu gut weg nur weils HP universum ist finde ist auch kein schlechtes spiel aber die performence ist Traurig. Führ denn leistungs hunger müsste das eines der schönsten spiele sein die es aktuell gibt und vieles gameplay ist auch nur das selbe wie bei ubisoft dafür so ne wertung hat es nicht verdient. Aber bin ja mit schuld das sie nix mehr daran machen weil haben ja gesehen das man auch mit einem schlecht optimiert spiel gut verdienen kann.
Und wir wollen schon UE5...? :fresse:
Die Entwickler sollen erstmal UE4 richtig ausnutzen. Jetzt ist die Frage, ob die Hogwards-Entwickler es nicht hinbekommen oder unsere HW noch zu schwach ist oder beides
Zu "The Days Before"...
Ist es möglich, dass Steam so einen Drecks-Entwickler, wie "Fntastic" ganz aus dem Store schmeißt? (sorry, etwas "diplomatischeres" fällt mir bei diesem "Pixel-Puff" nicht ein). Was die da abgeliefert haben, ist eine ziemliche Sauerei. Mir tun die Leute (insbesondere Kids) leid, die auf so viele Lügen heingefallen sind :fire:
Aber "egal", die Kuh hat ihre Milch an "Fntastic" abgegeben. Zum Glück bin ich bei diesem Drecks-Game nicht schwach geworden
Das Spiel an sich ist echt gut aber die Technik ist traurig auf dem PC. Es sieht toll aus aber das Stuttering macht es schon ein wenig kaputt. Es kommt wahrscheinlich auch nix mehr, letzter Patch im Juli oder so. Wollte es jetzt aber doch dann mal zocken und hab es in der Black Friday Woche für 25€ bekommen. Es betrifft zum Glück hauptsächlich nur Städte und eben Hogwarts. Die Kämpfe sind meistens flüssig. Es ist spielbar mit Controller aber schön ist das nicht.
Also RT Schatten sehen schon gut aus bei dem Game . Bei den Reflexionen kommt es drauf an vorallem bei den Böden ist bei manchen Oberflächen zu viel des Guten. In der Open world durchaus schön.Habs selber auf Ultra DLSS Qualität @ RT und FG on gezockt . Ruckler meine war nur in Hogwarts selber. Open World war ok und auch bei den Kämpfen keine Probleme . Spiel hat auf jedenfall hohen Ram Verbrauch und CPU wurden die 8 P-Cores ordentlich gefordert. Hab’s nicht so dramatisch in Erinnerung. Hatte es nach dem letzten Patch im Sommer gespielt. War zufrieden mit dem Game im Großen und Ganzen , aber paar kleine Fehler gabs soweit ich weiß , aber hatte keinen einzigen Absturz in dem Game.
Ok, vielleicht sollte ich auch runter mit der Auflösung von 5k auf UHD, vielleicht wird es dann flüssiger😅
Ich meine prinzipiell würde die GPU auch 5k/DLSS Quali/FG locker 90fps schaffen, aber das stuttering halt...
Außerdem kommt mir die Steuerung noch sehr... behäbig vor. Dachte, dass es am Input Lag wegen FG liegt, aber nope. Erinnert mich bisschen an RDR2, von der Steuerung her.
Okay nach zwei Stunden hin und her schalten von Einstellungen und einigen Crashes später, scheint folgende Mod und paar .ini Einträgen für mich das Spiel zu retten
Selbst RT funktioniert und microstutter ist komplett weg. Gott sei dank! Das war ja nicht auszuhalten.
RT in hogwarts ist kaputt. gibt dafür mods
hast du die fps mit FG mit dem AB gecapped? das darf man nicht. FG fps cap nur über ingame engine oder nvidia CP
Bin zwar schon fast durch aber werde es mal probieren :d
Welche Mod nutzt du. Die oben verlinkte hat microstutter eliminieren können, aber das seltsame Verhalten von RT leider nicht. In manchen Räumen flackerte es ganz wild vor sich hin mit so seltsamen Artefakten.
Kein Cap.
Ähnliche Themen
