[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wenn dich das schon schockiert, dann schau dir bitte nicht an was manche Leute im Audiobereich für Kabel kaufen :fresse2:
Oh, das ist mir sehr vertraut. Ich hab einige Jahre Car HiFi im Auto gehabt (3-Wege Umbau mit Armaturenbrett raus, Komplettdämmung und einem speziellen Bandpass) und habe auch ein wenig, aber sehr abgespecktes HiFi hier im Haus. Verstanden habe ich das mit den Kabeln nie, abgesehen von Verarbeitungsunterschieden, die aber auch ohne unmögliche Kosten erreicht werden konnten.
48€ für ein 3m Kabel kommt mir auch viel vor aber ich hab selbst noch mehr für einen cablemod Adapter bezahlt :(
^^ Genau das hab ich auch gedacht. :d
Der NVIDIA GeForce RTX 4090 + HDMI Kabelthread. :rolleyes2:
Finde ich schon legitim. Viele nutzen mit der 4090 die LG TVs als "4K" Monitor. Deshalb gehören solche Erfahrungswerte schon ein wenig mit rein. Was wäre dir denn sonst lieber?
Nur rein über die Karten? Ich denke da gibts dann ziemliche Stille bis die Super Karten kommen.
@Holzmann schau mal eine Seite weiter vor im Thread.
Dafür gibt es doch extra einen Thread, wo man ausgiebig sowohl über die OLED's als auch die passenden Kabel diskutieren kann:
Da gibt es mittlerweile reichlich Tipps welches Kabel man in welcher Länge nehmen sollte. Finde es artet hier zu sehr aus und ist am Thema vorbei.
Vielleich zu dem 48€-Kabel noch gleichzeitig ein Günstigeres testen...!?
Alleine für das Zertifikatslabel zahlt man nen Haufen Geld ;)
Oder...
...zwei exakt gleiche Waagen. Die Eine ist geeicht, die Andere nicht - welche ist teurer? :fresse:
Von dem hatte ich damals das 10m (oder waren es 5m 🤔) gekauft und konnte leider kein HDR durchschleifen.
Die kürzeren davon laufen prima, welche ich auch nutze.
Ohne LWL, nehme ich an?
Spezifikationen:
  • Leistungsfähig: Das Kabel übertrifft dank erstklassiger Fertigungsqualität und verstärkter, hochreiner Kupferleitungen die High-Speed-Spezifikation und überträgt daher UHD-II-Auflösungen wie 8K bei 60 Hz und 4K bei extrem schnellen 120 Hz (max. 3 m)
Es soll also besser als ein HDMI 2.0 spezifiziertes Kabel sein, ist aber noch kein HDMI 2.1 Kabel. Steht auch nur High Speed und nicht Ultra High Speed.
Hatte das Kabel in der 3m Variante mit einer 3080TI im Einsatz und da gabs random Signalaussetzer für paar ms. Nervt halt beim Zocken.
Kann mit dem Kabel klappen, muss aber nicht.
Dann greif ich lieber einmal tiefer in die Tasche, aber dafür ist Ruhe in der Truhe.
Spezifikationen:
Gibt es von der Marke aber auch als Ultra High Speed HDMI 2.1 Variante.
KabelDirekt – 8K/4K HDMI-2.1-Kabel – 3 m – von HDMI zertifiziert für höchste Qualität (8K@60Hz, Ultra High Speed/48G, neuester Standard, optimal für PS5/Xbox, Monitor/TV/Beamer, schwarz) https://amzn.eu/d/5Ljv7ak
Das nutze ich in 1.5m Länge und hatte bisher keine Aussetzer. Könnte natürlich an der Länge liegen. Aber ansonsten sehe ich hier ehrlich gesagt keinen Grund das 3 fache auszugeben, wenn es das schon tut
die Abzocke mit den Kabeln ist inzwischen wirklich unverschämt und für Laien total undurchsichtig
aber noch schlimmer ist es bei USB C Kabeln... die haben so viel Spezifikationen, da wird man nicht mehr fertig... USB C mit 100w laden aber nur usb 2.0 speed sind die geilsten^^
wie kommt man auf die kombi...
Ich versuche gerade mein Glück mit einem nicht zertifizierten gpnstigen glasfaser Kabel https://www.amazon.de/Glasfaser-48G...+2.1+glasfaserkabel+10m&qid=1699877294&sr=8-3
Sooo endlich Alan Wake 2 durch, zum Schluss musste ich mich tatsächlich durchquälen…bin jetzt froh es durch zu haben.
Aber war schon richtig richtig schick das Teil, mal schauen was nun als nächstes kommt. Jedi Survivor ist immer noch verbuggt, daher wird es wohl Diablo 4 in der Kampagne oder evtl schon Starfield.
BG3 wird gemütlich für den Dezember Urlaub aufgespart.
Nachricht gelöscht
so ein Kabel kostet 7-10 Euro und man kann wunderbar Handys oder Geräte laden. Was soll daran so komisch sein?
das Problem ist, dass alle USB C heißen, dass es aber mit den x verschiedenen Unterarten schwer wird das richtige zu finden
zu einem akzeptablen Preis
ich hab letztens sicher 20 Minuten gesucht, bis ich ein 2m langes usb c Kabel gefunden hab, das "anständig" lädt 60w und 3.2 gen 2x2 ist ohne dabei arm zu werden...
hab dann eins um 8 Euro gefunden 8-)
aber ey... das ist fast nen unicorn
/langsam sollten wir vllt back2topic kommen...
ASUS GPU Tweak III v. 1.7.0.7 (14.11.23)
Notes:
v1.7.0.7:
.After swapping out the graphics card, the Mobile Monitor will now display data for the new card.
.Added multi-language support for the Mobile and Watermark sections.
.Fixed the issue with the external fan control not working.
.When exporting logs in the Monitor, °C will be changed to display Celsius, and °F will be changed to display Fahrenheit
.For the Matrix model, a popup will now be added when closing the program to prevent accidental data loss due to user errors.
.Fixed issues related to text overflow caused by long text strings in multiple languages.
Download über ASUS Server
Ähnliche Themen
Antworten
7K
Aufrufe
541K
