[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich lasse meinen 180er erstmal verbaut. Denke das Risiko ist minimal.
Cool, dass die dir dann tatsächlich deine Karte ersetzen im Fall der Fälle.
Also mir hat Cablemod erstmal gesagt, ich solle mich an den Händler wenden. Der hat die Karte zum Glück zurück genommen. Ob Cablemod dann ersatzweise eingesprungen wäre...keine Ahnung.
Also bei mir steckte der Cablemod Adapter zu 100% auf Anschlag drinnen, daher scheint da mehr zu sein als nur eingeklipste und verwackelte Stecker.
ist nicht schon bekannt das dieses stecker problem eigentlich nur von der unfähigkeit der menschen kommt weil diese wohl zu "dumm" sind einen stecker richtig reinzustecken ?
Davon bin ich definitv bis auf vielleicht wenige Ausnahmen (schlechter Verarbeitung) absolut überzeugt .^^
Warum haben diese Zwischenadapter einen Kühlkörper, aber der Stecker von meinem direkt angeschlossen 30€ NT-Kabel nicht?
Nun ja, im Northridge Video ist zu sehen, dass der Adapter zu 100% drinnen steckt. Bei Reddit sind genügend Fälle wo der Adapter zu 100% drinnen steckt. Mein Adapter steckte 100% drinnen.
Neben dem Problem von nicht richtig sitzenden Steckern, hat der Anschluss anscheinend noch andere Probleme.
Weil der Adapter laut Igor bis zu 75°C heiß werden kann. Vermutlich bildet der Adapter einen klitzekleinen Widerstand.
Der Voltage-Drop unter Last war mit dem Adapter auch ziemlich beachtlich. Mit meinem neuen ATX 3.0 NT und direktem Kabel von NT zur Karte habe ich nur einen Bruchteil dessen, was der Adapter an Voltage-Drop hatte.
@Capoo
Hast du noch irgendwelche Zahlen zum Voltage Drop?
12.2V Max, gedroppt bis auf 11.5V mit Adapter.
Jetzt mit neuem NT, 12.15V Max und droppt auf 12.1V
Bei 0.5V "Verlust" und sagen wir mal 40A gehen da mal eben 20W über den Adapter flöten.
Wenn man das jetzt noch weiter runterbricht, z.B. auf einen Pin der nicht richtig sitzt, dann gehen mal eben 20W über den kleinen Pin als Wärme flöten, dann muss man sich nicht wundern, wenn die Anschlüsse verschmelzen
Und warum kommt man dann auf die Idee, mit solchen Adaptern seine GPU Stromversorgung zu verschlechtern? Ich schrauben mir ja auch keine Schneeketten auf die Reifen, um damit über die Autobahn zu scheppern, nur weil die Schneeketten so schön glänzen.
Die größeren Wärmeverluste sind ja nur ne Auswirkung, von dem schlechteren elektrischen Kontakt zwischen NT und GPU. Die zusätzlichen Wärmeabstrahlung des Adapters ist der GPU ja noch relativ egal. Aber die größeren Spannungsschwankungen durch die schlechtere Verbindung zwischen NT und GPU, wirken sich auf jeden Fall auf die GPU Leistungsfähigkeit(UV,OV,OC, Wärmeverluste) aus.
Weil kein Platz im Gehäuse und darum Adapter.
Und ich hab das Ding kurz nach Release bekommen, da war auch noch nichts bekannt über den Adapter.
Den Voltage Drop hab ich mir erst angeschaut nachdem der Adapter nicht mehr entfernbar war.
Und darum bin ich jetzt bei einem ATX 3.0 NT mit passendem Kabel 😉
also ich hab mir direkt das wireview gekauft und ein hochwertiges kabel (bequit) - bei diesen ganzen kabeln die bei der gpu dabei sind hätte ich irgendwie angst die sehen auch nicht wirklich gut aus ...
Support/Garantieabwicklung = Lotterie
Aber ist wahrscheinlich fast überall so.
Du hattest eigentlich nur EVGA, die da herausstachen. Alle anderen kannste getrost in einen Topf werfen.
Edit: und NVidia selbst, meine RMA bei denen lief vorbildlich, ohne Kosten für mich und super schnell.
Will nächste Woche diese Karte bestellen:
Die wird vermutlich ebenso einen Power Adapter nutzen? Ist das noch ein Thema oder nur bei der FE von NVidia selbst?
Wie ist eigentlich so die Erfahrung beim untertakten, geht ihr da einfach auf Power Limit 350w und gut oder gibt es da noch mehr Spielraum um noch mehr Leistung/Watt raus zu kitzeln?
Auch wenn ich auch oft auf Layer 8 Probleme tippe, weil ich es aus der IT nicht anders kenne, bin ich beim 12VHPWR Stromanschluss auf Seite von Northridge. Die normalen 8 Pin Anschlüsse gibts es ja schon seit Jahren und wir hatte nie solche Probleme. Der Stromstecker darf nicht solch lockere Toleranzen haben, damit diese Situation überhaupt nicht entstehen kann.
Aus meiner Sicht ein kompletter Design Fehler von Nvidia oder PCI-SIG oder wer auch immer diesen Standard auf die Welt gebracht hat. Hersteller die eine RMA verweigern werden in Zukunft ignoriert.
LOL, diese Angebote wird's nun immer wieder geben. Keine Panik.
Hilft mir nichts. Vor nächste Woche hab ich das Geld nicht beisamen. Und ist das garantiert Neuware und keine Rückläufer?
Sollte Neuware sein.
Wie @MS1988 bereits schrieb, könntest du die Pay-Later-Funktion von PayPal nutzen. Oder du wartest halt eben, bis du das Geld zum Kauf hast. Deine persönliche Entscheidung.
Ähnliche Themen
Antworten
6K
Aufrufe
400K
