[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das ist echt richtig ätzend o_O
Ich hab bei meiner Recherche grade auch noch weitere Nachteile entdeckt bei 4K Monitoren mit 144hz+ und Displayport. Wird DSC (notwendigerweise) verwendet, gibt es durch ein Bug bei nvidia beim Alt+Tab aus Spielen im Vollbild Modus ein ätzendes Blackscreen Delay.
Noch nie gehabt. 4K 144 HZ @ Gsync Ultimate . Auch noch nichts negatives aufgefallen in Bezug auf DSC.
also die pixelstruktur auf den aktuelle QD OLED reicht für mich daheim zum surfen mehr als aus.
Ich hoffe Asus (oder Acer) bringt nochmal eine updated Version Deines Monitors. Würde den instant kaufen! Habe in den letzten 2 Jahren bestimmt 6k für Monitore ausgegeben, weil ich nie einen gefunden habe, der mir auf lange Sicht taugt. Bin es langsam Leid :(!
OLED ist ja nicht gleich OLED, es gibt meines Wissens nach derzeit drei unterschiedliche Pixelstrukturen auf dem Markt.
Aber ja, das Allheilmittel ist OLED auch nicht...
Hatte alle Varianten selbst schon da, als Coder wirst du definitiv mit keinem davon glücklich.
Vll ist es bei dir nicht wegen dem dedizierten Gsync Modul. Bei den 3 4K DSC Monitoren die ich nun da habe, ist das aber überall.
Stimme ich so nicht zu.
Ich code selber 3-4h in meiner Freizeit an meinem QD-Oled mit dark mode und mich stört das ganze genau gar nicht - ist halt subjektive Wahrnehmung und wenn man das Haar in der Suppe sucht, wird man es schon finden - egal bei welchem Display
Ja ich stimmte dir zu. So Diskussionen führen zu nix. Am Ende stellt sich wieder raus, der mit den 2 Meter Panzerglas vor den Augen sieht kein Unterschied. (Grüße an der Stelle an den Schwerhörigen mit Hörgerät der kein Spulenfiepen kennt.)
Für meine Augen jedenfalls ist der unterschied gravierend.
Da war glaube was geplant mit 2300 oder mehr Dimming Zonen und 4K 240Hz . Zumindest AUO wollte so ein Nachfolge Panel produzieren . Da hatte ich irgendwo ein Screen gesehen . Denke mit der 5090 und DP 2.XX wird da schon was kommen . Hoffe Nvidia bringt da nochmal ne aktualisierte Version des Gsync Ultimate Modul . Die Dinger funktionieren einfach und eignen sich gut für LCD . Bei Oled kann man da schon drauf pfeifen und da tut es die einfache Variante .
Das würde dann zumindest noch mal einen neuen Blick wert sein. Die Bildqualität der IPS FALD Geräte mit 1152 Dimming Zonen fand ich persönlich grauenhaft (viel zu wenig Zonen, immer noch massiver IPS Glow), zumal die doppelt so teuer sind wie ein OLED :haha:
Hätte es die geilen OLEDs doch schon früher gegeben :rolleyes2:
(schreibe gerade an meinem ollen X27 mit wahnwitzigen 3 Lüftern für nen Haufen Kohle)
Wichtig ist auf jedenfall der Dimming Algorithmus . Das steuern die dedizierten Gsync ultimate besser als die Freesync Geräte . Nachteil ist aber die Performance mit den Mini LED Geräten . Hat mit fast IPS nichts mehr zu tun . OLED bietet eigentlich das beste . Mit dem MLA Panel ist man auch auf einen guten Weg auch wegen der Helligkeit , aber hat auch paar Nachteile .
Micro LED wäre wohl das optimale zwischen Ding . Naja man nimmt was der Markt halt bietet . Monitor Markt finde ich nach wie vor recht unbefriedigend .
Zockt jmd aktuell "Division 2"?
Wieviel PL bzw Watt (avg) habt da laufen?
Oled ist für mich keine Option mit dem Pixel Layout. Primär zeige ich Texte an und die müssen knackscharf sein.
Wie jemand ein Oled als Hauptmonitor nutzen kann und daran auch surft/arbeitet etc. ist mir schleierhaft.
Och das geht schon, wenn man die einzelnen Pixel nicht mehr sieht :d
Meist sitze ich vor dem 48CX in 80-90cm Entfernung (gemessen ab Auge zu Panel) :fresse:
Der versprochene D1 Patch scheint die performance ja behoben zu haben :fresse: Not.
Nö, nach wie vor CPU Limit des Todes in dem Spiel. Das wird bei mir was fürs Sommerloch oder Weihnachten. Zumindest war es gratis. :fresse:
ea ist und bleibt einfach ein kackladen.
GPU RAM läuft voll und die Auslastung der GPU sinkt auch je länger man spielt.
Woher weiß ich denn wenn die CPU am Limit ist?
wenn die graka nicht mehr ausgelastet ist bzw., wenn du die auflösung verringerst und die fps NICHT hochgehen. das ist der beste indikator
wenn der vram das problem ist, dann sieht man das nicht so einfach aber dann hat das spiel eh andere probleme. kann ja nicht sein dass so ein kackspiel ne 4090 zur kapitulation zwingt
Naja es kann aber auch nicht sein das ich anfangs 99% GPU Auslastung habe und die dann immer weiter runter geht. Kann meiner Meinung nach kein CPU Limit sein.
Ich habe 50% PL eingestellt, damit hält die 4090 durchgehend die von mir gewünschten 122 FPS. Leider quittiert dieses - und nur dieses - Spiel jegliche Art von undervolting mit einem Absturz
das game ist mir in dx12 vor paar monaten alle paar minuten stehen geblieben. danach flogs wieder runter. ubischmutz
100% stabil war/ist The Divison 2 zwar nie, es reagiert aber massiv auf instabiles OC und Undervolting.
So, seit gestern auch endlich mein neues System mit RTX 4090 und WaKü fertig. Mit den Temperaturen bin ich stock recht zufrieden (gerne Feedback geben), Undervolting muss ich mir noch mal ansehen.
Was mich hingegen total abnervt ist das coil whine. Eigentlich sollte Zotac hier ja etwas robuster sein aber nix da. In Benchmarks wird geheult ohne Ende. Denke nicht, dass mich das in Games stören wird, genervt bin ich dennoch.
RTX 4090 in Superposition
2,8 GHz
400 Watt Leistungsaufnahme
45 °C max GPU
48 °C max Memory
RTX 4090 in Time Spy
2,8 GHz
420 Watt Leistungsaufnahme
44 °C max GPU
50 °C max Memory
PT auf 70% ziehen
Kommt noch. Werde mir noch ansehen, was wie viel Performance bringt um für mich den Sweetspot zu finden :)
das ist quick and dirty die einfachste methode und kostet vll 5 fps :d
Bei mir läuft TLOU mit ca. 90 FPS und 4k Ultra Settings.
Hey ich habe jetzt einfach mal bei TLOU noch mal neu gestartet, um zu schauen ob die FPS da anders sind und siehe da, die gehen wieder vollkommen normal hoch!
Und wenn ich nach Pittsburgh lade, geht's wieder richtig runter auf 68-75FPS 🤣 richtig asozial aber ok, ist dann wohl gebietsabhängig oder so... Anders kann ich es mir nicht erklären 🤔
Ja diese unterschiedlichen Frameraten sind schon echt komisch.
Hatte ja mal gefragt wie man am besten den Clip vom PCI-e Steckplatz löst. Hab den Plastikgriff von einer Fliegenklatsche genommen, der war schön breit und nicht so gefährlich abzurutschen :bigok:
Gibt wohl nicht viele Leute, die ihre Strix zerlegt und festgestellt haben, dass eines der langen Pads an der BP überhaupt keinen Kontakt zu irgendeinem Bauteil haben
Ich hab auch 50% PL eingestellt. Was etwa 300W avg entspricht. Zusätzliches UV ist aber völliger Quatsch, da mit der Reduzierung des PL die Spannung eh schon gut runtergezogen wird. Hab auch keine Lust auf Spannungsunterversorgung, der dann worst case im Crash endet
50% PL und gut iss ;)
Ähnliche Themen
Antworten
6K
Aufrufe
392K
