[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit B-Die (Q1)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
dann installier mal noch iCue, dann haste nur noch 13.500 Punkte. Die ganzen RGB Programme fressen viel zu viel Ressourcen.
Expo RAM bestellen wenn du nicht alles manuell machen willst
Weiß jemand aus Erfahrung mit welchen Hynix man mehr anstellen kann - A-Die oder M-Die ?
Habe hier die wie auf dem Bild, leider Made in China und dann noch welche wo nur Hynix bei HWInfo angezeigt werden mit Made in Taiwan alles beides die gleiche Marke Kingston.
Danke!
Also rausbekommen habe ich hier selbst, dass die A-Die Chips von Samsung seien sollen - kann das richtig sein ?
@Panta Rhei
Auf welcher Plattform setzt du den Ram denn ein?
Samsung hat mit Hynix A-Die oder M-Die nichts zutun. Du hast da eine Samsung DDR4 Liste verlinkt, das ist was ganz anderes.
Auf Intel würde ich aktuell eher A-Die empfehlen für einen höheren Takt und die M-Die eher für AMD für straffere Timings.
@Panta Rhei
Ah ok da siehst du das ich darin noch eine Glatze habe. Also A-die für mein Intel System, dann ist ja alles ok.
Das Bild von HW Info weiter oben steht ja - A-Die (4.1) - aber in dem Artikel von Hardwareluxx wurden doch die A-Die Samsung zugeschrieben. Vielleicht stimmt das ja auch nicht mehr weil der Artikel von 2019 ist und SK Hynix und Micron noch andere Bezeichnungen hatten.
Mmh, da schaue ich immer noch nicht so richtig durch.
Es gibt verschiedene Chip Hersteller wie zum Beispiel Samsung, Micron und Hynix. Und es gibt immer verschiedene Revisionen der Chips der einzelnen Hersteller und die heißen dann oft gleich.
So gab es bei Samsung zu DDR4 Zeiten (im von der verlinkten Artikel zu lesen) B-Die und danach dann A-Die und M-Die. Das hat aber nichts mit den aktuellen A-Dies und M-Dies bei DDR5 von Hynix zutun.
Von Micron gibt es zur Zeit aktuell auch A-Die.
Aktuell sind bei DDR5 aktuell aber nur Hynix A und M-Die relevant. Die Chips der anderen Hersteller haben weniger Potenzial.
Im ersten Post von @emissary42 von diesem Thread gibt es auch noch ein paar Infos dazu.
Ich hatte die mal da und waren A-Die. Es wird halt das drauf sein, was gerade am günstigsten zu bekommen ist.
Weil ich günstiger ein 6400er G-Skill Kit bekommen hab das auch noch wesentlich besser ging ;)
Sind angekommen
Good Morning,
do I get A-Dies with this memory or are they still M-Dies?
https://www.alternate.de/Kingston-FURY/DIMM-32-GB-DDR5-6400-Kit-Arbeitsspeicher/html/product/1857487
Some time ago I overheard that the manufacturers are switching to A-Die and that A-Die is actually always installed from 6400 onwards.
This is A-dies dual rank, 1.25v
Grüße zusammen,
da ich günstig an DDR5 kommen kann, würde ich gerne eine zweite Meinung dazu hören
Geplant ist ein 7800X3D, Asus Strix B650E- (entweder E oder F).
Es geht um folgenden Ram : 32GB Corsair Vengeance RGB grau DDR5-6000 DIMM CL30 Dual Kit (2x16GB)
An das Kit kann ich für 120Euro kommen (Neu). Das scheint mir erst einmal ein guter Preis zu sein.
Wenn ich den Thread hier ein wenig verfolge, scheinen 6000 mit CL30 auch ein guter Wert zu sein.
Ich will den Ram einfach nur einstecken, Expo laden und Freude daran haben.
Ist es hier also wichtig, welche Chips verbaut sind ? Laut Corsair können es verschiedene sein (je nach Versions-Nummer). Das finde ich wohl erst nach Erhalt des Rams raus.
Gibt es eigentlich Performance-Unterschiede in Spielen bei DDR5 zwischen 4 und 2 Slots? Hat hier jemand ggf. zuverlässige Pro und Contra Quellen?
Habe auf Youtube in Reviews mit relativ wenig Hits eher widersprüchliche Informationen dazu gefunden. Mein Einsatzzweck dafür wäre rein optischer Natur, würde aber sehr ungern FPS dadurch verlieren.
CPU: 7800x3d
MB: ASUS X670E-F
RAM: https://www.corsair.com/de/de/Kateg...-RGB-DDR5-Memory---Black/p/CMT32GX5M2X6000C30
Dürfte keine nennenswerten Unterschiede geben, war bei DDR3 und DDR4 schon so, zumindest solange man es gleich konfiguriert.
2 Slots haben den Vorteil, dass man in der Regel höheren Takt und bessere Timings erreicht, dürfte also dahingehend schneller sein.
CPU: 7800x3d
MB: ASUS X670E-F
ja logisch
4slot kann mit glück 8000mhz (eher 7600mhz)
2 slot kann 8400mhz+
mit dem richtigen board+cpu
aber da gehts um oc ...
ryzen7000 ist limitiert auf 6000-6400mhz ...
Gut, da ich nicht über 6000-6200 hinaus übertakten brauche, sollte das ja keinerlei Probleme darstellen.
Schnappt zu bevor er weg ist:
Genau die habe ich mir gekauft!
Werden die auf dem Z790-I Board laufen? Auf der ASUS Website wird unter "Speicher" bei dem Board 7.600+ angezeigt. Wenn man aber in der "Liste" des kompatiblen Speichers reinschaut ist dort leider "nur" Max 7200 vertreten.
Für AMD auch im Angebot
Was würdet ihr für einen R5 7600 eher nehmen:
oder
Oder gar 5200er ?
Finde keine Tests die belegen dass schnellerer Speicher - gerade bei den min-fps ingame - Vorteile bringt. Also Geld lieber sparen ?
Ich würde die QVL des Mobo Herstellers checken - (relativ) sicher ist man nur, wenn der Speicher offiziell unterstützt wird. Welches Mobo ist es denn?
oder
Oder gar 5200er ?
Also laut diesem Test bringt es schon etwas:
Also ich würde eher zum 6000er greifen. Aber vorher wie schon erwähnt besser in die QVL Liste schauen, ob der RAM aufgeführt ist.
Ich befürchte, ich muss den G.Skill Lot-Code der ersten Seite invalidieren.
Hab hier einen G.Skill Trident Z5, 6000C30-40-40 (2x32GB) der auf ..820M endet, aber ziemlich sicher Samsung ist, zumindest laut GIGABYTE Memory Support list.
  • mb_memory_am5_ddr5_6666_raphael (1).pdf
