[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bin da auch kaum aus dem Tutorial rausgekommen da hatte ich es schon wieder deinstalliert, schrecklich :d Aber Geschmäcker sind ja verschiedenen und ist ja prima wenn es gefällt.
Dito 😄
Musst schon den normalen Block mit dem normalen von WC vergleichen, wüsste nicht das WC bei der jetzigen Gen eine aktive Backplate hat.
Der EK kostet wie der WC nämlich auch seine 269€. Da nimmt sich keiner was.
Warum schnell? Die Lager sind voll, da geht noch ordentlich was am Preis. :d
Logischerweise hat EK auch die Preise für den normalen Block hochgezogen :) Aber mit dem Block oben sah es halt dramatischer aus :d
Hast du schon mal in den EK-Shop reingeguckt? ;)
287€ bei EK vs 240-270€ bei WC ;)
Über die Quali und Materialwahl bei EK sag ich mal besser nix :fresse:
Nur schade, dass WC immer so lange braucht. Aber immerhin viel schneller, als bei der 3090. Das war eine Katastrophe… :rolleyes2:
Gab es die Strix OC schon mal unter 2.049€?
Die Lager sind voll, weil die Taschen der Leute leer sind :d
(weil Viele nicht bereit sind 2.000€ für eine Graka auszugeben)
Finde die EK Qualität schon in Ordnung. Die sind meiner Meinung nach auch optisch meilenweit vor WC, aber das ist halt subjektiv.
Watercool braucht aber unterm Strich zu lange für alles was sie produzieren und auch dann ist die Qualität nicht immer perfekt
Die Tubes von denen leaken zum Beispiel gerne, weil der Abdichtungsring zu dünn ist - kriegst dann wenn du den Support anschreibst n neuen, dickeren Ring - wieso ist der nicht von Anfang an drauf?
Und preislich sind die auch im oberen Segment angeordnet. Wer aus Preis achtet sollte auf Alphacool oder Byksy zurückgreifen, die Temperaturen bei den Blöcken ist fast messtoleranz (1-2 Grad° GPU)
Nabend zusammen,
in Folge einer geistigen Umnachtung habe ich mir am Sonntag eine 4090er Zotac samt EKWB-Block für die WaKü gekauft. Nun stelle ich mir die Frage, ob ich beim Kühlerwechsel direkt auf Flüssigmetall umstellen sollte. Angst vor der Anwendung habe ich nicht, wenn man es richtig macht. Plan wäre Schutzlack oder Kapton auf die Komponenten um den Chip, entsprechenden Küchenschwamm zurechtschneiden, so dass dieser außerhalb der Bauteile knapp über Höhe des Chips liegt. LM drauf und fertig.
Vermutlich würde es auch ohne Schwamm als Sperre gehen, jedoch ist meine Karte horizontal eingebaut, weswegen ich mich mit einer Sperre sicherer fühlen würde.
Für mich ist aber eher die Frage: Lohnt sich LM bei einer 4090 überhaupt? Groß OC plane ich nicht, Kühler ist ein Mora 420 und die CPU eine 7800X3D, d.h. die GPU hat praktisch die ganze Kühlleistung für sich alleine ;)
Wenn du das beste vom besten willst, nur für das Gefühl: Mach es ruhig.
Lohnen tut es sich nicht, gerade wenn du - wie man es sollte - das Power Target reduzierst. Ich komm in Cyberpunk 2077 bei 3440x1440 mit path tracing nicht auf über 45 Grad, selbst wenn ich mich anstrenge (Power Target bei 75%) und hab zirka 100-120FPS (je nachdem was gerade passiert, alles auf Ultra/Psycho mit DLSS Quality + FG)
Grundsätzlich habe ich immer den Leitsatz im Kopf: Je kühler, desto mehr Takt, desto weniger Verbrauch. Daher war mein Grundgedanke bei der Frage: Macht es Sinn den die Temperatur durch LM noch weiter zu drücken um der Karte eine noch bessere Effizienz zu ermöglichen.
Leider finde ich aber im Netz kaum jmd. der sich mal wirklich sinnvoll mit dem Thema beschäftigt hat.
ich wunder mich etwas. selbst mit 100% pt säuft die 4090 bei mir nix. ist da was im eimer?
ich depp weis es glaub ich
Hängt halt hart im FPS Limit?
ne ich glaub ich lese mit dem befehl nur das aus was die karte über die kabel zieht? bin aber noch net sicher
Ja mag sein aber Elden Ring gönnt sich ja Max 60fps also würde es mich nicht wundern. Nehme mal an dass die Karte im 3D Mark alles zieht was geht?
fps sind uncapped
der screen oben war mit rt.... einfach abnormal.
Womit ist n das OSD erstellt?
afterburner overlay editor
C:\Program Files (x86)\RivaTuner Statistics Server\Plugins\Client\Overlays
da rein ohne ".txt"
ich teste mal 3d mark.
selbst bei 3440x1440 native + 120% skalierung nur 320w bei 110% pt.
  • Kevin.ovl.txt
Das Ding ist halt: Du kühlst mit Wasser deine Karte schon soweit runter, dass es keinen weiteren Sinn mehr ergibt, außer für das Gefühl.
@yilem76 hat seine Karte mit LM vollgekleistert, weiß aber nicht mehr welche temps er erreicht hat damit. Vielleicht hat er ja nen vorher und nachher mit Wasserblock?
Nabend zusammen,
Ich würde zuerst normal mit WLP montieren und die Abdrücke kontrollieren. Dazu ist der EK nicht für die beste Kühlleistung bekannt.
Quake II for NVIDIA RTX 1.7.0
Version History
1.7.0 (April 18th, 2023)
Fixed Issues:
Fixed a crash in the game logic when a monster interacts with a door in notarget mode (#92)
Fixed a crash when the map file doesn't have a VIS hunk (#223)
Fixed some Vulkan validation layer issues (#229, #246, more)
Fixed texture alignment issues on some doors (#211)
Fixed the flare gun still using ammo with dmflags including 8192 (DF_INFINITE_AMMO) (https://github.com/NVIDIA/Q2RTX/issues/)191)
Fixed Vulkan queue initialization on platforms that don't support split queues (#248)
Switched the OpenAL dependency with a statically linked library (#224)
Misc Improvements:
Added support for building on PowerPC 64 LE CPU architecture (#260)
Adjusted the automatic UI scaling to avoid making the UI too big
Improved precision of target frame rate adjustment (#242)
Tuned the full-screen blend effects to be less intensive
Updated the Loading plaque texture (#265)
Contributions by GitHub user @res2k:
Added a warning when screen-space image memory usage is very high (#179)
Added control over fallback radiance of emissive materials (#210)
Added menu controls for the full screen blend effects (#216)
Added support for spotlights with an emission profile and a player flashlight (#203, #214)
Fixed a crash when some textures are missing (#263)
Fixed an overflow condition when pt_bsp_sky_lights is more than 1 (#262)
Fixed animated textures on BSP models (#187)
Fixed crashes when renderer initialization fails (#199)
Fixed FSR image scaling in some cases (#232)
Fixed incorrect scaling of textures without a custom material definition (#235)
Fixed mode setting on Linux in GitGub CI builds (#268)
Fixed save game compatibility with Q2RTX 1.5.0 (#193)
Fixed some issues with lighting in custom maps (#189)
Fixed texture data size computation for R16_UNORM textures (#236)
Fixed the HDR screenshot feature (#190)
Fixed the look of smoke effects (#195)
Fixed the range of animated light intensities (#200)
Fixed the replacement textures when multiple materials are used with the same base texture (#222)
Improved light list handling to fix excessive flicker and noise (#234)
Improved material system robustness for games with custom textures (#201)
Improved polygonal light sampling to reduce noise and darkening (#266)
Improved Wayland support (#261, #221)
Integrated several fixes from Q2PRO (#196)
Replaced the single sky_clusters.txt file with per-map files (#219)
Tweaked particles to have more nuanced colors (#197)
Updated SDL2 to 2.26.1 (#252)
https://www.techpowerup.com/download/quake-ii-for-nvidia-rtx/#changes-1-7-0
Wenn du kein Benchmarking betreibst, lohnt es sich nicht...
Und die paar Grad, die du mit LM weniger hast, senken bei dem engen Temperaturfenster die Aufnahmeleistung so gut wie garnicht.
gebraucht oder bei Privat schon :d
Nur neu und kein Rückläufer ;)
Ja, das habe ich leider schon gesehen. Jedoch kommt Watercool ja nicht in die Pötte und ich habe keinen Bock den ASUS Aufpreis für TUF oder Strix zu zahlen, da die aktuell noch über 2k kosten wenn man nur verfügbare Karten betrachtet.
Ich werde beim EKWB-Block die Wärmeleitpads austauschen, vermutlich gegen Gelid. Und dann muss der Block halt reichen. Von AC kommt ja nix und die ALC-Blöcke will ich aus Gründen der Optik und der Firma (persönliche Abneigung) nicht kaufen.
ich hab nen Bykski Block auf meiner TUF, wie so viele andere auch. Wobei ich auch mind. 1 persönlich kenne der seinen 4090 Strix EKWB-Block nicht hergeben würde und er hat ihn von Anfang an, aber auch mit anderen Pads.
Davon ab sind die WC Blöcke auf dem selbem Leistungsniveau wie die EKWB Blöcke, da wäre maximal die Optik ein Grund zu warten
Von Watercool wird auch für die Zotac nix kommen. Das Thema ist durch.
Reichen wird der Block in jedem Fall. Ein Paar Grad sind wirklich egal. Aber es zeichnet sich etwas ab, dass der EK etwas schlechter ist als die anderen Blöcke. Spielt aber keine Rolle.
Ähnliche Themen
