[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Waren nicht 860 mv das niedrigste was funktioniert?
Hab das irgendwie noch im Hinterkopf vom release.
Edit : hier fallen immer wieder 875mv.
Ja, bei mir sind es auch immer 875-880mV, die überhaupt möglich sind. Wird wohl der Durchschnitt sein.
Jo und ich dachte schon ich wäre wieder zu doof :fresse:
Hab jetzt erstmal 2500@860mV eingestellt.
Könnte mit dem Takt bestimmt noch höher gehen. Aber das werde ich nochmal testen wenn Zeit ist :)
Haben ja die gleiche Karte wie ich sehe.
Viel Spaß! :))
Bei mir ging nicht mehr groß höher als 2535Mhz, was auch der Standarttakt ist meine ich.
Ja 2535Mhz ist Standard bei der Karte. Hat deine Karte eigentlich Coil Whining?
Zum Glück einfach mal gar nicht 🙏 🎉
Ich müsste so richtig das Ohr an die GPU halten und selbst dann ist es minimal hörbar.
Bei dir etwa deutlich?
Die Gaming OC soll ja eigentlich mit die leistete sein, was das Spulenfiepen angeht. 😳
Ich höre bei mir so gut wie gar nichts. Ist auch Super leise. PC steht direkt neben mir.
War jetzt etwas neugierig 875mv laufen schon mal alle 3DMark Benchmarks bei 2550Mhz durch.
Das ist doch super!
Wozu auch mehr für Strom zahlen, wenn man sparen kann und dadurch kaum bis wenig Leistung verliert =))
Das ist doch super!
Dieses Undervolting per Kurve ist bei den Ada Lovelace Karten aber nicht mehr so interessant wie z.B. vorher bei Ampere. Wenn du magst, versuch doch mal deinen max OC für GPU und Vram rauszufinden und begrenz dann die Spitzen mit dem Powerlimit. So hast du sehr viel Leistung und Takt bis 3 Ghz und einen geringen maximalen Verbrauch. Mit max. 350 Watt kommt eine 4090 prima klar.
Wireview nun bei bei Caseking verfügbar, Freiwillige vor :d
Naja, zumindest weiß man, wie "WireView" aussieht. Mehr als 30€ für das Ding wären jedoch überzogen
man kennt doch die clown preise :d
Wenn sogar deren Contakt - Frame von TG 40€ kostet, das Äquivalent von Thermaltake nur schmale 13€, dann vermute ich mal, dass für das Teil mindestens 99,90€ aufgerufen werden ^^
nicht ganz :d
@Youngtimer
Muss ich mal ausprobieren 🤔 wobei ich das mit dem Powerlimit auf 70% stellen getestet und jetzt nicht sehr begeistert war. Fand die Leistung pi x 👍 wie beim Undervolting.
Über 250 Watt Verbrauch zu gehen war für mich seit dem Kauf eigentlich tabu und ich war froh, dass es möglich ist drunter zu bleiben. Wobei ja 350 Watt jetzt nicht die Welt wären für ein paar Std zocken... Aber ob sich das lohnt ist die frage, da ich nur in 4k bis 115 FPS cap spiele habe ich in allen Games eine top Leistung von 90-115 FPS bei 120Hz und habe keinen zu üblen Stromverbrauch.
Muss mal wieder mit dem Stromzähler ran und schauen, wie viel es insgesamt sind zB bei The Last of Us Part 1 müssten es an die 600 Watt sein.
Danke für die Anmerkung! :)
Heute Atmic Hearts durchgespielt, was für eine Freude das Game ist, es strotzt ja nur so vor neuen und extrem einfallsreichen Ideen! Und prächtig sieht es dazu auch noch aus, leider wurde ja bis heute immer noch kein Raytracing nachgeliefert.
Trotzdem eine absolute Empfehlung das Spiel, hat einfach irre viel Spaß gemacht es durchzuspielen (habe es auch original russisch mit Untertiteln gespielt, da kommßs nochmal viel besser rüber)
PS: Und welcher Idiot das Spiel als Russland-Verherrlichung dargestellt hat ist meiner Meinung nach ein Idiot und/oder hat das Game nicht zu Ende gespielt, Russland wird am Ende des Spiels absolut nicht gut dargestellt, mal ganz glimpflich ausgedrückt....
Hab das abgebrochen, der nervige Hauptcharakter macht es komplett unerträglich imho… Dialoge wie von nem 13-Jährigen geschrieben.
Auf Russisch hat der eine sehr erwachsene Stimme und kommt auch so rüber.
Heute Atmic Hearts durchgespielt, was für eine Freude das Game ist, es strotzt ja nur so vor neuen und extrem einfallsreichen Ideen! Und prächtig sieht es dazu auch noch aus, leider wurde ja bei heute immer noch kein Raytracing nachgeliefert.
Ich als jemand, der russische, ukrainische und deutsche Wurzeln hat, hab auch richtig Bock auf das Game aber kam noch nicht dazu und wollte erst mal alle Updates abwarten. Danke für den Bericht! Steht auf jeden Fall auf meiner Liste.
Finde es ansonsten korrekt was du sagst und dass man auch einfach solche Sachen mal raushalten sollte.
Es gibt genug games, wo man als Amerikaner andere Staaten niedermäht und es feiert aber dass das auf die Realität übertragen genau so beschissen ist, das sagt keiner. Aber würde Russland mal alles niedermähen, wäre es plötzlich das schlimmste Spiel überhaupt 😂
Deshalb, was das angeht, es ist nur ein scheiß Spiel und man sollte es auch eher neutral behandeln, denn es ist fiktiv und nicht real, auch wenn es eine reale Vergangenheit darstellt oder sonstiges.
Die Preise von EK werden immer dreister... :oops:
Und den Signature-Block scheint ausverkauft zu sein...
So langsam spinnen die wirklich, dachte ich hätte schon zu viel bezahl für meinen Block, leider konnte Bykski damals nicht liefern. Deshalb musste ich was von EK nehmen.
Allgemein finde ich die Preise >200€ abartig.
Die 160€ für den Aurora waren für mich Kotzgrenze.
Abnormal wie die jeweiligen Preise sämtlicher Komponenten in den letzten Jahren gestiegen sind.
Was für ein geiles Teil 😲🤤💦
Schnell - Strix OC für 2.049€... :wink:
Das ist doch die Variante mit aktiver Backplate (sinnlos), die normale ist "nur" 30€ teurer geworden.
"Nur"...?
Das sind auch fast 300€ für - naja - keine Spitzenleistung (dann eher den WC-Block)
Mein EK Direct-Die-Block ist von 200€ auf 215€ gestiegen :oops:
Hab ich auch nur gekauft, weil der so schön ins "Quadrat" vom Apex passt
Ich wünsche EKWB mal einen fetten Umsatzeinbruch, damit die mal wieder normal im Kopf werden
(aber eher friert die Hölle zu)
Nachricht gelöscht
Fand das Game auch unerträglich. Auch völlig egal welche Sprache man eingestellt hat. Konnte mich wenn dann nur grafisch überzeugen. Nach 5 Stunden oder so hatte ich keinen Bock mehr.
Bin da auch kaum aus dem Tutorial rausgekommen da hatte ich es schon wieder deinstalliert, schrecklich :d Aber Geschmäcker sind ja verschiedenen und ist ja prima wenn es gefällt.
Ähnliche Themen
