[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So gesehen wäre mir VIEL lieber, wenn die den GPU Gen Interval auf 3 oder gar 4 Jahre hochsetzen würden!
Finde 2 Jahre sind einfach nichts für eine GPU Gen und erst am Ende der Gen werden die GPU's erst durch die Treiber so richtig ausgereizt, oder sogar noch viel später.
Ja immer der Zwang das beste zu haben macht unsere Taschen leerer
Zumal man aus Erfahrung ja immer davon ausgehen kann, dass viele der beliebtesten AAA Titel auch ihr Jahr oder gar länger benötigen um bestmöglich optimiert auf dem PC zu laufen 😆
Von mir aus kann alle 6 Monate ne neue GPU Gen kommen, musst ja nicht immer das neuste kaufen. XD
Der Drang ist dann aber echt stark und lässt einem keine Ruhe, kennst doch bestimmt 🙊😆
Das ist dann aber Dein Problem und nicht das der Hersteller. ;)
Nur sich dann halt bitte nicht über die Preise beschweren.
Es ist ja auch so das man in 4K sehr viel GPU Leistung Benötigt.
Ohne DLSS wird es nicht selten schwer hohe FPS zu bekommen wen man die Regler immer gerne möglichst nach rechts schiebt.
TLOU zeigt das auch wieder das DLSS nötig ist wenn man im 100FPS +Bereich spielen will.
Aber im Allgemeinen war die 4090 ein wirklich großer Sprung ob das bei der 5090 wieder so sein wird muss man dann später mal sehen der Schritt könnte dieses mal wieder kleiner ausfallen.
Der Sprung von der 3090 im Samsung 8nm Verfahren auf die optimierte TSMC 5 Nm( 4Nm NV Optipmized ) war das sehr groß bei der 4090.
An wen war das gerichtet?
Sind genau meine Worte, wenn sich manche Leute immer nur den ganzen Tag über die Preise beschweren können.
Einfach nicht kaufen, wenns nicht passt.
Was ja auch keine Schande ist DLSS zu verwenden. Ich verwende es sehr gerne in TLOU, obwohl ich auch nativ mit 80-90 FPS bestens leben könnte.
Es verbessert/vervollständigt die Details noch weiter vs nativem 4k und ansonsten konnte ich praktisch keinen Unterschied feststellen.
Mehr FPS bei gleichzeitig geringerem Stromverbrauch. Klasse!
Jup gerade bei TLOU wirkt es sogar etwas schärfer als Native und sieht sogar etwas besser aus.
Bin auf die Anforderungen von Stalker 2 gespannt mit der UE5 Engine ich glaub da wird die gut kämpfen die 4090 .
Allerdings, ich auch!
Denke aber, wenn die das Game vernünftig wie zB Doom Eternal optimieren sollte das sehr gut laufen. Auch TLOU könnte noch so viel besser laufen, wenn es besser optimiert wäre. Denke aber ist alles nur eine Frage der Zeit.
Am meisten freue ich mich als ein langjähriger Tekken Veteran auf Tekken 8, soll ja auch in UE5 sein soweit ich weiß. Die regelmäßig hochgeladenen Gameplay Videos zur Vorstellung der einzelnen Kämpfer sehen definitiv extrem vielversprechend aus.
Man kann mit einer 4090 auf jedenfall ordentlich die aktuellen Games zocken in Verbindung mit einer starken CPU .
Damals mit 3090 lief CP 2077 , Control, Guardians of the Galaxy , Dying Light 2 , Farcry 6 , Halo Infinite , BF 2042 relativ bescheiden dagegen .
Hier dieser Generationssprung war auch mal nötig gewesen für 4K Gaming und macht auch spaß . Klar DLSS muss bei RT Games mit rein und FG braucht man für CP 2077 und Darktide ,
aber es funktioniert hier auch gut . Also kann mich bisher nicht beschweren über die Leistung aktuell. Bei der 2080 TI und 3090 war die Gaming Performance sehr früh teils noch nicht zufriedenstellend.
Hier mit dieser Generation habe ich es Grundsätzlich nicht das Gefühl . Geht alles sehr gut . Gibt auch viele Games wo ne 4090 mit 250-300 Watt relativ entspannt läuft dank DLSS.
Gerade BF 2042 und Deadspace Remake , wenn einem RTAO nicht so wichtig ist total entspannt und im FPS limit mit DLSS Qualität @ 4K .
Dying Light 2 mit RT und DLSS Qualität auch ohne FG schön im 100 FPS Bereich .
@MS1988
Haste recht!
So gesehen ist der Traum vom flüssigen 4k Gaming endlich für viele wahr geworden und funktioniert insgesamt sehr gut, wenn man alle Kriterien miteinbezieht. Da bleiben eigentlich keine Wünsche mehr offen und mittlerweile ist der Preis von unter 1700€ bei einigen Modellen ja nun wirklich okay angesichts der heutigen insgesamt teueren Zeiten. Eine neue RTX 4090 zur UVP von 1600€ ist ja schon fast ein Träumchen, das womöglich bald wahr werden könnte und bei der starken Performance wäre das ein exzellenter Preis.
Fall jemand noch seine AM4 CPU aufrüsten will:
Unter 300€ ist inzwischen echt ne Ansage 👍
Werde ich wohl meinem besten Kumpel im Sommer besorgen und zum Geburtstag schenken und ENDLICH seinen verkackten R5 3600X kicken 😆
Die Gerüchte gehen eher dahin dass der Sprung diesmal wieder so hoch bzw. wenn nicht noch größer ausfallen wird.
@Gurkengraeber
So ein Leistungssprung ist natürlich immer zu begrüßen aber sollte erstmal mit Vorsicht genossen und eher angezweifelt werden, da die Leaker eher für einen übertriebenen Hype sorgen um mehr Aufmerksamkeit und Klicks zu generieren (trifft natürlich nicht auf alle zu, es gibt auch die eher zuverlässigeren von denen, denen man durchaus Glauben schenken kann).
Solange Nvidia nicht selbst handfeste Infos zur Leistung und Leistungssteigerung vs RTX 4000 liefert, Ruhe bewahren.
LoL, Ruhe bewahren? Wo war mein Post denn unruhig?
Natürlich sagt ein Gerücht, besonders so früh erstmal nichts aus. Aber es ist nun mal da, daher hatte ich es geschrieben.
Bei Lovelace war es übrigens anders herum. Niemand hat diesen Leistungssprung bei dieser extremen Effizienz erwartet. Also das darf dann gerne wieder passieren. :d
Fühle dich doch nicht direkt angegriffen. Meine es im Allgemeinen, um sich da nicht unnötig auf etwas zu freuen und am Ende eher ernüchternd oder gar enttäuscht zu sein, meine nicht dich persönlich, weiß ja nicht mit welchen Emotionen du so dazu persönlich stehst.
Meist ist es ja so, dass die Sachen, die eher übertrieben gehyped werden, wie das bei AMD sehr oft der Fall war, eher mäßig oder gar als Flop ausfallen und wie du eben auch so schön gesagt hast viel besser als erwartet im Falle der RTX 4000er.
Klar defintiv, begrüße ich wie bereits erwähnt auch und drücke denen fest die Daumen, dass das wieder so gut klappt mit der Umsetzung. Zu mal sich Blackwell 🖤 viel besser anhört als Ada Lovelace 😆
Der Samsung Prozzes 8nm schien ja Recht ungünstig zu sein für richtig hohe Taktraten.
Daher hat man allein hier 1 GHZ an Takt zu gelegt.
Das konnte man ja bei HD6900XT Serie sehen die schon 2,5 GhZ angekommen ist mit 7nm TSmC und mit OC bis 2,8 +-.
Mit der 7900XT würde es jetzt mit 5nm kaum mehr als bei 7nm TSmC .
Jetzt von TSmC 5/4nm auf TSmC 3nm ist halt die Frage um wieviel die Taktraten noch steigen werden vielleicht gehen da noch Mal 200 MHz mehr man weiß es halt nicht genau.
Ich bin da er verhaltener und tippe Mal bei der ersten grossen Karte ca 45 %+ -also 4090-5090.
So kann man nicht enttäuscht werden.
Da zu gibt es noch zu wenig Infos für die 5000ner Serie eigentlich gar keine .
Gruß an euch alle.
@Thunderburne
Wäre sogar über eine Leistungssteigerung von 30-40% bei gleichzeitig 20-30% besserer Effizienz sehr erstaunt. Man darf da aber auch vor allem auf die Verbesserung in Sachen Raytracing und Path Tracing gesapnnt sein und es sollen ja auch glaube die ersten Nvidia GPU's im MCM Design werden. Da bin ich auf die Umsetzung hochgespannt und bin eigentlich relativ zuversichtlich, dass die das besser hinbekommen als AMD mit dieser Generation bei den RX 7000ern.
Würde ich mir auch wünschen. Wird wahrscheinlich aber nicht passieren
Oida! Die Palit GameRock gibt es aktuell für 1.669 Euro im MindStar.
neuer lian li strimer :)
Wieso nicht einfach bei Kleinanzeigen eine ab 1400€ holen... Die Chance stehen zwar hoch, dass die geklaut sind wenn die neu & ohne Rechnung sind aber who cares. Gibt ansonsten auch relativ gute Angebote mit Rechnung und noch relativ "neu".
Würde immer zu erst nach gebrauchten oder neu und billig schauen als überteuert bei Händlern. Wobei ja 1700€ für die Karten schon echt gut ist.
Spreche aus Erfahrung und das bei mehr als 3 mal.
Würde immer zu erst nach gebrauchten oder neu und billig schauen als überteuert bei Händlern. Wobei ja 1700€ für die Karten schon echt gut ist :)
Und wenn die gpu defekt geht hast du nur Probleme :) risiko beim kauf inklusive
Wieso sollte sie, wenn sie frisch verpackt ist? Ansonsten bringst PC mit kaufst und testest direkt vor Ort, wenn die Unsicherheit so groß ist! Ist die gebraucht, wird sie wohl vor Ort getestet werden können. Wenn nicht, weiß man direkt, da ist etwas faul.
Hatte sogar eine 1300€ teuere und bereits Monate lang genutzte Asus Rog Strix RX 6900 XT LC Top Edition komplett übers Internet gekauft, hab per Video call vorführen lassen und ohne Probleme mit privatem Kaufvertrag gekauft, selbst ausgiebig problemlos genutzt und für 1000€ weiter verkauft. Die Karte hatte noch Garantie insgesamt 3 Jahre und nach mir noch 2.
Wenn es eine recht teuere Karte ist würde ich persönlich nur mit Garantie und Kaufvertrag kaufen sodass man im. Fall der Fälle umtauschen kann über den erst Käufer, zu dem man dann auch selbstverständlich nach dem. Kauf Kontakt haben sollte.
Wenn man will, findet man Wege, wenn man nicht will, findet man Gründe.
Es gibt auch gpus die anscheinend neu verpackt defekt sind oder innerhalb von 0-4 Jahren defekt gehen und als 2 Käufer läuft die rma Abwicklung nicht immer gut. Aber wenn du noch keine schlechten Erfahrungen gemacht hast ist dies ja in Ordnung
Es gibt auch gpus die anscheinend neu verpackt defekt sind oder innerhalb von 3-4 Jahren defekt gehen und als 2 Käufer läuft die rma Abwicklung nicht immer gut. Aber wenn du noch keine schlechten Erfahrungen gemacht hast ist dies ja in Ordnung
Sicher es kann immer was passieren, hast recht. Wie oft sind auch mal nagel neue GPU's defekt und müssen eingetauscht werden oder haben unerträglich lautes Spulenfiepen...
Da ist eine gebrauchte mit Garantie, die man mal eben beim Verkäufer ausgiebig testen kann oft viel besser.
Na, dass da ein zweiter Käufer dran war müssen die ja nicht wissen. Das würde die Sache natürlich unnötig schwieriger machen.
einmal in farbe
Ähnliche Themen
Antworten
6K
Aufrufe
409K
