[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Eventuell den Desktop mal auf 120hz runterschrauben. Du hast den Treiber ja so eingestellt das er in Games die Graka voll ausfährt und am Desktop "nur" 120hz tut nicht weh.
Ja das hab ich so gemacht und war die Lösung. :)
Die Diablo Beta haut ordentlich rein beim RAM um die 21,5 GB in 4K.
Wen man die Auflösung intern auf 125% setzt teils 22,7GB und immer noch meine 120 FPS.
Läuft aber echt super .
D4 haut immer den VRAM voll soweit ich das gelesen habe. Ist eher ein Bug. Man kann das Game auch mit einer 3080 Ti problemlos in 4K zocken
Die RTX 4070 Ti/12G bekommt selbst in WQHD mit dem optionalen HD-Content Probleme, knapper Hauptspeicher verschärft das Problem nochmals. Oft zu sehen sind obendrein verspätet nachladende Texturen,
Vielleicht wurde jetzt zur Open Beta bisschen was verbessert da hab ich jetzt noch keinen Test oder Sowas gesehen.
Kann ich nicht sagen ob da jetzt was verbessert wurde. Habe heute mit einem Kollegen gespielt der halt ne 3080 Ti hat und er meinte er spielt auf 4K max mit 100+ fps
Es ging mir ja nicht um die FPS .
Die 4070Ti hat ja auch 12GB wie die 3080TI und das das schon bei WQHD so sein soll verwundert schon.
bei mir startet das Spiel in 4K mit ca 18,5GB. und geht dann mit der Zeit so auf ca 21,8 und verändert sich nicht mehr .
Es kam ja auch ein neuer Treiber der D4 unterstützt vielleicht hat der ja Abhilfe geschaffen das es zu extrem wird.
Die 4070Ti hat ja auch 12GB wie die 3080TI.
Ja schon klar. Ging mir darum, dass er keine Probleme mit extremen Rucklern hatte wegen vollem VRAM und wohl konstante FPS hat. Ein paar Ruckler hat man aber immer, auch mit 4090. Wobei es schwer zu sagen ist ob Server oder Client laggt in den Momenten. Werden sie sicher noch verbessern.
gestern den Kühler der Manli demontiert....WTF, da sind 3 Schrauben die sind beschissen, die unterm E und unter der bescheuerten Wasserwaage. Man kommt dort praktisch nicht hin, weil man den Schraubenzieher schräg ansetzen muss, aber so schräg, dass man nicht mehr schrauben kann. Evtl. gibt es für sowas gewinkelte Schraubenzieher oder so, habe ich jedenfalls nicht. Fragt nicht wie ich sie runter bekommen habe...zurückbauen ist nicht mehr :sneaky:
Der EK Block für die Zotacs passt aber gut auf die Manli....
Gibt es eigentlich ein anderes IO bracket zum nachrüsten 2 Slots?
Für was braucht man die Libelle in ner Grafikkarte? :fresse:
*edit*
Wenn du die Schraube an der Libelle links und rechts löst, kannst du dann nicht die Blende mit der Schrift abmachen und kommst dann an die Schrauben darunter ran?
Mal eine Frage an die Experten hier bezüglich be quiet netzteil und Kabel für eine 4090 FE.
bequiet! Pure Power 12 M 750W ATX 3.0 hat ja bereits ab Werk dieses 600 Watt Kabel womit man keinen Adapter mehr benötigt. Passt dieses Kabel auch an ein Straight Power 11 Platinum 850W?
Oder geht das nicht bzw passt die Pinbelegung irgendwie nicht?
Generell würde mich interessieren ob das genannte beiliegende Kabel an allen modernen aktuellen be quiet netzteilen also z.b auch der dark Power Serie passt?
falls du das Kabel BC072 meinst, das benutze ich an einem straight power 11 750W
Ehrlich gesagt habe ich keine Ahnung wie das Kabel heißt. Steht das irgendwo? Ist wie gesagt das Kabel vom purepower 12
Wenn man nach der Bezeichnung schaut dann steht zumindest in der Kompatibilität drin dass es für alle netzteilserien passt:
*edit*
hatte dann gestern aus Verzweiflung mit jemand hier im Forum geschrieben der auch die Manli hat, beim Umbau stand er auch vor dem gleichen Problem...geht scheinbar nicht anders, wie gesagt...evtl. mit speziellen Werkezug oder so...als alle Schrauben unten waren, ist der Kühler immer noch bombenfest gesessen, mit etwas Gewalt :cautious: konnte ich ihn dann lösen (hat mich an den 3090er Umbau erinnert...)
Hey zusammen, ist ein Riesen Thread, versuche mich ein wenig durch zu forsten.
Habe seit ca. einer Woche eine PNY 4090 XLR am laufen.
Läuft bei mir mit +160Mhz Core und +500Mhz RAM.
Toll ist, kein Spulenfiepen. 😎
PL ist bei 90%
Weis nur nicht ob die Einstellungen Sinn machen, steige bei der 4090 noch nicht ganz durch.
Früher habe ich meine Karten einfach undervoltet, scheint ja bei der 4er Serie nicht so Sinnvoll zu sein. Die alte 3080Ti lief mit 0,85V und +200Mhz, hatte mehr Power als Stock und weniger Verbrauch.
Ich habe das Kabel separat von bequiet gekauft
Ich habe das Kabel gekauft und an ein Dark Power 11 pro 750 angeschlossen
*edit*
Anders wird es nicht gehen - die Schrauben an der Libelle sind sicher keine Zierde... :fresse:
Ich glaube kaum, dass der Kühler mit abgewinkeltem Werkzeug montiert wurde
Hab gerade Lust meine Strix auf Wasser umzubauen...
Das markierte WLPad an der BP hatte anscheinend null Kontakt zum PCB :rolleyes2:
Das breitere Pad aber schon. Ist/war das bei euch auch?
Beide Pads sind gleich dick. Bei dem breiten Pad sind die Bauteile ~2mm hoch
Das schmale Pad kühlt nur Luft (haben keinen Abdruck im Pad)...
K.A. ob das so angedacht ist, aber genau in diesem Bereich befinden sich 12 Elkos gegenüber
Hab die BP so positioniert, dass das eine Loch mit dem Loch auf dem PCB übereinstimmt
(nur die zwei hinteren Löcher unten "passen" nicht. Was der perspektivischen Verzerrung geschuldet ist)
Kranker Scheiss...
Konnte meinen alten Score vom Feb, mit der TUF @EVC2 gleich drei weitere Male erreichen :fresse:
Alles noch ohne EVC2 und mit Kryonaut Extreme statt Conductonaut @ 15°C Wasser
demnächst wird das Trennen sowieso weniger, da verliert das etwas an Bedeutung :hust:
Dafür vergisst man es da aber auch schneller mal, vermute ich mal so 🤐
Bei mir hoffentlich auch irgendwann...
Im Moment sind die Dinger super hilfreich.
Ganz davon weg will ich aber nicht. Die QDs könnten an CPU und GPU weg (nur Schläuche dran mit QDs am Ende)
Das QD-Handling an der GPU find ich nicht so toll, weil das Trennen einen heftigen Ruck verursacht
hast Du die direkt mit G1/4?
ich hatte (gebraucht) 10 Paar mit 16/10 bekommen, da ist eher das Gewicht das Problem, aber sie sind halt nirgendwo fest verbaut und drücken auf nichts (ziehen aber dafür)
Hab 6 "Männer" @1/4" und 6 "Frauen" @ 13mm x 16mm (1/2in x 5/8in)
Hatte erst 10mm x 16mm (3/8in x 5/8in) probiert, aber bei Zug oder seitlichem Druck/Zug lösen sich die Schäuche nach und nach (kann Tage dauern)
Und das, obwohl die zwei "scharfen" Ringe an der Tülle dicker sind (12,2mm), als das Innenmaß, der ZMT 16/12 (16,1mm/11,1mm)
Nachteil der 13mm x 16mm (1/2in x 5/8in) ist, dass man den Ring nur mit enormer Kraft über den Wulst am Schlauch, aufs Gewinde bekommt (14,5mm statt 12,2mm Tülle)
Drehen von Hand kann man leider auch vergessen. Hab ich mit 2 Gabelschlüssel gemacht. Da geht nichts mehr ab :d
btw:
Hängen die Weibchen nur oder hattest du mal Undichtigkeiten?
Die O-Ringe der Jungs kann man zum Glück ja tauschen
Jemand zufällig vor kurzem bei Watercool nachgefragt wann die Asus Blöcke für die 4090er kommen?
Hab die BP so positioniert, dass ddas eine Loch mit dem PCB übereinstimmen
Niemand?
Würde mich auch interessieren. Konnte endlich eine 4090 TUF zur UVP (CHF 1600.-) ergattern und würde lieber bei Watercool als ALC und EKW einkaufen. :)
Ähnliche Themen
Antworten
7K
Aufrufe
528K
