[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei den Deutschen kann man das auch machen denken die sich ^^
Haben die auch fleißig versucht, bis auf einmal die Zusammenarbeit mit Klarna eingestellt worden ist. Da hat Klarna leider nicht zugunsten Proshop entschieden. Konstruierte Gebrauchsspuren würde die Staatsanwaltschaft bei einer natürlichen Person gleich als Be.t.ru.g werten. Seit wann werden hier einfache Begriffe wie Be.t.ru.g zensiert? Das Forum wird hier auch immer erbärmlicher, schon mal was von Meinungsfreiheit gehört?
Graka umgebaut, aber Temperaturen sind viel zu hoch.
Nochmal Wasser ablassen und schauen woran es liegt:unsure::hmm:
@yilem76
wenn Du öfter an Deiner GPU baust würde ich wohl einfach 2 Absperrhähne an der Distro verbauen und mir dann noch etwas einfallen lassen um die GPU einzeln zu entlüften, so ziehst Du Dir nicht unnötig Luft in den restlichen Kreislauf.
Aber krasse Optik :hail: ,
nur die unterste Tube passt so garnicht zu den anderen Parallelen. Da würde ich wohl auch noch 2 Bögen am Heck verbauen und die Tube auch parallelisieren :fresse2: .
Achso und eine satinierte und die restlichen klar. War noch ein Rest oder hat das eine Bedeutung?
@yilem76
Ist noch nicht ganz fertig, mir war von vorneherein klar daß irgendwas nicht passen wird, deswegen nur mal provisorisch zusammen gebaut👍
Powerlimit auf 600W und Spannung auf 1,1V?
Da kann das Delta beim EK-Kühler schon recht groß ausfallen.
80° bei Wakü alles auf Stock ist schon verdammt hoch, da passt irgendwas nicht 😁
Ein Delta von 80 Grad ist wirklich katastrophal, da schein kein kaum Kontakt zum Die zu bestehen, zumal du ja auch LM verwendest, oder?
sollte er mal checken wie krumm sein Die ist.
sobald es zu krumm ist, ist LM eher suboptimal, dadurch das WLP nicht ganz so dünnflüssig ist, kann sie diese Spalten besser überbrücken.
LM noch nicht, kommt aber noch😁
Ich denke die Pads sind viel zu dick wo dabei waren, LM und die 1mm Pads von Gelid dann sollte es passen.
Hinten hab ich Kupplungen, muss nicht jedesmal komplett ablassen.
geht ja darum dass Du nicht jedes Mal die Distro und den Rest im Case entleeren und entlüften musst, in dem Fall ist nicht der Mora gemeint
Für den Fall dass Du öfter die GPU wechselst, oder eben jetzt für die Erstinstallation (mit Ungereimtheiten)
Bei Hardtubes geht's leider nicht, ich wüsste jetzt nicht wie ich daß machen könnte.
Irgendwie auffällig, dass einige nach dem Umbau auf Wakü zu hohe Temps haben:unsure:…mein EK Block kommt in den nächsten 1-2 Tagen…hoffe das geht reibungslos…nervt mich, wenn ich mehr oder weniger unnütz wieder aus und einbauen muss…
Ist das normal das die Backplate eine Wölbung hat , auch das PCB etwas verbogen wird ?
Vorne bei der Blende is es am schlimmsten.
Vielleicht auch nur wegen Thermal Pads & anpressdruck .
Ne ist nicht normal, ist die Karte neu oder gebraucht erworben worden, möglicherweise war die Karte schon mal auf Wasser umgebaut!?
Kann mir einer sagen, ob irgendeiner dieses Gehäuse hat und ob da eine Eiswolf 2 in die Front passt von der Schlauchlänge haben die 42 cm ich finde das irgendwie keine Information
Lg
Lg
Habe das gleiche Gehäuse und die Eiswolf 2 seitlich montiert. Ist aber auch in der Front kein Problem.
Von welchem Hersteller ist die Karte?
tippe auf Palit Game Rock! Dann wäre es normal :LOL:
Ähnliche Themen
Antworten
7K
Aufrufe
528K
