[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das verstehen Manche (auch das HWluxx-Team) irgendwie nicht und beharren steif und fest auf "ihren" (einzig wahren) 720p-Bench mit ungünstigen RAMs, die CPUs etwas einbremst
Wenn die dann noch patzig und persönlich werden, weiß man schnell, wie es um den Charakter bestimmt ist. K.A. was mit Manchen los ist... :rolleyes2:
Mit 720p habe ich kein Problem. Es soll schon im CPU-Limit getestet werden (wir wollen ja CPU-Leistung testen). Wegen mir können sie auch in 480p benchen. Sind ja letztendlich nur Werte/Abstände. Ich will das Ganze aber halt mit maximal niedriger Latenz und maximal möglicher Bandbreite beim RAM auf der jeweiligen Platform sehen. Das ist mein Knackpunkt. Was da oft fabriziert wird ist nichts Halbes und nichts Ganzes. Bei AMD macht es halt weniger aus als bei Intel, weil der Cache einfach viel "kaschiert".
Mein Gedanke ist halt auch, dass ein monolithischer Die, wie er bei Raptor Lake noch vorhanden ist, dem Chiplet-Ansatz bei AMD überlegen ist. Das Ganze wird sichtbar werden, wenn beide Platformen komplett "ausgequetscht" werden. Dafür braucht es aber halt ein wenig mehr als DDR5-7200 & XMP. Ich sehe aber auch ein, dass die Tester nur begrenzt Zeit haben und das mein Wunsch eher unrealistisch ist.
guckt doch einfach in den ram oc foren was dort dann erreicht wird.
da tüfteln die junge teilweise tagelange oder wochenlang rum bis sie das maximal mögliche raushaben. so viel zeit haben die redaktionen teilweise aber nicht.
edit . ja richtig, dein letzter absatz passt.
cb testet in 720p
luxx testet 720p
pcgh testet 720p
hub testest 1080p und hat sogar vor 2 wochen ein ausführliches video dazu gemacht
steve testet in 1080p
roman testet in 1080p
igor testet in 720 oder 1080p
etc... pp
Naja, das ist ja wurst, ob 720p oder 1080p. Man könnte auch in noch niedrigeren Auflösungen testen, Hauptsache das CPU-Limit ist gewährleistet.
wo ziehst du denn die grenze mit welchem ram man eine intel cpu bitte testet? 6000? 7000? 8000? 9000?
Ich würde es gerne einmal mit DDR5-5600 (JEDEC) und stock sehen, so wie es beispielsweise PCGH macht (also quasi wie vom Hersteller vorgesehen) und einmal komplett auf Anschlag auf nem 2-DIMM-Board mit maximal möglichem RAM-Takt und maximal scharfen Timings bei noch vertretbarer Spannung. Dann kann sich ja jeder auf der Spanne, die diese beiden "Endmember" darstellen, was aussuchen.
Und genau da liegt der Hund begraben.
korrekt. solange der tester uns versichern kann dass er stets im cpu limit war, ist die auflösung latte. von mir aus kann es auch 1440p oder 4k sein. nur wird die wahrscheinlichkeit halt geringer.
und jetzt kommt ein weiterer punkt hinzu
man möchte ja am ende eines tests einen durchschnittswert ermitteln.
jetzt hast du von 20 spielen 15 wo mit einer 4090 sogar in 4k ein cpu limit erreicht wird, was ja gut wäre. dummerweise kommen dann mit pech aber 5 titel die das nicht mehr schaffen. das durchschnittsergebnis wird damit verfälscht oder du musst die 5 spiele rauslassen was ebenfalls schlecht wäre.
deshalb auflösung runter damit du auf gar keinen fall in die gefahr läufst ;)
und das ist auch der grund warum die dickste gpu genommen wird. es wird ja nicht das gesamtsystem getestet sondern lediglich die cpu.
Wenn ich dieses neue super video resolution feature vom neuen Treiber im nv control panel aktiviere wird mein Bildschirm schwarz, der PC startet neu und beim neustart sehe ich dann im Gerätemanager, dass die GPU deakiviert wurde. Wenn ich es wieder ausschalte passiert das selbe…wtf
was soll das feature denn machen?^^
Sorry auch von mir für den Offtopic-Talk hier. Ich denke nur, dass eine Raptor-Lake-CPU der bessere Partner für meine 4090 wäre als eine Zen 4-X3D-CPU. Ein Kumpel will mir erzählen, dass die neuen AMD-CPUs die eierlegende Wollmilchsau wären. Sind sie für mich aber nicht. Er begreift aber auch nicht, was ich vorhabe. ^^
Sorry aber das ist einfach unnötig. Dieselbe Scheisse wie im X3D Thread wieder jetzt wieder hier genau 1:1 durchgekaut. Wozu? Lasst es doch einfach bleiben bzw. diskutiert das bis zum erbrechen im entsprechenden Unterforum. Gibt auch Leute, die das nicht die Bohne interessiert.
Ja, sehe ich ein. Kommt nicht mehr vor.
puhh wüsste jetzt nicht wann ich sowas nutzen würde.
entweder die videos sind auf youtube in 1080p60 + vorhanden oder ich gucke es erst gar nicht :d
filme sind 4k.
dann wirds schon dünn. jemand ne idee?
Hat wohl Benches herausgesucht, die auf dem 13900K besser liefen? :unsure:
Zugegeben ist der 7950X3D brutal effizient
Wegen topic...
In den Benches wurde ja eine 4090 verwendet. Passt also hier auch rein :)
Was mom. nicht so toll sein soll, ist die Core-Verteilung. Kann man mit cmd-Befehlen fixen und der X3D steht viel besser da
Auch wenn dass Spiel nicht besonders anspruchsvoll ist, aber warum macht man CPU Benchmarks in 4K ? Ich versteh das bis heute nicht, warum das so viele Reviewer machen. :rolleyes2:
4K ist halt die Auflösung, die die meiste Aufmerksamkeit bekommt.
Kenne ich, danle ;)
Hab ich im Nachbarthread zig mal erklärt, aber kaum jmd versteht es, weil mein Ansatz ein völliger Anderer (nicht Mainstream) ist. Such bitte danach...
Wegen topic...
Ja nee is klar. Und weil der Raum in dem das getestet wurde, noch mit Rigibs Platten ausgekleidet war, am besten noch das Bauhaus Forum zumüllen.
Ihr seid echt die Härte Jungs. :rofl:
Streitet Ihr Euch wirklich den ganzen Tag wegen AMD vs Intel?
Man hat schon dem @Brandur angemerkt, dass er traurig als Intel-Fanboy ist. Wie er eine angebliche überdurchschnittliche Grafikkarte hat :lol:, so möchte er auch die beste CPU…
Seid doch froh, dass wir zwischen den CPU Herstellern so einen Kampf um die Spitze haben. Dadurch gewinnt der Verbraucher am Ende.
Der 7950x3D ist eine Spitzen-CPU, vor allem in Anbetracht der Effizienz.
Man sieht doch was bei Grafikkarten passiert, wenn der eine Hersteller nicht mithalten kann.
Aktuell ist AMD der Sieger für mich, jetzt muss Intel sich die Krone zurückholen.
Am Ende muss man es aber auch abhängig von seinen Games und Ansprüchen machen.
Man kann aber auch nicht verlangen, einen 13900KS mit einem 8800er RAM zu vergleichen. Vor allem muss das am Ende TM5 stable sein.
Ich bin mit dem 5800x3D erst einmal bedient: Tarkov läuft endlich zufriedenstellend.
Bin gespannt, wie die Preise sich bis Black Friday entwickeln. Eventuell würde ich noch einmal upgraden. Aber bis dahin fließt noch viel Wasser den Rhein hinunter.
Klar, wenn man keine Kohle für eine neue Plattform hat, wird sich die alte schön geredet, kennt man ja von Dir :d!
Mal was zum eigentlichen Thema: Gibt es eigentlich nun mehr Infos zur vermeintlichen 4090Ti oder Titan?
Genau das wollen Manche nicht verstehen
Mein Gott, wenn es dich (!) und vielleicht 3 Hanseln so brennend interessiert, dann Kauf beide Plattformen, Lote sie aus und präsentiere das Ergebnis. Ich würde auch nicht zig zusätzliche Tests machen, die vielleicht für 3% der Leser interessant sind und real betrachtet wenig bis keine Relevanz besitzen.
Irgendwann ist doch auch Mal gut. Jeder zweite Post von dir dreht sich um dieses "Mimimi", wirst du dann darauf hingewiesen warum etwas so ist wie es ist, bist du (gefühlt) beleidigt. Also los, mutig voran und selbst testen und veröffentlichen.
Ansonsten kann ich nur sagen, die Community war irgendwie auch Mal "besser". Diese permanenten Anfeindungen, "XY ist besser, alles andere ist doof" oder auch "Guck her, ich hab den längsten, du kannst dir das nicht leisten" ist einfach nur zum fremdschämen. Sorgt aber leider auch dafür, dass die Leute die wichtige Info gute Infos usw. weniger werden. Auch ich schätze die Infos/Informationsaustausch hier sehr, aber leider sind es permanent die gleichen, die quasi durchs gesamte Forum geistern und dort wüten. So, mein Wort zum Mittwoch ;)
Ab heute gibt es keine Verkaufsgebühren mehr auf ebay. Dafür leider ein Datenaustausch mit dem Finanzamt. Ich bin mal gespannt wie sich die Gebrauchtpreise der 4090 einpendeln. Ich selbst würde Ebay immer vor allen anderen Plattformen bevorzugen, da es für mich entspannter ist. Wie schätzt ihr das ein? Wird es Auswirkungen auf die Preise haben?
Ähnliche Themen
Antworten
7K
Aufrufe
528K
