[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Spielst du schon oder analysierst du noch Frametimes :coffee2:
Ich bin grundsätzlich nur am analysieren und wenn ich fertig bin und der Meinung bin, dass der PC Port nicht gut läuft, sind die 2 Stunden Refund Zeitfenster um :fresse:
Ok, dann haben nur die Karten die keine 3100 schaffen keine spulen 🤣. Der Grund warum sie so kacke taktet 🤣🤣🤣. Also wie immer random.
Oder ihr habt eure auf wasser umgebaut und das verursacht nun das Orchester.
Meine ist auf Wasser umgebaut und der Rechner steht genau auf der Höhe vom Ohr. Ist bestimmt was anderes wenn die Kiste auf dem Fußboden steht und statt dem Mesh im Deckel, der gedämmte Einsatz verbaut ist.
Treffer, ist unter Wasser.
Habe die kleinen süßen aber auch durch den Luftkühler gehört.
Für mich ist es ok.
Genau das habe ich bisher auch immer gemacht. Diesmal war jedoch kein Kühlblock verfügbar.
Es freut mich, dass Du auch hier wieder dabei bist - hatte Dich schon vermisst.
War fast 4 Monate weg.
Gesundheitlich Probleme gehabt, jetzt geht's wieder😀
:d
So ein Sch... jetzt muss ich bis 28.2. - 2.3. auf den Block von Bykski warten :wall:
:heul:
Mach Dir nix draus - watercool liefert mir auch erst Anfang März. Wenn bis dahin die 7X3D verkäuflich sind, kann ich alles in einem Arbeitstakt umbauen. See always the bright side of life;)
Der X3D rundet dann das ganze Paket mit der 4090 ab das sollte dann alles so passen bis zur 5090 .
:d
Schon ein geiles Geschoss, aber auch der Preis ist fett mit 4,8k 😅
An alle mit TUF und/oder Strix…
Ist doch “normal“, dass die rote LED an der Karte brennt, wenn der PC aus ist. Und sie geht aus, wenn der PC gestartet wird (ist jedenfalls bei mir so)
Bei Roman ist das scheinbar anders (ab 3:33 min)… :confused:
Bei meiner war mit dem original Nvidia Adapter das rote Licht ausgeschaltet auch an, mit dem original Corsair Adapter dann aus.
Kommt also drauf an :d
Beste Grüße
Nachdem meine Game Rock jetzt wieder bei Aternate im Paketzentrum auf abhoung wartet. Werde ich nach gutschrift verscuhen ne FE oder strix zu ergattern, Macht es eig nen unterschied ob Strix OC oder ist das egal ?
Unterschied bezogen auf was? Leistung? Ne non OC kann höher boosten als ne OC.
Falls Du die Gamerock wegen Spulenfiepen zurückgesendet hast, kannst Du Dir den Versuch mit der Strix allerdings schenken. Da ist die FE die bessere Alternative. Wenn Du auf leise Lüfter stehst, dann die Strix.
Wenn Du beides brauchst, setz diese Generation aus. :fresse:
Ne die gefiel mir null, zocke eh nur auf 2560x1440 in 120 FPS ab und an in 5120x1440 aber war die Omni Black komplett ohne RGB da hatte ich kein Bock drauf xD
Ja muss aber auf Rückerstattung von Alternate warten, Sendung ausgeliefert aber steht noch warte auf Rücksendung.
Spätestens wenn das Geld vom Alternate zurück ist ist sie es nicht mehr habe immer so ein Glück
Servus Leute, ich weiss das das eigentlich hier nicht hingehört aber das ist das erste mal das ich weder weiter weiss, noch was ich probieren soll...es geht einfach nur um "Deadspace Remake", ich würde es gerne spielen wollen :-) War ja auch eigentlich gar nicht mal so günstig...
Ich habe es jetzt mehrmals versucht (3x Neu De/Installiert auf verschiedenen Partitionen) und komme nicht mal aus dem Settings Menü vernünftig raus, hat das wer schon mal gehabt?
Den Mauszeiger kann ich ganz normal bewegen aber die Menüs reagieren nicht bzw nur schleppend (Lag)... und wenn ich auf einem Setting bin und das aktivieren(oder deaktivieren egal) will, muss bestimmt 10x die Maustatste drücken damit was passiert. Um auf die nächste Zeile zu kommen dauert auch ewig…13900ks + 4090. Nur bei diesem Spiel ist es so, und wenn ich es dann mal gestartet bekommen habe, ist es im Spiel genau so…Mausbewegung quasi kaum vorhanden. Versuche mich umzuschauen und die Drehung dauert ewig, lagt halt wie Sau. An den FPS liegt es nicht die sind in Ultra bei ca 110 aufwärts. Habe so ziemlich alles an Tweaks ausprobiert die es im Netz so gibt, nichts . Vsync an aus, Vollbild/Fenster, gsync/BIOS Version mit und ohne oc usw. 1024er Auflösung, schlechteste Settings, mir gehen die Ideen aus...
Deadspace 3 läuft ganz normal, die Menüs kann ich bedienen und einstellen wie es sich gehört, sowie natürlich alle anderen Spiele die ich gerne spiele wie CP2077, Hogwarts usw, alles kein Problem. Das macht mich kirre, das ich dieses Spiel nicht spielen kann...Mouse Lag Fix gibt es ja auch glaube nicht für das Remake....
Ähnliche Themen
