[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, ich finde den optisch sehr gelungen. Wirkt sehr gediegen.
War mir nur für drei zu teuer, zumal man meine Kisten eh nicht sieht und mir Optik ziemlich egal ist.
Er kühlt mit den Originalpads bei 250 Watt und 32 Grad Wasser zudem auch 2-3 Grad besser als der Bykski. War nach Umbau anfangs nicht so - die ersten ca. 10 Tage war er sogar etwa 3-4 Grad schlechter. Musste sich anscheinend erst "einfahren" 😅
Ja, nachdem ich die 4er Generation eigentlich überspringen wollte, wurde ich von der 4090er Effizienz (ganz grob gesagt etwa doppelt so viel F@H-Punkte bei etwas mehr als halb so viel Stromverbrauch gegenüber vorherigem Setup ... also statt vorher 30 Mio PPD bei 1650 Watt/h nun 62 Mio PPD bei 900 Watt/h für beide Kisten) derart überrollt, dass mir gar keine andere Wahl blieb :d
Kannst du die Karte nicht erst kurz unter Luft auf Fiepen testen? Das wäre mir nix, instand auf Wasser umbauen, ohne vorherigen Test.
Geht nur mit viel Aufwand bei mir, müsste die Kiste fast zerlegen wegen Hardtubes und da hab ich gar kein Lust drauf.
Kannst du beim nächsten Video, bitte mal ne FPS und CPU/GPU mit anzeigen?
Hier ist der Nachweis, dass ich ein auserkorener Gottes sein müsste ^^
RT Shadows sind off, ändert aber auch nichts an der Performance.
Wenn man auf dem Pferd reitet, kommt es eher zu Mikroruckler... wobei ich nie reite, sondern immer nur sprinte oder Fast Travel nutze.
Habe aber auch 35 Mods installiert, u.a. 4K Rüstung.
4.00 lief genauso -> aber wehe dem, ich hab DLSS nicht verwendet :fresse: Dann war es eine Ruckelorgie vom Feinsten.
Die Mod AutoLoot führt ebenfalls zu Mikroruckler je nach Setting beim Hardcore-Looting -> aber die nehme ich gerne in Kauf damit ich nicht selbst looten muss.
Nochmal, du hast offensichtlich einfach andere Ansprüche an Performance. Ist ja auch völlig ok, aber es bringt nichts uns permanent weismachen zu wollen, dass irgendwelche Games optimal laufen, wenn sie es erwiesenermaßen nicht tun.
Mal abgesehen davon, dass ein 60Hz Video ohne Frametime Graph für diesen Zweck völlig ungeeignet ist, kommt noch dazu, dass Witcher 3 hauptsächlich an Shader Compilation Stutter leidet, die nicht reproduzierbar sind. Treiberreset --> Frametime Graph anmachen --> Witcher 3 starten --> Shader Compilation Stuttering beobachten.
Nichtsdestotrotz habe ich mal zu dem Novigrad Teil geskippt, weil man hier auch Stuttering abseits von Shader Compilation bekommt aufgrund vom CPU Bottleneck wahrscheinlich. Und siehe da, ab Minute 6 haufenweise Mikroruckler. Mal wieder selbst von dir aufgenommen. Liegt wahrscheinlich an der Aufnahme oder weil die Karte in 16K rechnet, schon klar. Aber lassen wir das, es ist einfach witzlos mit dir darüber zu diskutieren, das habe ich mittlerweile verstanden
Glaub die ham Die Produktion eingestellt kommt ja nix mehr Letzte Drop war der 17.01 und UK 03.02.
Mal was anderes Strix oc Non Oc gibt's da gravierende Unterschiede?
Nachricht gelöscht
Okay, dann sind es nach Deiner Wahrnehmung ein paar Tage mehr. Doch weshalb ist das so?
Bei den anderen Boardpartnern scheint sogar ein regelrechter Preiskampf stattzufinden.
Wann und wo war der letzte FE Drop?
Fes lohnen sich nicht mehr. Jetzt werden nur noch titans hergestellt 8-)
Zeig mir mal ein Open-World Game, dass durchweg 100% perfekt läuft.
Forza Horizon 5, Spider Man Remastered / Miles Morales. Nur um aktuelle Beispiele zu nennen. Es gibt sie haufenweise.
Auch hieß es, die Kämpfe seien eine Ruckeorgie! Sieht das nach einer Ruckelorgie aus?
Du verstehst einfach nicht was Shader Compilation Stuttering ist. Ich kann auch ohne Probleme ein Video aufnehmen in Witcher 3 wo die Kämpfe flüssig sind. Wie gesagt, es ist einfach witzlos.
Nicht jeder Stutter entsteht durch Shader Compilation.
Und das habe ich wo behauptet? Im Falle von Dead Space habe ich von Traversal Stutters in Verbindung mit Shader Compilation gesprochen. Schon wieder vergessen? Bei Witcher 3 sind es eben Shader Compilation Stutter in Verbindung mit CPU Bottleneck in größeren Städten, weil dies auf das Game nun mal zutrifft.
Mal eine andere Frage, wenn Witcher 3 unter Stutter Compilation leidet, warum sind diese Stutters ohne RayTracing oder auf Full HD kaum bis gar nicht vorhanden?
Eine Stutter Compilation kann ich von deinen Gameplayvideos machen, die ja angeblich perfekt laufen. :ROFLMAO: Wenn du Shader Compilation Stutter meinst, gibt es keine Antwort auf deine Frage, weil die auf einer falschen Aussage beruht. Shader Compilation Stuttering tritt unabhängig von Auflösung und Grafiksettings auf und sind dementsprechend nicht für den User fixbar. Ich verstehe wirklich nicht warum du so zwanghaft versuchst ein Optimierungsproblem weg zu reden und als Quatsch abzutun, wenn dies von mehreren Stellen erwiesen ist und der Entwickler höchstpersönlich diese Fehler sogar eingesteht. Echt der Wahnsinn. Ist ja schön, dass es dich nicht stört aber sie sind nun mal da und das ist ein Fakt. Wer leidet hier noch mal unter Starrsinn?
Weil Callisto Protocol jetzt zu Release katastrophal war,
Dachte gerade ich schau mir das Game vlt. jetzt mal nach ein paar Patches wieder an, aber selbst bei Key Sellern kostet das immer noch 56€ :fresse: Ne danke.
Callisto Protocol habe ich mir auf der Xbox Series X angeschaut beim Kumpel . Ist eher so filmisch dargestellt . War nicht ganz so meins . Auf den ersten Blick ganz cool , aber auf dem zweiten Blick war es nicht so geil bzw. Ok aber finde da Deadspace besser . Es ist auch zur ursprünglichen Version eine Verbesserung und Atmosphäre finde ich super . Daher dann doch zu Deadspace Remake gegriffen . Callisto Protocol werde ich eher weniger kaufen . Nach längerem spielen sind mir diverse FPS Drops an Schleusen auch aufgefallen , aber im Großen und Ganzen läuft es meiner Meinung nach ganz gut.
Ich werde die Karte ohne zu testen gleich auf Wakü umbauen, mal schauen, ob ich Glück oder Pech habe :rolleyes2:
Dass du an Altersstarrsinn leidest, steht doch außer Frage. Da gebe ich dir Brief und Siegel drauf :)
Im Gegensatz zu dir, kann ich mich an einem guten Spiel mit guter Grafik erfreuen und heule nicht jedem kleinsten Stutter hinterher.
Dann hast du noch selbst gesagt, dass ein 60 Hz Video nicht optimal ist, was auch stimmt - jetzt reitest du wieder darauf rum.
Dann deine Behauptung, dass Dead Space defekt sei, weil dein OC (oder UV mit OC kombiniert) nicht stable ist :lol:
Da fällt mir echt nichts mehr zu sein - pure Inkompetenz.
Ich würde dir empfehlen, wie @****** es bei jemand anderes tat:
Hatte es für 48€ im Sale geholt gehabt, nachdem ich es aufgrund der Stutters zu Release zurückgegeben hatte. Vom Gameplay ist es nicht so gut wie Dead Space, aber dafür ist die Story besser und man hat ein Ich-bin-mittendrin-Gefühl -> top Atmosphäre.
Ja, paar Design-Fehler sind vorhanden... denen kann man natürlich ein lebenlang hinterheulen.
Kann ich wirklich nur empfehlen und würde mich nicht von frustrierten, Frametime-geilen Usern abhalten lassen.
Das HDR wurde gefixt, soll aber immer noch mies aussehen. Ich hatte es mit Reshade -> Levels.fx gefixt.
Die 60Hz waren überhaupt nicht der Punkt an denen ich mich aufgehängt habe. Das war nur einer von vielen Punkten um aufzuzeigen das dein sogenannter "Nachweis" komplett wertlos ist. Habe ich in vergangenen Posts ja verdeutlicht. Scheinst du nur nicht zu verstehen.
Den einzigen Nachweis den deine Videos liefern, sind die für die Probleme, die ich hier angesprochen habe. Wenn man dich dann darauf hinweist sind es natürlich andere Probleme, die durch Aufnahme passiert sind oder es wird als nicht so schlimm abgetan und ich als "Frametime-Geiler User" oder "Trottel" bezeichnet. Und wenn dir die Argumente ausgehen bist du derjenige der in solchen Diskussionen ständig ein altes Thema hervorholen muss, bei denen ich vielleicht unrecht hatte, das aber absolut gar nichts mit dem aktuellen Thema zu tun haben, nur um mich zwanghaft zu diskreditieren und die Kompetenz in diesem aktuellen Thema abzusprechen. Und du wirfst mir vor ich würde auf Dingen herum reiten? Einfach lächerlich
Dito. Meine Gaming oc macht zwar 3,1 mit dafür sind auch die Spulen da 😛
Ok, dann haben nur die Karten die keine 3100 schaffen keine spulen 🤣. Der Grund warum sie so kacke taktet 🤣🤣🤣. Also wie immer random.
Oder ihr habt eure auf wasser umgebaut und das verursacht nun das Orchester.
Hogwarts läuft tagsüber bei Sonnenschein unschön. Viele Pop-Ups und fühlt sich träge an, trotz durchgehend 75 FPS.
Hoffe ja auf einen Patch heute oder morgen.
Edit: Ergänzung...
Ähnliche Themen
Antworten
7K
Aufrufe
541K
