[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Genial, dass es das Dead Space Remake gibt, unbezahlbar das Spiel. Sofortiger UV-Stabilitätstest ohne stundenlang irgendwelche Benchmarks laufen lassen zu müssen. Spart unglaublich viel Zeit.
Natürlich ruckelt jedes Games, wenn die FPS einbrechen. Was willst du mir erzählen? Hogwarts Legacy hat auch Ruckler ohne Ende, wenn ich die Frames nicht begrenze.
Viele Games, die über eine aufwendige Grafik verfügen, können die Frames nicht halten. Da geht es auf und ab mit den Frames und dann nimmt man das als Ruckeln oder Stuttering war.
Abhilfe kann man in der Regel schaffen indem man die Settings reduziert, die Hardware aufrüstet oder die Bilder ganz einfach begrenzt.
Es geht hier doch überhaupt nicht um Ruckler wenn die FPS Einbrechen? Hast du das Video überhaupt gesehen? Das Spiel hat massive technische Probleme, was detailliert erwiesen ist. Man hat diese Ruckler selbst in 720p mit niedrigsten Einstellungen und 60 Fps Limit. Also was willst du mir erzählen?
Habe gestern das Game angefangen und über zwei Stunden gezockt . Ersten 10 min gab es ruckler , dann hat sich das beruhigt und dann lief es sehr sauber . Ob das Game jetzt guter UV Test ist ka , weil der Verbrauch liegt wie in BF 2042 bei ca. 300 Watt bei voller Auslastung . Habe aber RTAO nicht on und SSAO aktiv sonst Ultra und 4K HDR DLSS Qualität. Meiste Zeit habe ich die 144 Fps anliegen und geht hier und da bei viel Action auf 120 FPS runter . Also da habe ich keine spürbaren ruckler oder so . Weniger als 120fps habe ich bei dem Game bei mir noch nicht gesehen .
Was mich nervt ist das man wie bei Bf2042 nur HDR on und off einstellen kann und nicht Kalibrieren . Bei Bf2042 gehts mittlerweile , aber hier leider nicht .
Ich fand es bei Deadspace recht erträglich auch wenn die kurzen ruckler nach Türen vorhanden waren. Fand das Spiel eher langweilig :fresse:
Ich guck mir doch kein Video zu Witcher 3 an, wenn wir über Dead Space sprechen.
Zumal Witcher 3 perfekt lief. Das einzige Stuttering kam durch die MOD Autoloot :drool: Die nehme ich aber gerne beim Looten in Kauf, bevor ich selbst looten muss.
Dann war es mein Fehler. Das ist das richtige:
Ändert aber nichts an meiner Aussage. Und auch Witcher läuft nicht perfekt. Kannst dir ja gerne mal das von mir fälschlicherweise verlinkte Video angucken bzw. das detaillierte PC Video von Alex auf dem selben Channel. Bestätigt in dem Fall dann nur, dass du extrem verzeihend bist, wenn du meinst ein Spiel laufe perfekt. Kein Framelimit der Welt hilft gegen Stuttering, es wird nur etwas weniger auffällig, da die Frametimes natürlich höher sind bei weniger fps und kleinere Mikroruckler dadurch besser kaschiert werden. Ist aber trotzdem noch sofort sichtbar.
Leider laufen alle AAA Games der letzten Monate nicht wirklich gut, bzw wurden mies-extrem mies auf dem PC optimiert. Denke das kann man auch einfach so stehen lassen, gibt ja nicht umsonst die ganzen Artikel bei pcgh, Computerbase, Digital Foundry, etc. Und gerade die Ruckler mit UE4 sind und bleiben eine Plage. (aber nicht nur bei UE4, siehe Witcher 3)
Auswahl von Spielen mit Rucklern etc:
- Calisto Protocol
- Dead Space Remake
- Hogwarts Legacy
- Forspoken
- Witcher 3 "Next Gen"
- Warhammer 40k Darktide
Irgendwie "angefangen" hat die Misere mit Gotham Knights, dass Game ist technisch unter alle Sau :wall:
Man kann quasi bei jedem der aufgezählten Games nur auf Patches warten und sollte dies auch tun.
Ist echt absolut nicht feierlich was da gerade abgeht bei den Spielen, dass sollte eigentlich auch niemand Schönreden oder gar Verteidigen!
War da nicht auch was bzgl. fTPM bei AMD und dem Agesa? Glaube da kommen manchmal einfach viele Dinge zusammen... Viele Faktoren (Game-Engine, Integration, System, Treiber, subjektives Empfinden)
Am besten hat es noch Computerbase zusammengefasst:
Is denn da los ist der Ralle Bot tot oder passiert grade nix ? Gestern 17:45 letzte Meldung, sonst im Min Takt xD
Dachte heute Dropt mal ne schöne 4090 FE aber ne
- Calisto Protocol
- Dead Space Remake
- Hogwarts Legacy
- Forspoken
Calisto läuft mittlerweile glaube ich bis auf das HDR, was immer noch den Schwarzwert anhebt und damit sehr verwaschen aussiehst. Kann ich aber nicht bestätigen weil ich das Spiel nicht besitze.
Aber ansonsten kann ich nur zustimmen. Mittlerweile ist es echt normal geworden wie es scheint. Sieht man ja daran, dass die Spiele zumindest teils trotzdem sehr gut bewertet werden und es sogar Spezialisten gibt, die meinen so eine Performance noch zu verteidigen weil sie mit ihrem 15fps Limit (Achtung Übertreibung!) und Controller das nicht merken. Ist für mich völlig Unverständlich. Selbst mit Controller in 60fps kann man Mikroruckler locker sofort sehen. Dass es selbst mit der UE4 besser geht zeigt Hi-Fi Rush gerade. Da ruckelt absolut nichts.
Das ist längst gefixt und nicht Ursache dafür. Die genannten Games ruckeln auch auf Intel CPUs und AMD GPUs.
Ist ja inzwischen alles verfügbar. Deswegen heißt es auch "Verfügbarkeitshinweise" ;)
Alles bis auf diese bekloppte FE und Strix zu Humanen Preisen 2500 Zahlt hoffentlich keiner mehr
Also bei mir lief / läuft W3 auch absolut astrein. Will jetzt nicht beschwören dass es gar keine Mikroruckler alle 10 Minuten gibt, aber dann gibt es gar kein Spiel was astrein läuft. Kenne Deadspace nicht, aber W3 hat Null Probleme in einem 4090/12700K/W11 Setup.
Es ruckelt jedes Mal wenn du einen neuen Gegner siehst, einen neuen Trank trinkst, einen neuen Skill benutzt etc. Quasi immer wenn ein neuer Grafikeffekt das erste Mal auftritt. Das kann alle 10 Minuten sein aber im schlechtesten Fall auch alle paar Sekunden. Im Fall von Witcher 3 kommt man nach einigen Stunden wahrscheinlich an einen Punkt wo es wirklich nur noch alle 10 Minuten auftritt und weniger schlimm ist weil die Ruckler nicht reproduzierbar sind. Zumindest solange bis es mal wieder ein Treiberupdate gibt, dann geht es von vorne los.
Dead Space macht das auch, denn neben den immer auftretenden Rucklern beim bewegen in der Nähe von Türen oder beim Öffnen von Türen, die auch reproduzierbar sind, gibt es hier auch einige Shader Compilation Stutter (obwohl das Game ja eine Kompilierung macht) wie in Witcher 3, was in diesem Fall aber sehr nervig ist. Z.B. an einigen Stellen wo man erschreckt werden soll mit einem neuen Effekt (Monster greift dich unvermittelt an, oder huscht irgendwo lang) was dann aber immer auch mit einem Ruckler begleitet wird. Wenn man die Stelle neu lädt tritt der Ruckler nicht mehr auf aber man weiß natürlich schon was kommt. Totaler Atmosphärekiller, der den Moment für mich, als jemand der das Original nicht gespielt hat, kaputt macht.
Selbst der Entwickler gibt bekannt das er noch zig Sachen fixen muss, vor allem in Bezug auf Performance:
Ob der Entwickler nur Scheisse erzählt und das Game insgeheim astrein läuft? Joa, wage ich irgendwie zu bezweifeln 😏
Und das ändert jetzt was daran, wie es aktuell bei mir läuft? Ohne RT sogar auf der 3080 ohne Probleme im DX12 Modus.
Ich geb‘s auf, schön das bei euch die Spiele quasi perfekt und ohne jegliche Ruckler laufen und das in allen Situationen. Klingt himmlisch.
Ihr müsst Auserwählte Gottes oder so sein, schön für euch 😏
Für uns Pöbel gibt’s leider Ruckler und Bugs… 😖
Geht es dir eigl noch gut? Was interessiert mich, wie eine RTX 3080 oder eine RTX 2060 mit einem Ryzen 5 3600x läuft.
Zumal da auch kurz stand, Launch Day Version.
Mittlerweile kamen 2 Patches - Guten Morgen :wink:
Er testet das Spiel auch auf einem 4090 System mit 12900K auf dem aktuellen Patch mit den selben Rucklern. Das Video ist von vorgestern. Die anderen Systeme sind nur um aufzuzeigen, dass die Ruckler auf schwächeren CPUs noch stärker und störender ausfallen und um nachzuweisen, dass es kein Problem mit seinem Setup ist. Du schaffst es ja offensichtlich nicht mal das Video zu gucken und trotzdem versuchst du dagegen zu argumentieren. Was soll das? Du hast hier sogar schon selbst ein Video von deinem Gameplay gepostet, wo man ganz klar die Traversal Stutters erkennen kann die gemeint sind. Mach dich doch nicht lächerlich. Schau dir allein 2:00 - 2:10 an.
Nachricht gelöscht
Ähm, du weißt schon, dass es 6K sind? Und die Grafikkarte am Rauchen ist?
Zumal das noch mit DLSS 2.5.0 war.
Dann noch FPS Lock auf 90 statt 70 oder 75 um die 3 GHz zu testen.
Dazu kostet das Aufnehmen extra Leistung und das, wo die GPU bereits auf 100% ausgelastet ist.
Hatte sogar explizit geschrieben, dass 6K mit DLSS 3.1.1 deutlich besser läuft.
So langsam machst du dich lächerlich.
Ja, natürlich. Das sind nicht DIE Ruckler, sondern andere :fresse: Ist schon ok, du hast die Hardware aus der Zukunft auf der es perfekt läuft, während renommierte Medien vor allem im Bereich Technik wie Digital Foundry wahrscheinlich einfach nur auf 70fps limitieren und mit Controller spielen sollten um das Problem zu lösen. Oder bessere Hardware kaufen. Kann ja nicht jeder die 3,1GHz Edition haben.
Sorry, Thema ist jetzt aber durch von meiner Seite
Ähnliche Themen
Antworten
7K
Aufrufe
540K
