[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
2183€ 😅
Wenn ich bedenke was ich für meine bezahlt habe, war das mehr als unverschämt 🤣. Aber ist in der eile dann auch nur die gaming oc geworden. Aber das wäre es mir echt nicht wert.
Darf man nicht sagen echt nicht ^^. Weniger als ne 4080 kostet.
uiuiui wie die 4090 hier verdroschen wird.
Und wen interessiert mit solchen Karten die kleine Auflösung?
Gibt es kein Vergleich mit UHD (ohne KI Verbesserungen) und den Karten? Finde da nix auf die schnelle. Meine Kiste schafft (zumindest jetzt noch am Anfang) 4090 auf 80% zwischen 70 und 1++ mit Cap auf 120. Alles auf Ultra unter UHD, DLSS aus und DLAA an. Ohne Cap waren die min Frames glaube ich höher, das muss ich nochmal anschauen. Sync war vorhin aus beim zocken.
Bis zu 380 Watt liegen an bei 80% ^^ Solange ich nicht mehr FPS brauche gehe ich da nicht höher. :coolblue:
Gibt es kein Vergleich mit UHD (ohne KI Verbesserungen) und den Karten? Finde da nix auf die schnelle. Meine Kiste schafft (zumindest jetzt noch am Anfang) 4090 auf 80% zwischen 70 und 1++ mit Cap auf 120. Alles auf Ultra unter UHD und DLSS aus und DLAA an. Ohne Cap waren die min Frames glaube ich höher, das muss ich nochmal anschauen. Sync war vorhin aus beim zocken.
Aber nur mit FG
LoL, in dem Video um das es hier geht zeigen sie genau das ne Folie später. :lol:
Nur Blöd das ich das ich das Video nicht gesehen hatte nur das Bild. Jetzt schon, dann Lol mal weiter...
"Und meine wenn ich an der selben Stelle bin ^^" Da habe ich dann gefunden was sich gesucht habe. Sorry das ich meinen Post vorher nicht gelöscht hatte und du mit 2 überfordert bist.
Überempfindlichkeitsmodus wieder aus :asthanos:
Autsch....
So nun zum Thema was ist FG ????? Stehe auf dem Schlauch.
Ah okay, das habe ich aus , steht sogar da ^^
Edit: War leider nicht aus trotz ausgegrautem Feld.
Direkt mal fast halbiert die FPS ohne FG.
Also gestern nach etwas längerem Spielen Hogwarts viel mir auf das es noch einige Grafikbugs vorhanden sind .
Spiegelungen mit mit Eigenleben oder Winkelabhängigkeit.
Nicht immer aber es fällt auf.
Auch so gibt es hin und wieder ganz kleine Fehldarstellungen.
Wie es auch schon bei einigen Test gezeigt wurde.
Ob man das abstellen wird muss man Mal abwarten.
Kann aber auch gar nicht genau sagen ob das vom RT kommt weil man für diese Änderung einen Spiel Neustart braucht und meine kleine nicht aus dem flow gerissen werden wollte.
Es sind aber durch aus noch ein Paar technische Mängel im Spiel.
Wie schafft es eigentlich W3 alles in in-game umzustellen, während alle anderen Spiele mindestens einen Neustart vom Menü aus oder gar einen Restart brauchen?
Softwaredesign. Bestimmte Einstellungsänderungen lassen sich nur umsetzen, in dem die Renderingpipeline neu initiaisiert wird. Je nach dem wie die Engine funktioniert kann das ein einfacher Call sein oder sehr schwierig durchzuführen sein, ohne dass das Spiel ganz neu gestartet wird.
W3 ist eine eigene Engine, CDPR hat volle Kontrolle, und die wissen auch, was sie tun. Wenn man die U4 Engine oder eine andere third-Party Engine nutzt und dabei bestimmte Dinge in der eigenen Software nicht von vorne herein sauber Designed, ist es oft einfacher einen Neustart zu erwzingen als irgendwelche Bugs zu riskieren.
Man liest ja auch immer wieder von Spielen (zuletzt Dead Space) bei denen zwar auf den ersten Blick Einstellungen ohne Neustart verändert werden können, sich dann aber rausstellt, dass danach das Spiel nicht mehr sauber funktioniert. Um diese Effekte zu vermeiden, erzwingen einige Spiele einfach gleich einen Neustart.
die kombination aus neustart + 120 logos + 5stunden ladezeit sind halt die kirsche auf der torte :d
bei, wow und diablo bist du ruck zuck ingame :d
diese grafikfehler hab ich auch schon gesehen
weißer glow um gegenstände/schränke etc...
schatten verschwinden an den rändern und um den charatker herum.
im großen klo haben die fließen geglitzert ...
Wenn ihr RT Schatten ausstellt sind viele Grafikfehler behoben ohne das ihr viel an Qualität einbußt.
Hab eben die aller neueste DLSS Version 3.1.1 bei Hogworts rein gepackt soll die Qualität steigern und die Performance wohl auch.
Sieht aus wie eine Powerbank. Fand die älteren Designs besser. Vielleicht aber auch bisschen der Größe und Form der GPU Platine geschuldet.
Ähnliche Themen
Antworten
7K
Aufrufe
488K
