[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Guten Morgen !
Meine Inno 3D, die als defekt über Caseking an Inno gesendet wurde, ist nun erstattet.
Als Info für euch. Ich war nochmal so frei an der Hotline auf die 4 Wochen hinzuweisen ohne das die Karte schon angekommen ist beim Hersteller.
Netterweise war das für Caseking ein Argument und wir sind uns nun einig das es sonst zu lange gedauert hätte.
Liebe Grüße an Alle
Du beziehst dich wahrscheinlich auf die Extensions Kits, Das sind halt die männlichen Enden der PCI-E Stecker, die sind immer gleich (universell). Wenn du Kabel direkt fürs Netzteil suchst, musst du die Asus/Seasonic-Sets für dein Netzteil suchen
Alles klar, danke. Ja suche die Kabel, die man direkt ans Netzteil stecken kann. Weiß ich Bescheid, dann ist das hier nix für mich.
Wasn das für ne Frage, die Karten die ich hier habe / hatte, kamen nun Mal mit einem 4 fach Adapter von Nvidia. Also würde ich auch nur so einen vom Drittanbieter nutzen.
die Karten funktionieren aber auch alle mit 3x 8 Pin am Adapter, lassen dann halt "nur 450W" zu, das CableMod Kabel würde mit den 3 Anschlüssen aber auch 600W zulassen, aber das dürfte für dich ja zweitrangig sein, weil du laut eigener Aussage doch alles "out of the Box" nutzen willst, daher sehe ich kein Problem mit 3x 8 Pin am Netzteil, aber wenn du dich mit 4 Anschlüssen besser fühlst ist das ja auch okay :)
Das original Kabel von Seasonic hat sogar nur zwei Anschlüsse? https://seasonic.com/12vhpwr-cable#gallery
Spezifiziert für 600W.
Wenn das Netzteil auf den einzelnen Anschlüssen genügend liefern kann, dürfte das ja kein Problem sein. Die Adapter mit 4 Anschlüssen gehen halt auf Nummer sicher weil es genügend Leute mit Chinaböller Netzteilen gibt.
Are you sure about that?
Die Cablemod Kabel haben alle nur 2 Sense Pins. Die lassen von 2x bis 4x immer 600W zu. Auch die Kabel der Netzteilhersteller sind ausnahmslos mit nur 2 Enden und darüber gehen trotzdem 600W. Der Nvidia Adapter musste eben auch die schlechten Netzteile berücksichtigen, die tatsächlich nur 150W pro PCIe 8 Pin Kabel liefern können.
Alphacool find ich jetzt nicht so wertig und Watercool..
Ziemlicher Stuss den Du da schreibst. Die Kühler nehmen sich nichts bezüglich Qualität. Hatte schon Kühler von allen Hersteller in der Hand und teilweise waren die Watercool Produkte nicht so wertig.
this.
Kannst Problemlos das 3x8Pin auf 12PWHR kaufen. Macht genau das gleiche. Habe ich auch. Habe auch 600 Watt.
@Gurkengraeber
Frage an die FE Besitzer und alle anderen 4 Peitschen PCIe Benutzer - wenn man 3x8 Pin verbindet und einen auslässt - ist es egal welchen man frei lässt ?
Ich plane mit max 450 Watt, mein 116FPS Framelimit macht es unnötig mehr zu haben. Danke euch,
Weiß jemand ob die Caseking / Cablomod Adapter auch bei Enermax Tytan Netzteil funktionieren ?
Ja, das ist egal. Die Schaltung ist so, dass nur die Summe der Anschlüsse zählt, nicht welcher verwendet wird.
4090 Strix im kuriosen Test aus China.
Das Video im Link ist auch mal ziemlich wild. Hier macht man sich ja immer viele Sorgen und wirft das Mädel einfach mal den Schnee ins Netzteil :fresse:
Kurze Frage.
Bei cable mod gibt es drei Varianten für das 12v Kabel/Adapter für die EVGA G2 Netzteile.
2x8 pin
3x8 pin
4x8 pin
Welchen der drei sollte ich für das alte Netzteil wählen?
Kurze Frage.
2x8 pin
3x8 pin
4x8 pin
Kommt auf das Powerlimit deiner Karte im Bios an. 4x8 Pin, wenn deine Karte 451-600W macht. Wenn nur 450W, dann reicht die 3x8.
Die 4090 mausert sich ja immer mehr zur einzig überhaupt noch sinnvollen Graka der nächsten 2 Jahre. :d
Dann kann ich ja auf Nummer sicher gehen und 4x8 kaufen... Hab eh noch keines
  • Danke
Reaktionen: SH
Ähnliche Themen
Antworten
6K
Aufrufe
400K
