[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ich würde die wette eingehen. :d
RDR2 hat 2.2.10. einige versionen zurück. ich teste mal :)
fu rockstar
das erkennt instant dass die datei nicht original ist und das spiel startet nicht ohne das ich auf aktualisierung drücke. er lädt dann die 2.2.10 :fresse:
selbst wenn du die exe ausm ordner startest macht er automatisch das update und und tauscht die datei wieder aus
Kommt auf die Auflösung an: Bei 1440p siehst du es in der Regel, bei 4K wird es schwierig.
Klar, 4k. Bei WQHD oder FHD braucht man DLSS ja auch seltener.
@Scrush
Welches Spiel hättest Du denn gerne? Ich mach die Bilder und lade sie als PNG unkomprimiert auf einen Cloud Server. RDR2? CP? PlagueTail Requiem? Spider-Man?
Take your pick. Kannst auch was anderes vorschlagen, aber ich muss das Spiel natürlich haben.
Ich mach für 10 Szenes je ein Bild mit DLSS Q und TLAA. Als Nachweis. Dann wähle ich zufällig je 5 verschiedene Bilder mit DLSS und TLAA aus und packe sie in einen Cloud-Folder, den ich freigebe. Und dann viel Spaß :)
fu rockstar
funzt
@Scrush
such dir aus. ist ja wurscht welche games ;)
ob ich alle treffe das will ich gar nicht sagen. gerade bei einem screenshot
aber in bewegung ist DLSS defintiv sichtbar. darum gehts ja. screenshot is ja wumpe
@Scrush
Deine Mühen in allen Ehren (ich sehe es genau so wie Du), aber Standbilder mit geüngend Zeit zum Untersuchen spiegeln auch nicht die Realität wieder. Alle die hier so großspurig behaupten dass DLSS so scheisse aussieht würden rein gar keinen Unterschied im normalen Gaming Betrieb erkennen. Vielleicht wenn sie Zeit haben, auf Telegraphenleitungen zu starren, während sie darunter herreiten, aber wenn dann noch jemand auf sie ballert, wars das. Ich glaube bisher kann man nur im Flight Simulator wirkliche Defizite erkennen, da sind die Anzeigen verzerrt. Und da würde man ja auch dauernd draufstarren, das geht nicht.
In W3 kann ich nur sagen wurde es perfekt umgesetzt. Ich spiele ohne, da mir die 4090 um die 60FPS liefert auf 4k RT Ultra. Das reicht in einem RPG für ein flüssiges Spielerlebnis. FG bietet fast das Doppelte, aber ich brauche es wie gesagt nicht.
DLSS ist genial, genau wie FG und dabei gerade noch am Anfang. Je mehr Games das unterstützen, desto mehr werden sich Lovelace Karten von ihren roten Gegenspielern absetzen. FSR3.0 soll ja der Heilsbringer auf AMD Seite werden, bin mal sehr gespannt, was die auf die Beine stellen. Konkurrenz belebt das Geschäft, aber momentan atmet nur eine Seite.
Es geht ja darum, dass @Scrush vom "typischen DLSS Bild" gesprochen hat. Also impliziert hat, dass man DLSS sofort als "typisch" erkennen kann.
Wenn ein Spiel korrekt implementiert ist, sieht man auch kein Schmieren. Das sind ja immer nur die Folge von fehlenden Bewegungsvektoren. Und wenn man was sieht, dann bestenfalls wenn man eine Szene ganz genau Bild für Bild vergleicht, wie das DigitalFoundry macht. Im echten Spiel sieht das de Fakto kein Auge.
Das Nachziehen hat man viel öfter durch RT selbst, weil die Effekte ja auch über mehrere Frames hinweg kumuliert werden, um Rechenzeit zu sparen. Das sieht man z.B. in Cyberpunk ganz extrem. Nicht, dass es mich stören würde, aber ich denke, manche verwechseln das mit den DLSS Artefakten.
An alle FE Besitzer/Wissenden. Ist die FE immer zu hören, sobald sie unter Last liegt? Ich habe aktuell eine FE mit relativ leisen Spulenfiepen aber Lüfter hörbar im Betrieb und eine Suprim X mit etwas lauteren Spulenfiepen, dafür aber ohne Lüftergeräusche. Die FE könnte ich auch nochmal einsenden, da NBB als Austauschgerät Gebrauchtware geschickt hat.
Seid Donnerstag, bieten sich Mindfactory und Computeruniverse, regelrechten Preiskampf :d
die RTX 4090 Gigabyte Gaming OC, erstmals 2029, geht seitdem in 10er Schritten runter. Erst einer, dann zieht der andere mit.
Lustig, wie die sich automatisch über KI selbst runterbieten. Scheint ja genug Luft in den Preisen zu sein wie es aussieht ;)
Liegt aktuell bei 1939,- €.
Kann nur eine Frage der Zeit sein, das die anderen Karten auch runtergehen^^
Genau das ist das Problem der FE. Wenig bis gar kein Spulenfiepen aber dafür einfach einen nervigen Lüfter verbaut den man schon ab 30% nicht mehr überhören kann.
Ist also normal und auch die neue wird das Problem haben.
Bin scharf auf die 4090 Frostbite und da die schon über 24 Stunden für gute 2000€ verfügbar ist werde ich noch warten.
Die Preise fallen,der Markt scheint bedient zu sein.
Je nach Händler kannst du zum Beispiel mit shoop oder DealWise (von der ING) noch zusätzlich Cashback/Rabatt mitnehmen. Da die Karten jetzt wieder länger in den Shops verfügbar sind, muss man nicht mehr wie von der Hummel gestochen schnellstmöglich zum Kaufabschluss durchhechten, so wie damals zu Ampere-Zeiten. Es ist alles ein wenig entspannter geworden. Aber auch irgendwie langweiliger. Mir fehlt der Nervenkitzel... 😪
Ich kann mich absolut nicht entscheiden was schlimmer ist, das Fiepen der Suprim oder der Lüfter der FE. Insb weil die Suprim nur 100 Euro teurer war…
Haha, stecke in genau derselben Situation. Die Kohle wäre mir wirklich egal in diesem Fall, selbst wenn die Teurere von beidem verschont bliebe. Aber die FE brummt, die Strix zirpt. Beides irgendwie nicht so pralle.
Ist wirklich ein wenig nervig. Ich beneide jeden, der den Jackpot geknackt hat. Also eine 4090 mit Luftkühlung, die weder fiept, rasselt oder brummt. :)
Haha, stecke in genau derselben Situation. Die Kohle wäre mir wirklich egal in diesem Fall. Aber die FE brummt, die Strix zirpt. Beides irgendwie nicht so pralle.
Ich möchte mit dem Thema jetzt auch einfach abschließen. Ich bekomme einfach keine Karte die komplett ruhig ist. Ich hatte jetzt so viele verscheidene Karten da und entweder haben sie mich angebrummt oder abgezirpt. Ich will EVGA zurück, keine einzige Karte von denen hatte Spulenfiepen bei mir…
Könnte bei mir auch so laufen. Im Zweifel zurück zu Ampere und auf die nächste Generation warten. Meine 3080 TUF fiept wirklich Null und die Lüfter hört man nie.
Du kannst vielleicht nochmal den Ghetto Mod für den Brummlüfter an Deiner FE ausprobieren. Hilft in der Tat ein wenig, auch wenn es mir nicht reicht.
Werde bei der Strix nochmal die Backplate etwas lösen. Aber abnehmen tu ich sie nicht, denn selbst wenn sie so nicht zirpen würde, würd ich sie ja so nicht benutzen wollen.
Wie ist es bei den Zotac Trinitys? Die sehen zwar billig aus, haben aber laut Spulenfiepenthread anscheinend gute Spulen. Brummen da die Lüfter genau so wie bei der AMP oder nicht. Letztere hatte auch ein sehr kurzes Gastspiel in meinem PC…
Bei einem Schreihals hat man zumindestens noch die Chance auf eine Besserung über Zeit (Habe die Erfahrung gemacht, dass es nach einiger Zeit besser wird) bzw. Eindämmung durch UV. Ein lauter Lüfter wird eher schlimmer werden über die Zeit.
Das sagen einige. Ich denke aber mir würde der Mut fehlen, das über die Widerrufsfrist hinaus auszuprobieren. Wenn die Karte also innerhalb der nächsten zwei Wochen leiser wird, super. Aber ansonsten dann Widerruf. So ne Aktion wie bei Amazon, wo man 2 Monate lang testen konnte käme mir jetzt gelegen. :d
Naja. Vielleicht auch ein Irrglaube.
Ich hab meine 3060ti von Asus mal im Zweitrechner gecheckt. Die zirbt auch ordentlich rum, dabei ist es nur eine 3060ti. Da hab ich aber noch nicht so drauf geachtet wie die meisten hier im Luxx :P
Also neu ist das nicht ;)
Nur die aktuellen 4090 von Asus schießen den Vogel halt mal komplett ab ^^
Diese Überlegung hatte ich auch, aber ich bin mir ziemlich sicher, dass das Topmodell nicht sonderlich weiter im Preis fallen wird - da wird meiner Meinung nach von vornherein nur ein kleiner Kreis Menschen als Zielgruppe einkalkuliert, würde ich jetzt mal vermuten.
Wahrscheinlich rede ich mir es aber jetzt nur schön, da ich meine schon am Samstag bestellt habe :d
Aber Spaß beiseite, ist in vielen Bereichen so, dass die "Mittelklasse" Produkte immer wieder mal günstig gehen, aber die TOTL Produkte eben nicht.
Mein LCD4 zb. hat bis zum bitteren Ende neu knapp 5k Euro gekostet, und selbst als dann der LCD5 kam, hat sich da nichts geändert.
Ist aber alles nur eine Vermutung, mit Marktwirtschaft kennen sich andere sicher besser aus :)
Meine Trinity ist flüsterleise und extrem kühl.
Von Zotac bin ich diese Generation echt überrascht und von Asus extrem enttäuscht.
Also bei computeruniverse ist die 4090 Frostbite immer noch für 2067€ zu kaufen.
Da musste ich jetzt auch zuschlagen 🤓
Also meine 4080 Frostbite hat kein SpulenfiEpen! Also wenn jemand Interesse hat 😀
Ähnliche Themen
Antworten
7K
Aufrufe
541K
