[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das Silber sollte super zum silbernen Rahmen der FE passen. Wenn das Gehäuse schwarz ist, wird das ein stimmiger Build. :)
Die ist leider nicht verfügbar.
Die ist ebenso nicht verfügbar.
Na ja, mit 3% Shop-Cashback ist die Manli auch "nur" 1.900 EUR bei Cyberport. Da wird es wohl die werden.
Hab mir jetzt die Manli bestellt. Krieg bald Nachwuchs und ich wollte vorher gern fertig sein mit dem Basteln.
Wird mein 10700k, der ggf. 5 Ghz AllCore bringt, die 4090 sehr ausbremsen? Ziel sind immer 4K@120fps. Hätte da eher gegen Endes des Jahre smit eiem Ryzen 7 7800X3D geliebäugelt, falls der Preis stimmt.
Für 4k wirst du nicht mal ne neue CPU brauchen.. es gibt so wenige Titel wo deine CPU WIRKLICH ausbremsen wird..
Noch. In 1-2 Jahren sieht das wahrscheinlich schon anders aus. :d
Ratenkauf macht´s möglich ...
So, meine Karte eingebaut und gleich mal ein paar Render gemacht. Wahnsinn, was das Ding in Echtzeit schafft, ich bin begeistert.
Habe auch mal 3D Mark Demo installiert und mal durchlaufen lassen: https://www.3dmark.com/3dm/86569975?
Passt das ungefähr so?
Ja, passt so für die Hardware.
https://www.3dmark.com/spy/34240861 das ist meine aktuell höchste Punktzahl im TimeSpy. Wir sind angeblich ein wenig CPU Bottlenecked im normalen TS, in Extreme siehts wieder anders aus.
Die Verpackung ist auf jeden Fall ein Highlight und das Paket echt schwer!
Verglichen mit den Custom Karten ist die FE aber echt putzig von der Größe.
Klasse, dann bin ich beruhigt (kenne mich damit 0 aus)
Ich sollte noch dazu erwähnen, dass ich 128gb, gemischten RAM habe, der unglaublich langsam läuft.
Die Grafikkarte kriegt nur 8x PCIe 3.0, ist auf 300 Watt limitiert (nur 2 Leitungen zum Netzteil angeschlossen) und die CPU kriegt ebenfalls nur 120, ist aber dafür Wassergekühlt. Auf den Block für die 4090 warte ich noch, sollte wohl im Februar kommen.
Die Verpackung ist auf jeden Fall ein Highlight aber verglichen mit den Custom Karten ist die FE echt putzig.
Oh ja, das Auspacken war beeindruckend, auch die Karte fühlt sich sehr sehr wertig an! Ich habe übrigens Karte 5 von 120 erwischt, welche ist es bei dir?
Wie ist die Lautstärke?
Lautlos, Gehäuse ist sogar noch offen, da ich auch meine Wasserkühlung umgebaut habe und ich gucke ab und zu unter den Tisch, in den Rechner, ob alles passt.
Kein Spulenfiepen, oder sonstiges, der Lüfter dreht super spät erst an und dann scheinbar auch mit wenig Drehzahl. Habe im Gehäuseseitenteil noch einen 140er Lüfter verbaut, der dann auch noch Luft abführt, denke dann wird das ganze vielleicht sogar noch kühler. Ich bin nach den kurzen Tests wirklich schwer begeistert! Vielleicht spiele ich sogar mal wieder was ;)
Mit was genau? Original adapter oder custom kabel?
Habe den Adapter genommen, der bei der Karte dabei war.
An meinem Corsair Netzteil sind zwei Leitungen angeschlossen, die aber in jeweils 2x8 PCIe Steckern münden, davon habe ich 3 angeschlossen.
Muss mich mal mit undervolting auseinandersetzen, habe das das letzte Mal vor 4 Jahren gemacht.
72 von 120 (34 von 200 auf dem überklebten Label)
Oha, überklebt? Habe meinen Karton nochmal gecheckt, da ist nichts überklebt
@ja-ki
Wo sehe ich das ?
Und ja sie sieht echt Nobel aus die FE.
Ich dachte zuerst das wäre ein Kratzer hier an der Stelle hab meine Lesebrille nicht aufgehabt.
Aber nein ein feines Detail!
achso hatte mich schon gewundert. Man braucht ja bei dem orig. adapter mind. 3 soweit ich weiß. Aber auch dann müsstest du mit dem original adapter ein 450W limit haben und nicht 300W. Auf Netzteil seite bekommst du ja pro 8 Pin 300W raus also 600W. Aber der Nvidia Adapter limitiert
Kann mal jemand bitte ein Bild von diesem überklebten Aufkleber machen wo man das sieht welche Nummer man ist?
Aber ca. 200 pro drop wären echt wenig. Jemand meinte hier mal 2000 wenn ich das richtig verstanden hatte.
Aber könnte ja auch nur eine charge sein und es werdne 10 chargen verkauft pro drop
@flysniper
Aktuell wären es 120+180+200, wenn ich die Posts korrekt gelesen hab. Also wenigstens 500 Stück bei diesem Drop
genau, 450 würde sie kriegen, aber ich habe sie selber auf 300 limitiert, ob ich jetzt 11 Minuten rendere oder 10:45 bei 150 Watt mehr Verbrauch, macht für mich schon einen Unterschied. Wenn ich alle 4 verbinde kriege ich tatsächlich 600 watt, aber ich denke das schafft mein Netzteil nicht mehr.
@ja-ki hast du dich eig schon für ein Wasserblock entschieden? Ich habe aktuell noch die ALC core und WC heatkiller V Bestellung offen ^^
Ähnliche Themen
Antworten
7K
Aufrufe
528K
