[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab eine AB.
Siehe Sammelthread, die ersten ABs gehen ein.
Meine AB ist nun auch da.
Hoffentlich wird die bald normal verfügbar sein ohne Drops... Echt kein bock mehr das abcampen, auch wenn die jetzt easy zu bekommen war...
Wo und wann genau gibts nochmal Ankündigungen diese Woche bzgl. neue Karten?
Ich hoffe noch auf eine 4090 ti Ankündigung^^ Aber bitte nur mit 1x 12vhpwr
Gibt es die 90 Grad gewinkelten 12vhpwr Adapter irgendwo zu kaufen? Lohnt es sich, für mein BQ DP12 850W das BC072 Kabel zu kaufen, oder lässt das sich ähnlich schlecht biegen wie die mitgelieferten Adapter?
Die 90° Adapter von Cablemod werden noch einige Monate auf sich warten lassen. Mein persönlicher Favorit ist:
Wer es besonders eng hat nimmt das Silicon sleeved Kabel.
In 5 Minuten ist ne kleine Keynote auf der CES.. mit ner 4090ti rechne ich jedenfalls nicht. :d
Bin Froh das hier nicht mehr über CPU diskutiert wurde.. hab schon angefangen doch jetzt schon für nen 13XXX zu schauen.. hört auf! :P mein i8700k reicht! ....
würd mein 750 Watt BeQuiet eigentlich ausreichen mit nem 13700k oder 13900k wenn ich nicht viel OC´e?
Bei OC i8700k auf 5,1 Ghz, 4090FE + 200 Mhz auf Core und 1,1V hab ich max 660 Watt gesehen.. :d
Ausserdem ist ja morgen nochmal von AMD ne kleine Keynote... man man man ..
4070TIEEEEEEE AAAAHHHHH sie habens immer noch nicht geschafft ihm beizubringen wie er es aussprechen soll. :)
Drop wieder verpasst:cry: Ist schon Scheiße wenn man arbeiten muss, können die nicht mal abends einen Drop machen:fresse:
Ja und dabei habe ich es auch nur um 15min. verpasst, aber man kann ja nicht ständig aufs Handy schauen oder nebenbei ein F5 Rush machen, grade wenn man noch Besprechungen hat, wo man den Bildschirm teilt. Leider wird es wohl nichts mehr mit der FE wenn nur monatlich Drops kommen zur Mittagszeit.
Der olle 6 Kerner reicht aber sowas von nicht! :fresse2:
Ja, das reicht dicke. Hab auchn 750er bequiet!
Ja kann man nur hoffen das die Mal länger liegen bleiben. Hatte davor auch geschaut, dann essen und wieder verpasst. Muss ich den Heatkiller wohl doch wieder stornieren.
Grad mit dem nvidia support im chat geschrieben.
Wow sowas hatte ich echt noch nie in einem Chat. Also im postivien. Sind echt ausführlich und gehen wirklich auf die Fragen und Bedenken ein ohne irgendwelche copy&paste Zeilen.
Ja, das kann ich bestätigen. Klasse Customer Support. Ich behaupte mal (im Chat) keine Muttersprachler getroffen zu haben, aber solange das Ergebnis stimmt alles im Lot. :)
Die Auftragsbestätigung von NBB ist zumindest angekommen .
Hab echt schon nicht mehr dran geglaubt eine FE zu bekommen.
Freue mich riesig drauf .
Danke Dir für deine Antwort.. aber du musst sagen.. NEEEIIIN du brauchst mindestens noch ein 300€ teures Netzteil, sodass mein Kopf sagt, .. ne, DANN .. dann kaufst du dir das nicht.. Weil, es ist ein riesiger unterschied ob es 1200€, oder 1500€ sind... :d
Jetzt hör mal auf, das Teufelchen auf meiner Schulter zu unterstützen!
Wo sind die Leute, die einem sagen, dass man die Kontrolle über sein Leben verloren hat. Jetzt brauch ich sie!
Karte wurden Versand übergeben .
Verdammt beim Board tut sich nix.
Habe auch eine ergattern können, gerade die Versandbestätigung bekommen. Bin ziemlich erleichtert, da die FE die einzige ist, die ich gerade noch so zum testen ohne Wasserblock ins Gehäuse kriege und ich spätestens Mitte Januar eine neue Grafikkarte für die Arbeit brauche. Bin ziemlich überrascht, da ich genau, als der Drop kam, NICHT am Handy war und erst 5 Minuten später auf den Link geklickt habe und auch direkt erstmal mit Fehlermeldungen begrüßt wurde (unbekannte Adresse, login Fehler, etc.)
Jetzt ist hoffentlich erstmal 3 Jahre Ruhe, bis die abgesetzt ist. Meine alte Karte hat leider immer mehr Probleme gemacht, absolut keine Ahnung wieso.
edit: Übrigens vielen Dank für den Bot, ohne den hätte ich sie wohl auch nicht beim ersten Versuch bestellen können! Es gibt allerdings noch eine andere Telegramgruppe, die 30 Sekunden schneller war. Dürfte aber bei der geringen Nachfrage auch hinfällig werden, hoffe ich!
Nur Geduld! Hermes hat bei mir noch nicht mal eine Sendungsnummer. Karte kommt daher bestimmt nicht vor Donnerstag an. Dein neues Bretterl kommt bestimmt auch bald :)
Ich will mit der mind. 6 Jahre ruhe haben ^^
Schön wäre es! Wenns fürs gaming wäre, würde mir meine jetzige 2060 noch reichen!
Computerteile kann man nur 3 Jahre absetzen, daher "muss" dann wieder was neues her. Ich "müsste" dieses Jahr eigentlich auch Mainboard, CPU und Arbeitsspeicher aufrüsten, aber darauf habe ich absolut keine Lust!
Ähnliche Themen
