[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wer da unbedingt von einem z.B. 10700K auf den 13700K oder noch höher aufrüsten will, hat meiner Meinung nach echt einen an der Waffel :ROFLMAO:
Mir geht es eher um die Max FPS. Ich brauche überall mehr als 100FPS, das schafft die alte CPU aber fast nirgends. Hänge meistens bei 60-80FPS rum.
Die meisten mit einer 4090 zocken doch eh in uwqhd/4k. Wer da unbedingt von einem z.B. 10700K auf den 13700K oder noch höher aufrüsten will, hat meiner Meinung nach echt einen an der Waffel :ROFLMAO: . Bei den meisten Spielen bringt es genau fast gar nichts. Und bei den paar, wo es was bringt, sind die Unterschiede auch nicht riesig bzw. fühlbar, weil man sowieso schon jenseits der 80-100fps zockt. Zudem investiert man in einen halbtoten Sockel. Hätte da eher noch auf Meteor Lake gewartet oder die neuen amd cpus.
Hätte ich auch nicht gedacht in 4K und gibt viele Spiele die gut laufen , aber manche halt nicht .
Bei Dying Light 2 war es bei mir am extremsten , das trotz 70-80 FPS bei der stelle mit starken CPU Limit es total ruckelig wurde gefühlt.
Ich wollte eigentlich auch den 10900K behalten und glücklich sein , aber gab immer wieder Situation wo es nicht smooth war , obwohl die FPS ok waren.
Die Karte braucht das richtige Fahrwerk sonst passt es nicht. Musste ich mir auch irgendwann eingestehen.
@MS1988 und @s L i X
Bin noch unschlüssig, ob AM5 oder Z790
Wie stehen eigentlich die Chancen, den RAM beim 13900K auf 7000MHz und mehr zu bekommen? Oder sind die CPUs und RAMs in der HOF alle selektiert?
Habe da paar mal 8600MHz gesehen :oops:
Die Frage ist wie das mit den Boards aussieht . Denke Raptor schafft 7200 MHZ + ziemlich safe was ich so gesehen habe , aber bei den Boards bin ich mir unsicher .
Da kann es auch sein das bei 6800 MHZ Ende ist , wenn das Board nicht stimmt.
Da muss man sich halt schlau machen diesbezüglich .
Bei AMD ist spätestestens bei 6400 MHZ Ende soweit ich weiß .
Muss man halt nicht so viel Geld für RAM ausgeben :d
Bis eine FE dropt... :coffee:
Willst Du die dann ohne Wakü verwenden?
Oder legst Du keinen Wert mehr darauf, dass die Kühlerdemontage durch den Grakahersteller definitiv erlaubt ist?
Ich frage, weil irgendwie Jeder was Anderes schreibt und meinten, dass man froh sein könnte über 7000MHz RAM zu erreichen (was ja stark von der Güte, des IMC der CPU abhängt)
Easy mit Z790. Ich bin aber auf Z690 gegangen. Sehe nicht ein für das gleiche Brett mit Z790 140€ mehr zu zahlen, obwohl ich die zusätzlichen Lanes und die zusätzlichen M.2 Slots nicht brauche.
Das ROG Z690-F, welches ich mir ausgesucht habe, unterstützt ohnehin maximal 6600MHz. Daher habe ich mir nur 6600er Ram besorgt.
Easy?
Du meinst wohl für das MB. Ein paar unterstützen ja bis 8.000MHz. Aber...
Wieviel höher als 5.600MT/s kann man denn in der Regel?
(ich meine jetzt nicht die paar Ausnahmen in der 3DMark-HOF)
btw:
Mit den neuen Intels kenne ich nicht nicht gut aus
Konnten die User in der HOF tatsächlich 8.000 (und mehr) mit dem IMC fahren?
Das wäre schon sehr krank...
Also n Kumpel von mir hat 7400er@7600 drin, und das läuft. Ist ja kein Geheimnis, dass die Raptoren mehr können, als Intel offiziell behauptet.
Ob die 7800er auch mit 8000 zu betreiben sind?
Wenn man mehr als 7600MHz möchte sollte man schon zum Apex Z790 oder EVGA Boards greifen. Und auch da muss man schon teils was von Hand einstellen. Man kann auch Glück haben, dass 7600Mhz und mehr ohne groß rum zu testen läuft, aber davon ausgehen würde ich nicht.
Ich habe das MSI Z790 Carbon Wifi und 7200er G.Skill und die laufen auch ganz ohne Probleme mit dem XMP Profil. Mehr will das Board aber ohne weiteres nicht so recht.
Mal schauen, was der X3D kann. Wenn der so gut wird, wie erhofft, dann wird aber bei mir auch wieder zu AMD gewechselt. ;)
Hmm. Ich hab die stärksten Rams genommen, die in der Support Liste des Mainboards stehen. Besteht da auch die Gefahr, dass ich rumfummeln muss? Z690 soll ja nicht so gut laufen mit hoch getaktetem Ram.
Garantieren kann dir das wohl keiner, aber du hast ja auch „nur“ 6600er RAM genommen. Die könnten schon ohne Probleme laufen, würde ich sagen. :)
Z790 ist auf jeden Fall problemfreier als Z690. Aber dafür auch meist teurer. Und beim zocken merkt man den Unterschied beim RAM Takt wohl eh gar nicht bis minimal.
Nun aber besser BTT - das Thema passt wohl besser in den Sockel 1700er Thread oder DDR Intel OC Thread. :)
Wenns ein aktuell produziertes Z690 Board ist, sollte der RAM problemlos laufen…
Meines Wissens sind nur die ersten Revisionen nicht so Taktfreudig…
Grund warum ich zb. das Z790 geholt habe war wegen der Probleme die hier Don hatte mit den Boards ,dass die M2 SSD am CPU angebundenen Anschluss nicht funktionierte mit Raptor . Deswegen um dem aus dem weg zu gehen habe ich direkt das Z790 genommen und mit Cashback war es ok .
Also ich habe auf mein z690 master 6400er (max nach qvl) 6800 mit arg strengen timings erreicht (49 ns latency)
da bringen mir je nach Latenz auch keine 7200er oder höher was.
Da hat Nvidia mit der 4090 halt schon auch für Umsatz bei Intel und AMD gesorgt 😂🤣
Ich hab mir Anfangs ja noch eingeredet, die 4090 braucht’s nicht, die 3090 reicht und mit dem Upgrade vom 12900 auf den 13700 bin ich in PUBG gut bedient. Von 5.200Mhz 12900 mit 4.000 DDR4 auf 5.500Mhz 13700 mit 4266 DDR4 hat im CPU limitierten PUBG (1080p/low) schon gut gezogen.
Tjo, zu der 4090 kam dann noch ein 4K Screen und jetzt bin ich wieder zur Grafikhure abgestiegen. 😂
Morgen mit einem neuen 4400C17 Kit noch mal das Letzte aus DDR4 gequetscht lastet man so eine 4090 in PUBG (1080p/low) dann auch irgendwann gebührend aus. Not.
Ja da Nvidia mal was gebracht was wirklich taugt . Da sieht AMD bisschen kacke aus , wenn man ehrlich ist und dann noch Treiberprobleme mit Leistungsaufnahme und dann noch die hotspot Probleme was noch dramatischer ist und nur Rasterleistung sonst nicht so dolle . Nvidia hätte meiner Meinung nach wenigsten den dp 2.1 einführen können mit 4000er , aber man braucht ja ein Argument für die 5090 :d . Denke so ein Leistungssprung wird es erstmal nicht mehr geben .
Das mit AMD und ihren Karten grad ist halt nicht so geil, auch für uns Nvidia Nutzer. Das gibt dem Lederjacken Heino leider eher mehr Spielraum den Preis weiter in die Höhe zu treiben mit neuen Karten.
Der Preis ist zwar für das was man gerade mit einer 4090 bekommt schon irgendwo ok, denn wann hat man jemals in 4K mit 200FPS und mehr gespielt, leise, aber das ist halt trotzdem nen schlechter fucking Monatslohn den man da auf den Tisch legen muss.
Da hast du recht . Wäre auch froh AMD würde besser dran sein mit der 7000er , aber AM5 hat wenigstens Potential . Bei Grafikkarten hoffe ich das Intel in 5-6 etwas aufholen kann , weil die haben Kohle und da ist schon was machbar , wenn die richtigen Leute dran sitzen . Man sieht aber ganz klar das Nvidia mit dem Preis der 4080er total übertrieben hat und deshalb die Dinger im Regal bleiben . Leute die eigentlich die Ressourcen haben holen halt die dicke Karte . Und die Käuferschicht für eine 4080 ist schwierig ausfindig zu machen , aber nach dem AMD Desaster und weil die 4080 gegenüber der 3000er Serie doch gut darsteht kriegen die sicher auch da paar Karten mehr verkauft .
Betreffend dem Pny Lüfterproblem, dass nur 2 der 3 Lüfter erkannt werden und arbeiten: Habe mich mit dem Amazon Support in Verbindung gesetzt, Möglichkeiten waren Rücksendung oder Preisminderung. Hab mir 150€ gutschreiben lassen. Bin mit der Karte ansonsten sehr zufrieden, leise, Temperatur passt und ich höre kein Fiepen/Rasseln.
Wollten die keinen Beweis dafür? Das wäre ja heftig.
Was glaubst du warum Amazon von Jahr zu Jahr teurer wird? :d
Ähnliche Themen
Antworten
6K
Aufrufe
409K
