[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hmm. Mein Bildschirm ist auch neu. Den schließe ich ohnehin aus, weil er mit der 3080 ohne Riser problemlos funktioniert hat. Hab auch ein LinkUp Gen 4 Kabel. Dann wirds wohl daran liegen.
Die Aussetzer sind auch nur 1 sekunde lang, kann ich bis jetzt noch verschmerzen. Aber auf Dauer wirds dann doch auf normalen Einbau ohne Riser mit nem neuen Gehäuse rauslaufen müssen.
Glaube er hat im Austausch für die 2080ti ne 3070 bekommen.
Bis auf die 8GB RAM ein fairer Ersatz (nahezu gleiche Perf) (y)
Ist das die erste 4090 hier, die im Betrieb Tüdelüü gemacht hat?
Und dann noch zu Weihnachten - eine Bescherung 🎄🎁 dieser Art ist natürlich ein Schlag 👊🏻 in die :fresse:
Ja, dann halt uns mal auf den Laufenden. Karte war von Caseking?
Geil wäre eine 4090 mit möglichst lautem Spulenfiepen, die Jingle Belts zirpen könnte :d
Hab seit gestern immer mal wieder kurze, unregelmäßige Bildaussetzer vom Hauptbildschirm. Der 2. Bildschirm läuft immer. Denkt ihr das Riserkabel hat einen weg oder eher die Grafikkarte?
Moni-Kabel könnte es auch sein
So, kurzer Test im AMD System ist durch, die Karte läuft dort unauffällig.
Es muss also irgendetwas "schleichendes" gewesen sein, mal sehen wann ich nochmal rückbauen kann, gleich kommt Besuch.
Denke aber das die Karte dann wieder läuft.
Kann das jemand erklären ?
Vielleicht irgendwas am OS oder Treiber zerschossen?
Anno1800 passt perfekt zu diese Zeit (y)
Weihnachtsmarkt schon gebaut?
Hab mir das Video mal komplett angeschaut. Fand es gut! Besonders, dass du die Erklärungen zu den verschiedenen Einstellungen mit in Game Szenen begleitest. Danke für die Mühe!
Ich wusste auch nicht, dass LG Oleds ein Thema mit Flickering haben bei eingeschaltetem Gsync. Ich bin da glücklicherweise wohl immun dagegen, weil es mir nie aufgefallen ist^^
Ich hätte jedoch noch eine Frage: Du gibst an, dass man neben Vsync auch Double und Tripple Buffering in game ausschalten soll. Sollte man das in der Systemsteuerung denn auch ausschalten oder lieber einschalten?
Danke. Im nvcp kannst du es lassen wie es ist.
Als ich hab noch nie flickering bei meinem oled in verbindung mit Gsync gesehen und hab schon über 7000stunden betriebszeit aufem oled aber vieleicht sind net alle gleich.
Bei meinem VA bildschirm den ich davor hatte hat ich das problem mit Gsync und flickering konnte den nur vsync betreiben war aber auch kein richtig gsync modul verbaut.
Lg oled flickering
Lg hat dazu auch ein statement. Find ich gerade nicht...
Das war das lg statement.
“Gamma for OLED is optimized and fixed for 120Hz by establishing a fixed charging time for OLED sub-pixels. VRR is used when the frame rate is less than 120 Hz. When the OLED TV uses framerates less than 120Hz, the gamma curve is inconsistent with the frame rate," the OLED Association explained. "Therefore, the lower frame rates results in sub pixels that are overcharged, causing flickering of dark gray images, which is noticeable for dark images rather than bright ones, because human eyes are more sensitive to low gray colors. LGD will likely solve this problem establishing multiple gamma curves optimized for lower frame rates."
Und das LGs "Lösungsansatz" 2021 :
Man kann damit die Gamma Kurve Manuell an die FPS anpassen was man für jedes Game einzelnt machen muss ... nur is dieser Fix eher ein Fix für die VRR Raised Blacks Thematik
und hilft eher weniger dem VRR Flicker bei dunkleren Grau bzw bei verschiedenen Grau Tönnen die zusammen auf dem Bild sind ... das ganze war erst vor wenigen Tagen mal wieder ein Thema im LG OLED Thread hier im Luxx wo wir darüber schon öfters geschrieben haben
Siehe oben
Ich selbst seh dieses Grau Flimmern nur selten bis garnich bei meinem LG 48CX OLED .. aber es existiert ... manche sehen es halt nur nich oder sie achten darauf nich und wieder andere stöhrt das Total.
Es gibt ja auch bei LCDs das Gsync Flicker da gibts ja seit Jahren auch unzählige Beiträge im Netz ... da das OLED Bild so klar is weil Glossy Panel und der Schwartzwert so gut fällt es dort halt nur etwas leichter auf
Also aus oder an? Ich weiß gar nicht, wie es war, weil ich da glaube etwas rumgespielt habe.
Einfach alles zurücksetzen. Meist ist beim stamdard ein nvidia symbol dran.
Anhang anzeigen 832054--- Anhang anzeigen 832055
So isses.
Siehe oben
So isses auch 😀
Gut zu wissen. Also liegt es gar nicht an dem oledpanel sondern evtl. am Hdmi controller?
So dann euch allen ein frohes Weihnachtsfest :wink: . Macht nicht so viel am PC . Family Time ;-)
Habt ihr eine Idee ?
Ja neue Grafikkarte, schon seltsam wie die andere Kommentarschreiber hier so mächtig rum eiern. Wenn es beim Boot an den VGA Post scheitert, dann ist zu 99,9% die Grafikkarte defekt. Aber andere können gerne testen bis der Arzt kommt.
Zum Glück habe ich meine Inno selber umgbaut und mir keine ranzige Frostbite mit falscher dreifach Slotblende gekauft. Denn Du bist nicht der erste mit einer defekten Frostbide.
Woran das liegt wissen wir bis Heute nich .. bekannt das es neben LCDs auch OLEDs betrifft isses seit 2019 wo mit dem C9 und deren Gsync Zertifizierung die OLEDs im PC Gaming Segment breiter einzug erhielten.
Wir hatten damals im LG Thread auch mal ne Zeit lang den HDMI Controler im verdacht aber die 2021 oder die 2022 OLEDs hatten glaub ich nen neuen bekommen und es is immernoch so.
Damit werden wir wohl leben müssen und wie gesagt die LCDs betrifft das ja auch schon seit Jahren. ... aber ich hab mich mit dem ganzen Thema nie so richtig groß mit beschäftigt sondern hab
nur hier und da immer mal nebenbei was aufgeschnappt da es mich selbst nich so sehr betrifft bzw ich damit keine Probleme hab da es bei mir nur im Windows Explorer auftritt wenn ich eine TXT Datei
öffene und die Maus bewege ( Dark Mode ... helleres Grau auf dunkleres Grau ) .. und letztens hatten wir eben einen im LG Thread der das bei WOW hat ( graue Stein Boden Textur und dunkler schatten )
.. und ein anderer hat es wenn er auf dem Desktop mit der Maus über die Desktop Icons geht
Gibt dazu auch sehr viele Beiträge im Netz "Gray Flicker"
Auch find ich die "lösung" von LG bzgl der VRR Raised Black Sache nich so elegant weil Aufwendig für den Nutzer das jedesmal selbst für jedes Game einstellen zu müssen
aber auch da bin ich die meiste Zeit von verschont da ich bisher erst 1 oder 2 Games hatte die entweder zu Dunkle oder zu hell waren in Dunklen Bereichen .. zb Metro Exodus
war eins das ich mit "Fine Tune Dark Areas" anpassen musste
Und es gibt auch Leute die sagen das sie das VRR Flimmern bzw Grau Flimmern eben auch sehen wenn Gsync aus is .. is schon recht vielschichtig die Sache irgendwie
vielleicht sind das auch mehrere Probleme die sich aber ähnlich äussern
Ist das ne gute Idee oder eher nicht so?
EDIT: okay, ist eh egal. Immernoch Blackscreens. Kaufe mir mal ein neues DP Kabel, ansonsten ist die GPU wohl hin.
@ alle, deren 3. Lüfter nicht geht
Habe etwas Ähnliches hier im Vid gesehen. Nur, dass der 3. Lüfter @100% dreht (ab 11:04 min)
Natürlich wird niemand von euch an der Karte rumlöten, aber evtl. hat der Fan-Controller einen weg...?
Hoffe, dass die GPU heil ist...
Ansonsten "Club3D-Kabel" kaufen ;)
Ok, aber irgendwas regelt die Fan´s ja ohne Software
Oder der Monitor vllt?
Gab mal einen User, der hatte eine perfekte 3090 Strix quasi verschenkt, weil er dachte, die GPU ist kaputt. Dabei hätte der LG TV nur ein Firmware Update gebraucht :fresse:
Das ist bitter, wenn man als Verkäufer erfährt, dass die GPU null Fehler hatte :ROFLMAO:
Ich will den Tag noch nicht vor dem Abend loben, aber aktuell spiele ich seit über 2 Stunden ohne Bildaussetzer. Hab das DP Kabel in den Anschluss, der sich am nähesten zum Mainboard befindet angeschlossen. Klappt bis jetzt.
Das Riserkabel ist auch wieder eingebaut und das VHPWR wieder ohne knick :fresse:
Also ich habe den LG B1 77 OLED und bei 120Hz mit 117 FPS Lock mit Gsync ist das Flcikering in manchen Spielen ( zb Dark Pictures ) unerträglich. Es liegt halt mehr oder weniger am G-Sync und wenn die FPS sehr viel Schwankt. Mit der 4090er ist das Flcikering gut 80% zurück gegangen , weil Genug Power die Karte hat. Habe nun noch ne andere lösung für mich noch bessere lösung gefunden. und zwar hab ich den LG auf 100Hz gestellt bei 97er FPS Lock ( langt ja auch ) und nun hat sich das Flickering NOCHMAl deutlich verbessert. Ich würde sagen von damaligen 10x Flackern 1x jetzt. Ich Zocke Aktuell Requiem und Callisto und da Flickert rein garnichts mehr.
Anscheinend ist mir das dann noch nicht aufgefallen bzw nicht störend. Da muss ich mal drauf achten
Oh man sei doch froh das du es nicht siehst warum so etwas herauf beschwören wollen.
Sei doch glücklich da mit .
Warum, damit Du dann auch im Problem Club bist? Lol. Ich hatte auch noch nie Probleme mit GSync und 144Hz, und da wird gar nix irgendwo besonders eingestellt oder sonstwas. Läuft einfach. Und ich werde den Teufel tun, Probleme die andere haben auch bei mir zu forcieren.
Ich glaube echt wenn man nicht hier im Forum angemeldet wäre, könnte man zwar weniger angeben und die ein oder andere Lösung eines echten Problems wäre schwieriger zu bekommen, aber gleichzeitig würde man einfach glücklicher zocken. :fresse:
...Es liegt halt mehr oder weniger am G-Sync und wenn die FPS sehr viel Schwankt.
Es liegt weniger an schwankenden FPS, sondern an extrem schwankenden Frametimes. Das kann man sehr gut in Ladebildschirmen beobachten, da dort in den meisten Spielen der Frametimegraph eher wie ein Seismograph aussieht.
Bei einem hellen Bild ist das Ganze nicht wahrnehmbar, bei dunklen Bildern fällt es sofort auf. Daher sind Spiele, die miese Frametimes haben und zum größten Teil im dunklen spielen auch unertäglich am flackern/unspielbar.
Ich kann hier im übrigen auch nur von meinem 65" C9 sprechen, habe aber von vielen anderen Nutzern des C9, C1, etc. das gleiche Verhalten bestätigt bekommen.
Die Titan Karte(von vergangenen Serien) ist doch wie die fe eine Edition speziell nur von Nvidia. Also Partner machen keine eigene Editionen davon. Wie sind denn die bisher kühlertechnisch gewesen? Ok oder war es mehr oder weniger muss für max leistung auf wakü umzubauen?
An die glücklichen Besitzer einer AMP Extreme: wie leise ist die Karte?
Da die wohl nicht lauter als ne Trinity sein werden... sehr leiste. Meine Trinity läuft mit 30% Lüfter auf 60°c. Modded Bios. Also sollte die AMP Extreme AIRO mindestens auf dem Level oder besser sein, falls das nicht der Fall ist.. ist es ein Todesurteil für alle High End Karten.
Die Lüfter finde ich viel zu laut - wobei ich das Silent Bios unter Luft gar nicht erst probiert hatte.
Inzwischen habe ich beide 4090 Airo unter Wasser. Die eine ist zu 100% lautlos, die andere rasselt sehr leise/akzeptabel vor sich hin. Hatte man bei der unter Luft, durch die Terrorlüfter, nicht gehört.
Ähnliche Themen
Antworten
7K
Aufrufe
540K
