[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Jeder wie er mag.
Der neue Besitzer meiner FE baut eh auf Wakü um.
Und für den Test war der hintere Lüfter eh im Weg! :fresse:
Hab mir das Video mal komplett angeschaut. Fand es gut! Besonders, dass du die Erklärungen zu den verschiedenen Einstellungen mit in Game Szenen begleitest. Danke für die Mühe!
Ich wusste auch nicht, dass LG Oleds ein Thema mit Flickering haben bei eingeschaltetem Gsync. Ich bin da glücklicherweise wohl immun dagegen, weil es mir nie aufgefallen ist^^
Ich hätte jedoch noch eine Frage: Du gibst an, dass man neben Vsync auch Double und Tripple Buffering in game ausschalten soll. Sollte man das in der Systemsteuerung denn auch ausschalten oder lieber einschalten?
Als ich hab noch nie flickering bei meinem oled in verbindung mit Gsync gesehen und hab schon über 7000stunden betriebszeit aufem oled aber vieleicht sind net alle gleich.
Bei meinem VA bildschirm den ich davor hatte hat ich das problem mit Gsync und flickering konnte den nur vsync betreiben war aber auch kein richtig gsync modul verbaut.
Zocke auch seit paar Wochen am PG42 UQ da flickert und flackert nichts. Ich kenne das aber vom Dell AW3418DW in minimaler Form. Der Asus hat ja auch das LG Panel, also das ist perfekt finde ich. Wünsche allen hier frohe Weihnachten 🎄
Hier nochmal ein paar Impressionen und die zugehörige Kostenaufstellung:
Anhang anzeigen 831807 Anhang anzeigen 831799 Anhang anzeigen 831802 Anhang anzeigen 831803 Anhang anzeigen 831806
Ziel war es, so günstig wie möglich :fresse2:
Wie und wo gab es die TUF für unter 1900€?
läuft der ram im xmp direkt auf dem board? kannst mir auch per pn antworten falls zu viel ot
Mit einem 13700k hast du generell wenig bis gar keine Probleme mit XMP. Warum auch immer laufen bei der 13ern selbst auf vorher grottigen Boards auf einmal hohe RAM Takte, selbst die Gigabyte Z690 Boards die früher grottig waren machen auf einem 6800 MHz mit M-Die. Weiter habe ich noch nicht getestet.
Frohes Fest
Weihnachtsbaum war dieses Jahr unnötig
Berichte mal wie die bei dir läuft. Besonders der Stockboost würde mich interessieren.
Moin Jungs,
erstmal allen schöne Feiertage.
Ich habe folgendes Problem :
- Inno 3D inkl. Wasserkühler ab Werk
- nie übertaktet, nur mir Curve um 0.945 Volt und 2730MHz Boost betrieben
- bestimmt 200 Spielstunden, alles top.
Heute ANNO 1800 das Update aufgespielt um an Weihnachten mal ein neues freies Spiel zu spielen.
Im Menü um die Bedingungen festzulegen blieb das Bild kurz stehen, danach Reboot, und nun bleibt der PC stehen mit Reading VGA Bios.
- es kommt kein Bild
- aus / ein, stromlos, Kabel abziehen usw probiert.
- auch kommt dem Board das wohl komisch vor, denn er schaltet einen ersten Versuch sogar nochmal aus und wieder an, danach war es das, es bleibt bei reading VGA Bios stehen.
Meine alte mit Wasser vorliegende 1080ti funktioniert umgehend wieder tadellos, ist allerdings mit 4K natürlich unbrauchbar.
Habt ihr eine Idee ?
ich hoffe die inno ist nicht von alternate :d
Schon mal das Naheliegendste gemacht wenn der Kontakt zwischen Board und graka nicht richtig funzt ?
Also die Graka mal aus dem Slot gezogen und erneut eingesetzt ?
Alternativ mal schauen was passiert wenn die Graka im zweiten slot sitzt ob das Prob mitwandert
Wenn nicht ist das NT schon außen vor und die graka auch so das das Board das Prob sein wird.
Wenn immer noch das Prob besteht die Graka mal in einen andern Sys testen .....
Problem weg ....NT oder Board ......Nt testen um den schuldigen fest zu nageln
Problem da ........Graka ist das Prob
thats all
@Scrush
Hmm, leider hilft der Beitrag nicht, zumal du mir nicht sagst was das Problem damit wäre, wenn sie von dort wäre ?
Hab ich nicht mitbekommen.
Habe Sie aber nicht von dort, bin Erstkäufer, habe die Karte nur benutzt.
@Holzmann
Werde über die Feiertage noch einmal einbauen, das die 1080 sofort lief und der PC nicht bewegt wurde, sie auch perfekt saß, das NT auch passt, vermute ich wirklich Graka.
insider ;)
anderen rechner in der nähe? karte rein testen .wenn dort auch tot dann scheint die karte hin zu sein. kontaktiere dann mal inno oder den händler.
Dachte schon die wäre Konkurs oder so. Ich vermute nun, die versenden OC Rückläufer ? :).
Hätte hier einen AMD mit 600 Watt Netzteil, zum Boot sollte der gehen oder ? der hat 2x2, also 4 x8Pin Strom.
Damit könnte ich einen Versuch wagen.
es gab jemanden hier der hat ne wakü inno karte gehabt die kaputt ging. inno hat die karte laut mail verschrottet ohne mit dem kunden zu kommunizieren. alternate hat sich dann auch quergestellt und das ging dann ewig hin und her. weis gar nicht mehr genau wie es am ende ausging
ich hoffe du lebst jetzt noch :d
Ja, aber wie soll das rechtlich klappen ? Käufer meldet Garantie, wie sollen die sich da querstellen, kann Alternate sich mit Inno einigen, die Abwicklung mache ich doch nur über den Verkäufer ?.
Ja für eine Test geht das schon.
wenn alternate die karte zu inno schickt und inno die karte in den müll kloppt und bittet alternate dann dir dann entgegenzukommen aber alternates angebot dir nicht passt.
finde den thread gerade nicht mehr. aber ich würde mich jetzt erstmal an den händler wenden
Einfach sich jetzt hier nicht verrückt machen lassen, wenn die Karte defekt ist, wie üblich bei deinem Händler reklamieren, Inno3d lässt die Garantie über den Händler abwickeln und sollte es dabei Probleme geben, wende dich bitte zb. hier im Forum an den Inno3d Support.
Glaube er hat im Austausch für die 2080ti ne 3070 bekommen.
OK, nehmen dann die 5080 :).
Danke für die Antworten, ich werde berichten. Da will man weil man krank ist mal ne Runde Anno "chillen" und dann das :(.
Und Leistung die ich benötige mit 0,945 Volt immer unter der Belastung mit der 3090 seinerzeit, das Netzteil ist mit 1080Watt und hinten maximal abgelesenen 465 Watt niemals überfordert.
Hab seit gestern immer mal wieder kurze, unregelmäßige Bildaussetzer vom Hauptbildschirm. Der 2. Bildschirm läuft immer. Denkt ihr das Riserkabel hat einen weg oder eher die Grafikkarte?
1080 Watt... Thermaltake ?
Selbes Problem bei mir, habe nen LinkUp Gen 4 Kabel.. ka ob Karte oder Kabel, Monitor habe ich erst seit gestern, vorher die Karte an keinen anderen getestet.
Ähnliche Themen
