[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
4090 Strix :
Bin echt super zufrieden mit meiner 4090 Strix .. gut beim OC und was die Spulen angeht is die auch superleise bei den Games die ich damit zocke zumindest für mein Gehör und Sitzabstand und Umgebungslautstärke ... hab da die Lotterie wohl echt gewonnen mit meiner 4090 Strix
Und auch DLSS 3 Frame Generation hat mich Positiv überrascht nutze das grad bei Spider-Man Remastered was damit echt gut läuft ( für mein empfinden ) und obendrein verbraucht die Karte damit bei Spider-Man bei mir grad nur etwa 300 watt trotz 4K Nativ und Ray auf Max und hab dennoch 95 - 113 FPS was aber natürlich auch an Frame Generation liegt
Und wenn ich dann den EK 4090 Strix Block hab gehts dann auch von 63-68 Grad auf 48-52 Grad beim GPU Core runter mit meinen Wasserkühlungs Komponenten die ich im System hab ( 400 Watt PT )
AutoHDR von dem Spiel ist leider auch kaputt.
Musst dann mal nach der HDR Intensität gucken.
Wenn die komplett runter ist sieht es aus wie SDR .
Muss auf max. zumindest bei mir .
Habe die MS Version installiert , weil ich noch Game Pass Ultimate bis März 24 habe.
Windows + G und dann kann man unter Gaming funktionen HDR Intensität einstellen.
Bei mir sieht es jedenfalls viel besser aus als der normale SDR Modus. Selbst wenn ich gamma @ SDR anpasse ist Auto HDR wesentlich schicker.
Ist aber hier und da nicht so perfekt , aber immernoch besser als SDR , sofern man FALD oder OLED hat.
Darktide hat echt ne schöne Atmosphäre . Macht richtig bock das Game .
Waffenfeedback finde ich auch nicht schlecht .
Wenn ich sie noch hier hätte gerne. SuprimX hat mit Strix OC Bios genau so hoch geboostet wie mit dem original Bios. Auch das Gigabyte OC Bios hat das selbe gezeigt. Immer 2840Mhz boost unter normalen Temps am offenen Fenster auch höher.
Beste Grüße
Bei meiner FE ist der Wasserumbau jetzt erledigt. Alphacoolblock sieht gut aus, wie immer super verarbeitet und ne schöne Dualslot-Blende war ja auch dabei. Delta Wasser-GPU 19-20 Grad bei 450W, knall ich 600W drauf wirds aber deutlich größer und vorallem der Hotspot marschiert dann davon. Stock Boost jetzt über 2800 Mhz, mit OC solide über 3 Ghz in allen Lebenslagen. Und das schönste, der VRAM brauchts bei der Karte nicht ganz so heiß. Keine Abschmierer oder Fehler beim Anwendungsstart/Profilumschalten auf P0 mit +1700 auch wenn der VRAM bei 20 Grad dümpelt. Hab die Folie auf den Pads gelassen und komme unter Last dann in die 50 Grad Richtung. Lief jetzt tagelang so ohne ein Problem. Fein.
Na aber schöne Bilder Bitte!
Was heißt der Hotspot maschiert dann davon bei 600W welchen Temps sprichst du da dann.
Ich befürchte eher, das ist ein größeres Problem bei mir und nach meinen Forschungen sind auch andere AutoHDR kompatible Spiele betroffen.
AutoHDR lässt sich bei mir technisch gar nicht aktivieren. Egal wie oft ich AutoHDR über Win+G-Settings aktiviere oder auch aus den HDR-Einstellungen von Windows 11 heraus. Da ist irgendwo nen Wurm drin.
Ich weiß, dass es früher lief. Nun geht es gar ned.
Natives ingame-HDR diverser Spiele, HDR youtube Videos mit MS Edge usw... sind kein Problem, funzen.
Aktuell ist sie aber undervoltet und läuft auch problems in Darktide und Port Royal mit 4K Customs Settings:
2805 MHz bei 0,96v.
Ich bin von Darktide wieder abgerückt als Stabilitätstest.
Freund von mir von 1070 auf 3080 gewechselt. Seit dem crasht die Shice bei ihm, ohne oc.
Ich, oc raus, Shice crasht wie mit oc.
Shinebar howt das Teil bei dir Zuverlässigkeit raus. Ist wohl nicht überall der Fall. (n)
Shice Windows neo install :bigok:
Kein Bock darauf, alles hier bereits zu Tode konfiguriert inkl. Wakü, Hälfte davon könnte ich vermutlich nicht mehr aus der Erinnerung heraus rekonfigurieren. :rolleyes2: :o
Aquacomputer soll ne cloud einrichten wo wir unsere configs saven können, von mir aus mit login. ^^
Vielleicht kommt in Q1 nen 7000er X3D rein, dann komme ich so und so nicht darum vorbei. Ärgert mich jetzt schon. :o
Hab auch Stock Abschisse gehabt mit Dark Tide.
Nach viel suchen viel mir auf das die Leute auf Win 10 Zurück gegangen sind um das Problem zu lösen.
Wo bei ich meistens was von Leuten mit AMD Cpus gelesen habe.
Bin jetzt auch am überlegen noch mal neu Aufzusetzen.
Auch liest man häufig etwas von Rucklern in Spielen unter Win 11.
Hab neulich ne TUF dort gekauft und wieder Retour geschickt!
Bei mir war der Service vorbildlich .
Lieferung schnell Rückabwicklung schnell.
Bei mir das gleiche mit der TUF (unerträgliches Spulenfiepen). Kann auch nur positives über Saturn/ Mediamarkt berichten. Geld wurde sofort zurückerstattet.
Ich frag mich wie so ein Amazon Scam funktioniert. Man kriegt da doch super leicht sein Geld zurück und als Verkäufer über Marketplace behält amazon ja auch erstmal die Kohle und kann die erst nach einer gewissen Zeit auszahlen
Edit: Ok, habs mal gegooglet. Die wollen einen dann per Mail zu einer Zahlung außerhalb von amazon überreden... Naja wer das macht, dem ist auch nicht mehr zu helfen :LOL:
Genau so :) Nach dem "Kauf" bekommt man eine E-Mail oder WhatsApp Nummer und wird aufgefordert die Bezahlung außerhalb von Amazon zu tätigen. Diese Art von Betrugsversuchen gibt es btw bereits seit Anfang 2021 verstärkt mit dem Mining Boom damals. Scheinen immer noch genug drauf rein zu fallen.....
Bilder kommen noch... erstmal den DDR5 austesten.
Bei 600W hatte ich ein Delta Wasser-GPU von 25 Grad und Hotspot noch mal 12 Grad über GPU. Ansonsten ist der Hotspot nur ca. 8 Grad über GPU. Repaste hab ich schon versucht, hat nichts geändert.
Performance ist aber gut. Im Alltag 60 Mhz mehr als vor dem Umbau, flüsterleise und ultra kompakt.
Kleiner Nachtrag bezüglich enormen Idle-Verbrauch von 40-80 Watt: War doch ne Treibergeschichte. Hatte vergessen beim Wechsel der GPU den Treiber zu installieren 🤦🏻‍♂️ Fehler saß also vor'm Bildschirm. Klassiker halt^^
Jetzt sind es 20-24 Watt in Idle.
Nachdem die Karten jetzt besser zu bekommen sind, wurde die 3090 StriX OC ersetzt:
Ich hätte sie mir grösser vorgestellt :fresse2:
Erste Erfahrungen läuft im Quiet Modus so richtig schön leise. Hat richtig Dampf. Ernsthaft gebencht wird erstmal nicht. Ich gehe lieber spielen.
Der Einbau erst mal noch mit dem Widder. Ich hatte keine Lust das schon vorhandene Corsair Kabel einzufädeln. Dann hätte ich die Rückwand und den Netzteil Käfig auch noch öffnen müssen. :d Beleuchtung muss ich mir auch noch anschauen. Das kommt dann in den Weihnachtsfeiertagen. Sowie der Ringtauch mit den Rechnern von Tochter (RTX 2080 TI gegen 3090 Strix) und Frau (??? gegen RTX 2080 TI).
@Cyrix1206
Eine Lieferung 4080 FEs ist wohl bei NBB angekommen.
Grund: Ca. ab Freitag (ganz genau weiß ich den Tag nicht. Ein Luxxer hatte das als Indiz gepostet) konnte man die 4080 nur noch vorbestellen mit erwartetem Wareneingang am 19.12.
Tatsächlich steht die 4080 FE nun wieder auf "Sofort ab Lager"
Haben die 4080/4090 eigentlich alle den gleichen Kühler jeweils? Oder gibt es 4090 mit Änderungen?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
