[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann man dieses BIOS einfach auf jede 4090 flashen oder wie ist das zu verstehen? Also ich nehme meine auf 450W limitierte PNY, flashe das BIOS drauf und zack kann ich über 600W gehen? Was passiert dann mit der stock Lüfterkurve?
Jop, idealerweise halt mit Wakü, mit deinen Lüftern musst du testen, habe noch von niemandem mit der PNY gelesen. Wenn die Lüfter komplett verrückt spielen sollten kannst du ja einfach wieder zurückflashen.
Nur FE geht nicht
Das BIOS allein macht aus einer Krücke natürlich kein OC Wunder, trotzdem hast du durchweg höhere Scores - vor allem bei Benches die mit GPU statt VRAM skalieren.
Ich rate eindringlich von einem 600W Bios auf der PNY ab, das ist die absolute Kotzgrenze für den VRM.
Du hast nur 14x50A für den Core, dabei ist der DrMOS zwar bis 50A spezifiziert. Empfohlen werden aber nur 40A in der Spec. 14*40A = 560A maximal Core only.
600W für die gesamte Karte sind dann bei 1,1V noch im Rahmen, ich würde aber für daily wirklich dringend davon abraten.
An alle pny interessierten
Ja, habe ich ja auch schon mehrfach gesagt, die PNY ist keine Karte für OC Rekorde, hat aber einen der besten Kühler aller 4090.
Der VRM der Karte ist absolut fine bis 500W, darüber würde ich eher nicht gehen. Für die meisten ist es aber vermutlich eine der besten Karten, da ein Referent PCB vorhanden ist, der Kühler sehr leise ist und auch Spulenfiepen eher kein Problem. AM Ende des Tages werden eh die meisten 4090 undervolted oder bei 450W laufen.
"The shittiest one so far". Außerdem haben ja nun auch hier im Forum bereits einige von sehr nervigem Spulenfiepen bei dieser Karte gesprochen. Also am Ende dieselbe Lotterie wie mit jeder anderen Karte auch. Nur dass bei dieser eben noch der Saft auf halber Strecke abgedreht wurde. Sehr ermutigend. :d
Nice
Welche Arctic AIO hast in der Front? Bist zufrieden mit den Temps und Lautstärke im North?
Edit:
Du hast die AIO ja im Deckel, sorry.
Ja, AIO immer im Deckel, nie vorne. Man bläst sich sonst die warme CPU Abwärme ins Gehäuse und die GPU muss dass dann einatmen statt frischer kalter Luft.
Bin sehr zufrieden mit dem kleinen. Build quality deutlich über der von Lian Li. AIO hat mit dem Strix Z690 D4 gerade so gepasst, bekommst kein Blatt Papier dazwischen. Temps sind sehr gut. Alles auf Noctua umgebaut, auch die AIO. Das Mesh mit 2x140 direkt über GPU und RAM versorgen die 4090 FE zusätzlich mit frischer klarer Luft.
All in all kann ich das Mesh North nur empfehlen.
Hatte heute Nachmittag, als ich die beiden FANs auf der Arctic noch mal gegen Noctuas getauscht hatte, mal etwas Temps in PUBG 1080p/low getestet. Ist noch MX5 drauf, heute noch die Noctua NT-H2 bestellt, die soll noch mal 2c bringen..
Irgendwann, wenn die 4090 ca 50c erreicht, gehen bei der die Lüfter an. Die kühlen sie dann runter auf ca 30c, bis sie wieder aus gehen.
Da fällt mir nur abgewandelt ein: "Lovelace-GPUs sind wie eine Schachtel Pralinen. Mein weiß nie, was man kriegt." ;)
Viel Erfolg bei deiner PNY (wenn sie endlich mal zu dir kommt)!
Hahaha, top. Evtl. passt dann auch noch das Zitat "dumm ist der der dummes tut". :fresse:
Auch ein Update bei mir zu CableMod. Ich habe im internationalen Store ein Custom Cable am 6.12. bestellt (im EU Store ging der ASUS Rabattcode nicht). Nun wurde gestern mit FedEx versandt und es soll schon am Montag kommen. Also liegt mein Kabel wohl nicht ewig auf dem Schiff :banana: :
Wollte auch eher mit dem Video das Teardown zeigen.
Hat schon jemand The Witcher Next Gen probiert? Was reißt die 4090 da so? Hatte nur gelesen, dass die Konsolen massive Probleme haben im 30FPS Raytracing Modus
Da bin ich auch super gespannt, muss aber erst ein anderes Game beenden und deinstallieren um Witcher wieder installieren zu können :fresse:
Habe mir dieses Video angeschaut. Scheint noch alles problematisch zu sein. Ist ja leider mittlerweile fast Standard, vor allem im PC Gaming. Dann stürze ich mich heute Abend lieber erstmal ins Hunt Showdown Event
Ich lade es gerade runter !
Das schöne ich hab es noch nie durch gespielt irgend wer oder was hat mich da immer raus gerissen.
Bei PCGH im Video sagen sie zur 4080 zwischen 40-60 FPS ohne Frame Generation in 4K.
Von wegen die neuen Karten sind schnell genug :fresse2:
Wird Zeit für ne 5090.
Yep, Spiele es auch zum ersten Mal und freu mich drauf.
Hab gerade rein geschaut... so ganz rund läuft es noch nicht nach dem ersten Start. Allerdings habe ich mit DLSS Quality um die 80 FPS und mit Frame Generation um die 120 auf ner 4090. Wenn es nach dem aktivieren von DLSS oder Frame Gen ruckelt, einfach das Spiel neu starten.
Wenn RTSS nichts anzeigt, in den Steam Diskussionen ist ne Anleitung was gelöscht werden muss damit es läuft.
40-60 wäre ja gut. In meinem Verlinkten Video hat er so ca. 30 mit einer 4090 in 4K Ultra+ inkl. RT :LOL: Aber irgendwas scheint da nicht zu stimmen bei ihm in DX12. Ist die Frage ob das nur ein Einzelfall ist
Habe gerade auch mal Witcher 3 gestartet mit dem neuen Update. Alles auf max gestellt mit DLSS Quality. Ich habe so 60 FPS im durschschnitt in 4K.
Ist doch egal, wie es läuft. Hauptsache sie haben den dmg-Bug mit den Ratten in der "Jetzt oder nie Quest" behoben...
Kann das jemand testen? :fresse2:
Unabhängig davon scheint es Leute mit "Top Performance" und "Ruckelparty" willkürlich zu treffen?
Jo auch kurz rein gekuckt 65FPS .
Muss mal kucken das ich den Afterburner zum laufen bekomme.
link wäre schön gewesen find ich nicht!.
Welche 4090 hast Du nun?
mag wer nachstellen mit der neuen version? ich lass erstmal die finger von.
man kann es eventuell in GOG auf 1.32 forcen
vor der burg vom baron.
V1.32
Modded
3440x1440
max ohne Hairworks
197 FPS @ 4090 TUF @ 100% PT non manual OC
Doch, kommt. Möchte auch endlich eine kaufen können :sneaky:
Falls jemand nen NVidia Invite über hat / verkau**... möchte....bitte melde dich 8-)
Meint ihr die Palit Gaming Pro kommt auch als RTX 4090 Version. Hat da schon mal jemand was darüber gehört?
Funktioniet nicht. Schon getestet. Die Mailadresse von GE und NBB müssen gleich sein. Gab wohl auch keine Invitelinks mehr. Letzt Woche haben sie ja massig FE's rausgehauen. EK ist immer noch voll.
:( danke für die Info. Sehr schade. Irgendwie soll ich kein neues Sys bekommen. Aber mal abwarten, soll im Januar ja besser werden lt. NV
Ähnliche Themen
Antworten
7K
Aufrufe
486K
