[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann auch das neue Galax 666W Bios empfehlen damit konnte ich die 11K in Speedway knacken :)
Für die paar Pünktchen mehr ;-) , jucken tut es schon, aber andersherum schon sehr geil was Zotac mit dem Kärtchen aus 495W rausholt..., werde mal ans Feintuning gehen, ob
da noch was zu holen ist...?, und geil wie AM4 noch performt :fresse:
Kannst denn damit mehr als 1,1v ?
Mit max. 1,1 V kommt man mit 600Watt BIOS nicht ins PL. Da bleibt noch etwas Spielraum .
Ne Spannung geht nicht höher, kann aber sein, dass das Bios intern etwas mehr Spannung für den Speicher frei gibt, womit der Takt dann etwas besser gehalten werden kann.
Gibt da schon ein paar Anwendungen aber Speedway gehört nicht dazu, das stimmt schon.
Das Galax bios boostet zwar nicht höher bei mir vs Strix original, aber der effective Clock ist Höher und dadurch 11400SW, 29500PR, 22300TSE…
Power limit hab ich selbst mit „nur 600 Watt“ beim Original Bios noch nicht gesehen, aber halt trotzdem mehr Performance mit dem Galax 666.
Ich denke, dass sind eher Leute, die nicht eingestehen wollen, dass ihr OC Käse ist.
Ich habe absolut keine Probleme mit dem Game. Ansonsten mal Stock laufen lassen.
Hab fast 40 Std. gespielt und 1A bisher gelaufen. Jeder Crash ging auf meine Kappe und wurde durch zu hohes OC provoziert.
Die ganzen OC Profis meinen immer, weil Game X mit 4000 MHz läuft, ist alles stable und das Spiel ist verbuggt. Immer die gleiche Geschichte. Wenn ich mir die Wertungen bei MW2 anschaue… in 140 Std. hatte ich nicht einen Crash außer, ich wusste, dass ich die Stabilität teste.
Musst dir ja nur mal die Patchnotes der letzten 4 oder 5 Updates angucken, in jedem werden mindestens 5-8 Crashes "gefixt" xD
Ich Idiot musste ja ein "running System" ändern und habe bei meiner Strix das 2.1 Bios aufgespielt, hat auch soweit geklappt, aber:
Ich komme nun nicht mehr ins MB Bios, bzw liegt dann kein Signal an über HDMI und ich sehe hier nichts, erst mit dem Windows Start wird wieder ein Bild angezeigt.
Ein Downgrade vom Bios geht auch nicht, da er mir sagt das kein Bios Update erforderlich ist... Hm, hat jmd Rat?
Ich Idiot muss ja ein "running System" ändern und habe bei meiner Strix das 2.1 Bios aufgespielt, hat auch soweit geklappt, aber:
NVFlash?
Hast du beide HDMI Geräte mal eingeschaltet, ob das Bild beim anderen Gerät ankommt? Das 2.1 Bios ist das Gleiche wie V1. Und diese haben den Post Issue gefixt.
War meine erste Idee, ne kommt bei beiden nichts an.
Bei mir Crasht es sogar non OC Aber Wirkürlich .
Sogar CPU RAM Stock.
Das Witzigste mit 3GHZ hab ich Mal 2 Stunden gespielt ohne Absturz.
Und Stock nach 1 Runde gestern auf dem Desktop gelandet ist zum Tot lachen.
Auch kein OC auf RAM oder CPU!
Ich werde Mal die Workerthreads später auf Stock stellen noch nicht getestet.
So die Master ist soeben angekommen...
ausgepackt und begutachtet. Muss noch etwas aufwärme. Die läuft gerade an weil draußen -2°C sind.
Verarbeitung/Qualität der Gigabyte 4090 Master wie erwartet schlecht!
Schrauben auf der Rückseite sind durchgenudelt. Da ist wohl jemand ständig abgerutscht. Bei ner 2000€ Karte springt einem Gigabyte's Qualitätsarbeit ja schon richtig ins Gesicht.
Selbst bei dieser teuren Karte immer noch gefühlt die selben Wackellüfter wie vor 5 Jahren bei den Windforces.
Plastikbomber-Case um den Kühler rum und im 2005er Style der Kühler mit kupferfarbenen Heatpipes. Gutes Design geht anders.
Lüfter/RGB Kabel total steif und nicht gut verlegt. Das Kabel drückt sich so derart vom Kühler weg, dass es über den PCIe Stecker ragt und vermutlich nachher beim Einbauen richtig böse gequetscht wird.
Backplate super dünn, selbst die Halterung die ans Board geschraubt wird alles dünnes Blech. Macht überhaupt kein wertigen Eindruck.
Zum Thema Verarbeitung und Qualität lernt Gigabyte einfach nichts dazu. Bis auf paar RGBs und den Display passiert da nix.
Ansonsten ist der Kühler natürlich ordentlich groß. Wenn der besser ist als bei der FE gibts ne Chance dass ich die behalte. Eigentlich habe ich sie auch nur deshalb unbedingt haben wollen.
Qualitativ macht die 4090 FE auf jeden Fall einen wertigeren Eindruck!
Bei der Qualität glänzt sie wie erwartet nicht. Ansonsten sieht sie natürlich insgesamt trotzdem nicht schlecht aus (Heatpipes sieht man ja nicht unbedingt.
Die Performance und Kühlleistung muss jetzt halt stimmen^^
Die FE z.B. bekomme ich nur schwer auf 60°C in CyberPunk oder Metro Exodus. Da laufen die beiden Lüfter auf ~80% damit man an die 60°C kommt was halt schon laut ist und die FE Lüfter eh ab 50% ein störendes Geräusch entwickeln.
Anleitung
CMD als ADMIN...
Entsprechendes Bios umbenennen -> StrixOCv1Q.rom
Bios im gleichen Ordner wie NVFLASH64
CMD als ADMIN...
cd "Pfad kopieren"
nvflash64 -6 strixocv1q.rom
Mit Y bestätigen
Ggf.:
nvflash64 --protectoff
Haut er mir eine komische Fehlermeldung raus, obwohl ich nvflash64 benutze:
Nimm die Version mal und nur nvflash64 im Ordner behalten.
Ok sehr nice, dass hat einwandfrei geklappt, nun komme ich auch wieder völlig problemlos ins MB Bios. :bigok:
Die 2.1 hat das komplett verhindert, würde mich stark wundern wenn ich der einzige mit dem Problem bin.
Oder hasse bereits gemacht?
Jup thx.
Soo, jetzt mal den RDNA 3 Test lesen.
PS: Mal dumme Frage: Musste ich beim P Profil auch den Schalter vorher auf P umlegen, bevor ich geflasht habe?
Also Druck auf die Nvidia-Preise wird RDNA3 nicht ausüben können, bei der Leistung... :ROFLMAO:
Jup thx.
Ich würde sagen: Ja :d
Dachte ich mir kurz danach, dann habe ich mit gerade das P Bios beim Schalter auf Q Position geflasht.
Dann gleich noch mal von vorn, hach ja 😏
Liegt am Spiel und nicht am Oc, crashed auch im Stock betrieb.
Den Rest kann ich wie beschrieben, so bestätigen.
Die Reddit Foren sind voll damit, die Entwickler sind auch schon mit im Boot.
Ja stimmt. Die sollte man nicht anrühren.
Hatte bei der Pre-Order Beta von 29 auf 16 gestellt und hatte auch Probleme. Dann wieder auf 29 angehoben und seitdem läuft es 1A. Fange auch gleich wieder an.
Macht echt Spaß wen die Chrashes nicht wären.
Kurze Frage: gibt es für die Suprim X mittlerweile ein 600W BIOS, welches in Bezug auf die Lüftersteuerung auch mit dem Stock Kühler einwandfrei funktioniert?
Wie ist die Karte kaputt gegangen? Er sagt ja verwundert, dass da korrodierte Kontakte bei einer neuen ASUS Karte vorliegen.
Dein ernst?
Der hat die Karte gemoddet (Elmor) + LN2 und sich dann wundern warum die dann kaputt geht.... Wieso werden hier eigentlich ständig der8auer Videos gepostet, verdecktes Sponsoring?
Ähnliche Themen
Antworten
7K
Aufrufe
489K
