[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
klar so ist der unterschied natürlich gigantisch. aber 30 fps auf ner 4090 in dem kleinen raum sind lachhaft. ka was da falsch läuft
Bei Portal is das halt Path Traicing das is nochmal ne andere Nummer siehe auch Quake 2 RTX oder Minecraft RTX welche auch auf Path Traicing setzen
Cyberpunk bekommt ja auch bald das Path Traicing Update ( Overdrive Mode )
Ich hab bei Portal RTX so 40 - 52 FPS mit DLSS 3.0 Quality ... mit DLSS 3.0 und Frame Generation währen das dann wohl auch so 80 FPS wie ja auch PCGH in ihrem Bench mit der 4090 hatten .. is doch ok
Weiss nich warum du nur 30 FPS hast da läuft bei dir wohl was schief .. vielleicht hast du im Nvidia Treiber auch die Max Hintergrund FPS eingestellt so wie ich vorhin wo ich noch 20 FPS hatte
nachdem ich das ausgemacht hatte gings ja auf so 50 FPS hoch
fake frames hab ich kein bock. hatte da zwar 120fps in dem raum aber tearing und stuttering des todes weil wohl VRR nicht mehr greift
Dann komm nochmal in 4 oder 6 Jahren wieder da kannst du dann vielleicht Path Traicing Games ohne DLSS und ohne Frame Gene zocken
wir schaffens ja nun grade mal Cyberpunk mit dem normalen RTX vernünftig zum laufen zu bekommen und Path Traicing is da nochmal ne ganz andere Nummer wirst du dann sehen
wenn das Cyberpunk Overdrive Update rauskommt.
Nebenbei nochmal ein Bild von Swat 4 ( 2005 ) mit RTX Remix :
KFA 4090 Noctua Edition 8-)
Derzeit noch mit braunen als Testaufbau, bin aber jetzt schon schwer angetan!
Coole Sache! Wie sind die Temps nun? Und Lautstärke?
Hast du den Kühler der KFA weiter verwendet?
Wo sind die Lüfter angeschlossen?
Aso, falls die Lüfter direkt an der GPU angeschlossen sind. passt das mit der Spannung und Stromstärke überein was die Lüftersteuerung der GPU liefern kann?
Naja ist anscheinend doch nicht gefixt :d Aber habe das Video von dem Kris auch gesehen wie er da vorgeht und was für Tools er hat. Scheint ein echter Vollprofi zu sein. Wenn ich mal so einen Fall habe werde ich den auch mal kontaktieren.
Ich habe ja auch schon viel gesehen, aber das ist ja mal ganz anderer Content.
Der AD102 ist mit 76 Milliarden Transistoren das komplexeste Gebilde das die Menschen jemals hergestellt haben.
Der Typ lötet diesen Chip und den VRAM von Hand einfach mal ab und wieder an. o_O
@***** ich denke wir sind uns einig. Krasses Video.
Wie ist die Karte kaputt gegangen? Er sagt ja verwundert, dass da korrodierte Kontakte bei einer neuen ASUS Karte vorliegen.
Und ist die jetzt ganz oder?
Starkes Video, egal ob ganz oder net.
die karte war nur pcie 8x und roman hat dann versucht die karte zu fixen was nicht ganz geklappt hat
Hast du auch eine Quelle dafür das Cyberpunk Path Tracing nutzt im angekündigten Overdrive Mode?
Das ist nicht lachhaft, hier wird echte globale Beleuchtung verwendet. Bei den Spielen von Heute sind es ausschließlich hier und da paar Raytracing Effekte. Kann man nicht vergleichen.
Solange die 4090 nicht so laut wie ne PS5 ist... Da haben auch immer welche behauptet, die haben kein Spulenfiepen und irgendein YouTuber hatte 20 Konsolen getestet und die waren alle laut.
Tatsache - die Spulen meiner PS5 höre ich eher, als den Lüfter unter Last :fresse:
Hab zum Glück die Guten und nicht die Kack-Lüfter, wie Manche
Dass der VRAM eine, bei Dir, relativ hohe Betriebstemperatur braucht, um stabil zu laufen, höre ich zum ersten Mal.
Hier gibts mehrere Berichte dazu.
ich geh nachher nochmal rein. das kloschüsselambiente war vll nicht der ideale ort :d
Keine schlechte Idee! Aber ist dir der Shice wirklich so wichtig, dass du die Karte nochmal aus dem Kreislauf rausholen und den Block demontieren würdest?
So, habe mich dafür entschieden, die Folie auf die VRAM pads zu legen. Also Aufbau: VRAM-Chip -> Folie -> pad -> Block
(Luftblasen zwischen pad und Folie rausdrücken)
Die VRAM temps gehen nun hoch von 36-40°C auf bis zu 58°C, selbe Stelle in Diablo 2R, wo die Graka 540W braucht, 10min getestet.
Laut den Berichten im overclockers scheint 50-60°C nen sweetspot zu sein. Zufällig treffe ich mit einer Folielage diesen Bereich.
Scheint aktuell stabil zu sein mit +1800MHz, aber fehlt noch Langzeittest. Jedenfalls ist es nun aber besser als vorher ohne Folie.
man man man. ohne passende cpu ist das echt zum heulen :d
Ok!! Aber schafft dein RAM jetzt auch mehr MHz?
Wenn ich mir den Shice durch den Kopf gehen lasse:
Ist der VRAM im Idle doch bestimmt kühl, oder? Und könnte dementsprechend kurz nach dem Spielstart, bevor die gewünschte Temp erreicht wird, abshicen, oder nicht??
:unsure:
Ja das kann passieren, solange er kühl ist. Das ist mir, wenn ich mir den Shice nochmal überlege, auch schon unter Luft passiert. Wenn abkacken, dann recht schnell, teilweise 1-2min nach boot in den Desktop. Das gabs aber schon lange nicht mehr, weder unter Luft noch unter Wasser, und ich weiß auch nicht mehr ob das nicht sogar +2000MHz waren. Dann waren Spiele vom schnellen Abkacken betroffen.
Die +2000MHz liefen in letzter Zeit weder unter Wasser noch unter Luft stabil.
Die +1800MHz waren noch in einer Testphase unter Luft , dann mit Wasser totales Abkacken mit +1800MHz.
Mehr als das ist einfach nicht drin, weder mit Wasser noch mit Luft. Die VRAMs brauchen ihren sweetspot im oc und haben einen cold bug bereits bei bis zu 30°C-40°C.
Es gibt unter den overlockers Berichten auch einen user, der meinte, man soll das oc-Profil mit + auf VRAM nur für games starten. Für alles andere, youporn
:o
usw... dann eben mit Stock settings oder uv, jedenfalls nichts mit + auf VRAM.
Also die Portal RTX Remix Files :
funktionieren wohl nur bei "fixed function pipeline" Games das sind wohl Games die noch vor Shader Model 2 rausgekommen sind ... schade wollte das grade mal mit Elex 2 testen
Der Thread davon :
Da müssen wir wohl auf neue Files warten
Warhammer darktide ist irgendwo nen Härtetest für VRAM oc, werde das Teil auch gleich auspacken.
Aber auch speed way kackt gerne schnell up, aber aktuell liefen 3 runs ohne Probleme mit +1800MHz.
dann frag ich mich aber was bei dir denn dann kaputt is das du da nur auf 30 FPS kommst in dem Raum wo ich 50 FPS hab mit nem 9900K von 2018 der mit 5Ghz Allcore läuft und auch mit ner 4090
4x msaa ha ich genutzt
Hab ich ja auch ... DDR4 4100mhz CL 17 hab ich is nu auch nich der schnellste aber er sagte ja MSAA 4 Fach ... is seltsam da DLSS nen besseren Job macht bei der Kantenglättug
Joa wenn du msaa aus hattest ist klar das du mehr fps hattest :)
Ähnliche Themen
Antworten
6K
Aufrufe
392K
