[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
PNY GeForce RTX® 4090 24GB XLR8 Gaming VERTO™ EPIC-X RGB Triple Fan
Etwas übertaktet hier meine Ergebnisse:
CPU läuft ohne HT und ohne preferred cores
GPU gönnt sich bis zu 450W aber bleibt kühl (64 Grad) und Lüfter drehen mit 1200 rpm
RAM + 1000 Mhz und hier ist meine Voltage Curve:
Mal eine Frage in die Runde. Ich habe seit ein paar Tagen eine TUF OC bei mir verbaut, weil ich wissen will, ob dieses Kärtchen auch bei mir fiepen oder rasseln würde. Die Erfahrungswerte hier im Forum weisen ja auf eine größere Wahrscheinlichkeit diesbezüglich hin. Finde die TUF an sich recht gelungen, daher der Kauf. Jetzt bin ich etwas verunsichert, weil ich bei meiner TUF nichts hören kann. Muss ich mir Sorgen um mein Gehör machen? ;)
Ne, Spaß beiseite. Ich habe die ASUS im Quiet Mode laufen. Mein System läuft komplett stock (nichts übertaktet). Getestet habe ich mit FurMark sowie Time Spy Extreme und Fire Strike Ultra (siehe auch Log Files von GPU-Z anbei). Auch nach ca. zwei Stunden BF2042 und einmal eine gute halbe Stunde Amok durch Night City (jeweils ohne Kopfhörer; Gehäuse geschlossen) war nichts von einem Fiepen zu hören. Ein Rasseln von ca. drei Sekunden war ganz zu Anfang wenige Minuten nach dem Einbau der Karte wahrzunehmen. Allerdings konnte ich dieses Rasseln nicht mehr reproduzieren und es ist bis jetzt nicht mehr aufgetreten. Mein System ist nicht auf Silence getrimmt, da ich mit Kopfhörern spiele (habe drei 140-er Gehäuselüfter sowie die beiden vom Noctua CPU-Kühler jeweils bei 700-1.100 RPM laufen).
Gibt es noch eine Möglichkeit, ein Rasseln oder ein Spulenfiepen irgendwie zu triggern? Habe schon von einigen hier mitbekommen, dass die Karten teils schon bei 200W zum Fiepen anfangen. Aber dann hätte ich ja eigentlich spätestens bei den Benchmark-Tests etwas hören müssen, da hier teilweise für eine kurze Zeit jenseits der 400W erreicht werden? Oder habe ich eine "leise" (d.h. für mich nicht wahrnehmbar) Karte bekommen? Bin leider nicht so erfahren, was ich noch machen bzw. testen könnte. Danke für eure Antworten :)
  • GPU-Z Sensor Log (Time Spy Extreme).txt
  • GPU-Z Sensor Log (Fire Strike Ultra).txt
Ich hab mal an ner Hauptstraße in Berlin gewohnt. Da hab ich auch nie was von meinen Rechnern gehört.
Jetzt wohne ich in der Pampa, und der Rechner brüllt mich dermaßen an...
Es muss nicht unbedingt an Dir liegen^^
Oder habe ich eine "leise" (d.h. für mich nicht wahrnehmbar) Karte bekommen? Bin leider nicht so erfahren :)
Scheint so das du ne Gute abbekommen hast .. is zum Teil halt auch Lotterie und in welchem FPS Bereich du zockst sowie eigene Empfindlichkeit sowie Zimmer Geräuschkulisse ( PC Lüfter )
aber is auch Game abhängig bzw Last abhängig ( siehe meine getesten Games die ich weiter oben aufgeführt hab .. da kommt gleich noch Borderlands 3 dazu das installier ich grad .. das Game "Control"
hab ich auch schon hinzugefügt ... hatte noch bock etwas weiter zu testen aber Borderlands 3 is nun die Letzte Runde für Heute .. so und Borderlands nun auch mit in der Liste )
Die 4090 Strix wird aufjedenfall bei mir bleiben.
Doch natürlich.
Besonders interessant die DL-DSR-Formate.
Macht doch gerade mit einer 4090 richtig Spaß.
Ich habe im Treiber keine DSR Option mehr seit ich den den Neo G8 (32“ 4K 240Hz MiniLED) nutze, deshalb die dumme Frage.
Ich habe heut aber bereits auch festgestellt, dass ich sobald ich den Monitor in seinem OSD von 120Hz auf 240Hz umstelle, keine Custom Auflösung mehr erstellen kann im Treiber.
Ob das gleiche Phänomen auch für DSR gilt, habe ich noch nicht geprüft, das werde ich gleich morgen tun.
DSR zusammen mit einer 4K Möhre wollt ich schon mal testen. Ich fände es jetzt nicht mega schlimm, wenn ich das nur im 120Hz Modus nutzen kann, denn mal ehrlich, mit DSR zusammen mit 4K braucht man wohl eh nicht mehr als 120 … 🤣🤣🤣
Ach und by the way. COD MW2 in 4K Ultra mit HDR auf dem MiniLED, mit DLSS Quality in 180+ FPS - der SinglePlayer. HOLY SHIT!
Man kennt ja dieses Video:
Auf dem G8 mit der 4090 sieht der ganze SinglePlayer aus wie ein fucking CGI RealWorld Render in 180+ FPS 😳😳😳
Purer Grafik Porn der SinglePlayer mit der Hardware.
Also verstehe ich das richtig? Du möchtest so lange suchen und testen, bis Du etwas hörst?
Es ist nicht notwendig eine Situation bewusst provozieren zu wollen, damit die eigene Karte auch ja so fiept wie von anderen beschrieben. Einfach die eigenen Game Szenarien durchspielen und die klassischen Benches. Wenn da für Dich alles fein ist, glücklich sein.
Ich glaube so langsam dämmert es mir, was hier bzw. insbesondere im Coil Whine Thread so läuft... :rolleyes:
Naja nur weil es bei einem der aktuellen Spiele nicht fiept heißt es ja nicht das es nicht vielleicht bei einem Titel in der Zukunft fiept :d Wenn es bei einem der provokativen Titel nicht fiept dann fiept es denke ich gar nicht.
Der "Abspann" bei Unigine Heaven Benchmark hat bisher das heftigste Fiepen was ich kenne. Mit Cheat Engine kann man den mehr als die 1-2 Sekunden die es normal beim schließen des Programmes aufpoppt aktiv halten. Klingt komisch aber ich habe noch nichts gefunden was mehr fiepen produziert.
Nein, kann ich so nicht bestätigen.
Bei meiner TUF musste ich nicht suchen. 3D Mark an und es war da. Cyberpunk an und es war da. Bei relativ wenig Last wie z.B. BF5 fiepte nichts.
Klar kann man mal aus Neugierde suchen ab wann man auch bei ruhigen Karten was hört. Wenn man da allerdings bei 300 fps+ liegt ist es komplett irrelevant. Bei mir war es z.B. in Cyberpunk bereits ab unter 100 fps (ich meine es waren etwas über 80, kann es aber nicht mehr genau sagen), deutlich zu hören. Das suchst du nicht, das findet dich.
Und wer das mal so erlebt hat, dass es eben schon bei relativ niedrigen FPS deutlich fiept, der wird bestimmt auch nicht abwiegeln. Das ist einfach nix, sowas willst du einfach nicht.
Ehm... danke für die Bestätigung meiner Annahme. Ja genau, am besten alle existierenden und natürlich auch noch nicht existierenden Spiele durchtesten, könnte ja 2025 fiepen und dann ist man unglücklich mit dem Kauf. Marty, du musst vierdimensional denken! :fresse:
Dann scheine ich ja Glück mit der Karte zu haben. Oder ich bin taub :fresse2:
Oder Deine Lüfter übertönen es ... so ne Art Gegenschalleffekt wie bei ANC Kopfhörern :unsure:
Manchmal fällt das Fiepen ja wirklich erst nach nem Umbau auf Wasser auf.
Hatte bei meiner Zotac dahingehend auch Bedenken, da die Lüfter von der schon unangenehm laut sind. Ist aber unter Wasser nun komplett lautlos, also alles Bestens.
Ich hätte eigentlich lieber wieder Asus genommen, war aber von den ganzen Fiep-Berichten hier "verschreckt", zumal auch meine 2x 3080 Strix schon fiepsig waren, wenn nicht im UV.
Genieß einfach, dass Du nix hörst ... ist vielleicht der "schwer erarbeitete" Bonus Deiner Club- & Openair Vergangenheit an vorderster Front :ROFLMAO:
Schlechter als Hermes geht gar nicht :shot:
doch UPS :fresse2:
Jepp. Ghost Recon Wildlands und RDR2 in voller 4K Pracht auf ultra sind einfach ne ganz andere Erfahrung als damals auf 1080p und "high". Ich entdecke diese Spiele komplett neu. Wenn das next gen update raus geht es dann auch mit Witcher 3 los.
vor allem mit ordentlich fps.
habe gestern auf dem neuen OLED monitor RDR2 angeworfen und konnte endlich ohne gelbe pissecken und 142fps spielen. wäre das game nicht so träge.... :d
RDR2 ist genau richtig. Ist halt keine Shooterorgie. ;)
Ich empfand / empfinde die Pace als sehr angenehm. Für mich auch immer noch das beste Spiel der letzten Jahre.
von vorne fast ne gigabyte aber keine 4080 :d
  • Haha
Reaktionen: SH
ich seh vor dem geistigen Auge schon die Vergilbung
Die Form der Zotacs ansich? Finde ich nicht verkehrt. Klar, die schönsten bleiben die FE, aber ich muss sagen ich finde viele andere Karten hässlicher. Zum Beispiel die PNY Karten. Oder auch die Palit. Das schaut immer aus wie Kindergeburtstag auf der Kirmes
Also sofern eine kompakte weiße 4090 rauskommt, werde ich in jedem Fall nochmal wechseln. habe ja einen White Build mit Fenster, das wäre dann noch das Tüpfelchen auf dem I. Aber die Zotac wie auch die Gigabyte passen nicht in mein Gehäuse. Vielleicht erbarmt sich PNY ja noch. :d
die gigabyte ist ja eigentlich ganz schick aber gibts halt nur als 80er. versteh das einer. bei gigabyte ist eh der teufel los. :d
2049€ ist schon n schicker Preis. Aber die passt auch nicht in mein Gehäuse :mad:
Davon mal abgesehen ist Inno3d das schlimmste, was passieren kann im Falle eines Defekts.
Ähnliche Themen
Antworten
7K
Aufrufe
486K
