[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ach du scheisse das is ja dann noch Ärgerlicher .. bin gespannt wie sie das dann nun lösen wollen ... müsste ja dann eigentlich erstmal wieder zurück zu NBB
und dort dann alles nachchecken ob noch alles ok is und dann wieder zu dir geschickt werden. Aber warums sie dein Packet nun immernoch nach über 1 Woche bei Hermes
deswegen festhalten is seltsam.
Das kommt auf den Umfang der Beschädigung an. Normalerweise werden leicht beschädigte Pakete von den Logistikern neu umverpackt oder notdürftig mit Klebeband "repariert". Deswegen dauert das auch.. nur sehr stark beschädigte Pakete gehen an den Versender zurück. Das ist aber echt selten. Als Empfänger, besonders bei Hardware, sollte man die Ware aber dann umgehend prüfen. So eine Kartonagen Beschädigung passiert ja nicht aus Luft und Liebe :d
Jup stimmt .. das hatte ich bisher noch nie selbst bei meinen Packeten aber hab ich sschon öfters mal bei anderen im Netz gesehen das da dann nach gebessert wurde mit Klebeband.
Jup absolut sollte man das .. vielleicht auch im Beisein des Zustellers würd ich mal schätzen ... sicher is sicher... aber der is ja meist in Eile und will schnell wieder weg,
4090 Strix von NBB .. Freitag bestellt :
Bei mir kamm grad nun auch die Versandbestätigung mit Sendungsverfolgungsnummer meiner 4090 Strix von NBB .. dann drück ich da auch nochmal ein Auge zu :d
"WICHTIGER HINWEIS ZUR WARENANNAHME:
Bitte überprüfen Sie das Paket sorgfältig vor dem Quittieren bei der Annahme! Wenn der Versandkarton nicht absolut einwandfrei ist, lassen Sie den Schaden vom Spediteur quittieren. Im Falle eines Transportschadens ist es andernfalls nur sehr schwer möglich, eine Versicherungsentschädigung zu erhalten. Nehmen Sie sich genug Zeit, um die Verpackung ausgiebig zu prüfen und lassen Sie sich nicht vom Spediteur zur Eile drängen. Mit der Unterschrift beim Spediteur quittieren Sie gleichzeitig den ordnungsgemäßen Empfang der Ware."
bzgl. 4090 FE drop:
Ich war super fix auf der Seite weil ich die 4080 vorher gesehen habe. Bestellung ging ohne Probleme durch, außer dass ich einmal im Warenkorb nicht absenden konnte (button blieb grau), kurzer refresh hat's geregelt. Danach war die Karte auch noch so 15-20 Minuten verfügbar.
Status war die ganze Zeit auf "in Bearbeitung", eben schau ich ins Kundenkonto und es steht kommentarlos "storniert". Was soll denn der Scheiß. Hotline sagt "kann man nicht sagen warum die storniert wurde".
Bestellnummer hier ist 19014045, hat jemand ne "höhere" die bestätigt wurde?
Also ich habe heute nochmal ne Antwort per Email bekommen. Begründung ist:
"Die Bestellung wurde von der Fachabteilung geprüft und storniert weil Sie bereits eine founders Edition erhalten haben."
Öhm...ja....letztes Jahr ne 3090. Darf man dann keine Karte mehr kaufen? Ist das allgemein bekannt bei NBB und ist nur an mir vorbeigegangen? Ich hab da nochmal rückgefragt.
Währenddessen kann man die Karte bei LDLC jetzt seit ~16h einfach bestellen.
Krass. Wie kann das sein? So verstrahlt können die doch nicht trotz allen möglichen Personalengpässen an den Kunden herantreten? Eine FE for life oder wat? :lol:
Ich vermuite mal der Praktikant hat nur 90 FE gelesen und dann storniert... :-)
Ja die liefern nur nach Frankreich (+Italien+Spanien). Ich könnte es mir zwar mit irgendwelchen forwarding-Diensten nach Deutschland schicken lassen, aber wer weiß was das dann für Probleme gibt im Garantiefall.
Ich könnte meinen Kollegen hier auf Arbeit fragen, der wohnt in Frankreich.... und es sind 10 Minuten dahin :d
So, meine PNY 4090 Bestellung bei Amazon für 2.094€ wurde einfach storniert. Habe dazu weder eine E-Mail erhalten, noch eine andere Info. Wollte grad einfach mal das Datum checken und nun ist die Bestellung unter "storniert" zu finden. Echt Klasse. :rolleyes:
Meine Bestellung vom 02.12. ist noch in Bearbeitung.
Lieferung 12-15.12.
Bin Primekunde (falls das überhaupt eine Rolle spielt).
Evtl. ein Problem mit der Zahlung bei dir? Z.b. Kreditkartenauthorisierung?
Das wäre auch echt Schwachsinn, lebenslanges FE Verbot :d. Ich hab letztes Jahr auch ne 3080 FE erhalten über NBB und gestern eine AB zur 4090 FE.
NBB storniert völlig frei wie die Bock haben und der Support sagt was auch immer denen so gerade einfällt als Grund. War schon bei der 3000er- Reihe so und ist auch jetzt noch so. Ich denke bei deren Drops gehen einfach X mehr Bestellungen durch als eigentlich Ware vorhanden und so wird halt storniert (definitiv nicht chronologisch).
Lieferung 12-15.12.
Hmm naja habe ja nichts verändert an meinen Zahlungsmodalitäten und es gab auch kein Problem bei der Verifizierung der Zahlung über die Bank App. Naja wie auch immer, aktuell ist die Bestellung wieder drin, eben nur mit der Lieferung am 21.12. statt eine Woche früher. Sollte das jetzt klappen ist es auch noch ok.
Mag sein.
Aber dann doch wenigstens lügen mit plausible deniability...also nicht was, wo man die "Fakten" mit einem Blick ins Kundenkonto widerlegen kann.
Und dann auch noch ein Grund der eigentlich nichtmal zum Ausschluss führen sollte.
Wo sind wir hier eigentlich, dass der Händler nach Willkür entscheidet ob ich ~2000€ für ne Karte ausgeben darf. In ein paar Generationen darf ich dann vorher ein Bewerbungsschreiben schicken damit ich ne Audienz beim König für die Chance auf ne FE bekomme?
Mag sein.
Weil es sich besser anhört als "Bevor wir eine AB schicken dürfen wir frei nach Schnauze entscheiden ob wir den Kaufvertrag annehmen oder nicht."
Verstehe was du meinst, aber was hört sich denn besser an an "du hast schon ne Karte gekauft" wenn dem nicht so ist.
Also so oder so kommt doch die Willkür durch...oder Inkompetenz wenn ne 3090 mit ner 4090 verwechselt wird. Weiß nicht was jetzt besser ist für den Händler. :d
Hab auch mal aus Spass bestellt, ich glaub aber nich, dass da am 19. Dez (angebliches Lieferdatum) wirklich was kommt lmao. Glaub eher da stimmt was nicht. Wär aber cool.
Wann hast Du bestellt?
Erst um 15:00 und dann nochmal um 15:20, da ich vorher eine Problem mit der Kreditkarte hatte (und dann Bankeinzug gemacht hab), aber die Amazon-Punkte wollte. Erste Bestellung dann natürlich storniert.
Wieso? EDIT: Ach so, bei dir wurde storniert. Ich gehe eigentlich von selbigem aus. War bei dir auch Vorbestellung oder? Was war das angebliche Lieferdatung?
Auf jeden Fall interessant das LDLC immer noch 4090 Stock hat. Ist halt nur die Frage wie zuverlässig die ganzen Weiterleistungsdienste sind. Dürfte aber ein Indikator sein das wir dann auch irgendwann bald mal frei verfügbare 4090 haben ♥
Nee, habe gefragt weil ich heute Vormittag nochmal bestellt habe und angezeigt bekomme, dass die Karte frühestens am 21. kommt. Jetzt glaube ich wirklich dass nicht Prime Mitglieder benachteiligt werden :fresse:
Ach so haha, ja, das kann schon sein. Bin Prime-Mitglied und da hat man natürlich schnellere Lieferungen, das ist ja u.A. auch Sinn des Ganzen.
An die Leute die bei LDLC bestellt haben: Wie läuft das genau ab? Welcher Lieferdienst verschickt das bzw. an welchen wird das in Deutschland übergeben?
Die Gigabyte Aorus 4090 Master gibt es in DE sogut wie nicht. Mindfactory hat nun wohl 5 Stück... allerdings mit Seltenheits-Bonuspreis...
Wie sind die Strix den so? Bisher konnte vermutlich noch niemand eine Aorus Master mit der Strix vergleichen?
@Thunderburne kann vergleichen :d
Also meine Phantom ging dort mit Chronopost raus, wird in Deutschland dann wohl mit DPD zugestellt, die gehören wohl zusammen.
Wie lange hats gedauert? Oder ist sie noch unterwegs? DPD bringt mich schon wieder ins grübeln...
Die is heute raus gegangen... Bestellt am 30.11.
Grade wieder "günstig":
Ja ich hab auch grad bestellt und meine PNY bei Amazon storniert. Fast 300€ weniger inkl. Versand ist schon verlockend. Sollte sie mir zu laut sein: Für den Preis wird man sie ja easy wieder los.
Ähnliche Themen
Antworten
6K
Aufrufe
400K
