[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
War nicht böse gemeint! Alles gut 👍
Ich würde denen gleich die Fotos schicken und sie mal fragen, was sie davon halten. Würde das erst anstecken wenn Cablemod sagt, dass es passt.
Dann hast du es schwarz auf weiß, falls was ist.
Teil uns bitte hier jedenfalls die Antwort von Cablemod mit; mich würde das schon "brennend" 🧯🔥 interessieren, ob das in der Norm ist.
Hast du einen Tipp wie ich cablemod kontaktieren soll?
bzgl. 4090 FE drop:
Ich war super fix auf der Seite weil ich die 4080 vorher gesehen habe. Bestellung ging ohne Probleme durch, außer dass ich einmal im Warenkorb nicht absenden konnte (button blieb grau), kurzer refresh hat's geregelt. Danach war die Karte auch noch so 15-20 Minuten verfügbar.
Status war die ganze Zeit auf "in Bearbeitung", eben schau ich ins Kundenkonto und es steht kommentarlos "storniert". Was soll denn der Scheiß. Hotline sagt "kann man nicht sagen warum die storniert wurde".
Bestellnummer hier ist 19014045, hat jemand ne "höhere" die bestätigt wurde?
bzgl. FE drop:
Stornierungsroulette, wie immer halt. Das wird definitiv nicht in Reihenfolge bestätigt, kann ich dir aus Erfahrung sagen :d
bzgl. FE drop:
Bei mir die 19014923, über AmazonPay als Gast, weil ich zwischendurch wieder ausgeloggt wurde ausm NBB Konto, AB kam vor ca. einer Stunde.
Ziemlich seltsam der Laden....
bzgl. FE drop:
Die kannste jetzt bei EK sofort abholen :-)
bzgl. FE drop:
Jo da hat sich bestimmt ein NBB Mitarbeiter privat bereichert.
Also nix bedenkliches aus deiner Sicht? Die beiden rechten Buchsen sind vielleicht ganz minimal tiefer drinnen, aber denke das geht schon noch durch
Hast du gesehen was mir cablemod geschrieben hat, das ist generell null bedenklich solange eines der Kabel beim einstecken nicht rausrutscht
In diversen Reviews steht zwar, dass auch die 4090 FE einen Zero-Fan-Modus hat, aber kann mir jemand sagen, ab exakt wieviel Grad die Lüfter angehen?
Gehen an bei ca 54°C, aus bei ca 33°C. Im bereits normalen Desktopbetrieb wirst du die 54°C regelmässig erreichen.
Hab ich gelesen, ja. Zumindest hast du es Schwarz auf Weiß und ich würde es mir aufheben, sollte zukünftig evtl. was an deiner Karte sein.
Es liegt mir wirklich fern dich jetzt weiter zu verunsichern, aber dein Stecker schaut heftig aus und würde bei mir kein Vertrauen wecken.
Mir ist schon klar, dass momentan sehr viele wegen der Steckerproblematik übersensibel sind (mir inklusive). Aber 2000 € sind halt auch kein Kleingeld
Ja ich weiß halt auch nicht wirklich was passieren soll, durch den Druck beim reistecken müssten die dann eigentlich alle gleichaufsein. Mein Originalkabel welches von Seasonic direkt kam und ich weiterverkauft habe sah auch so aus und der User der es gekauft hat hat keine Probleme
AB kam bei mir um kurz nach vier :banana:
Ich bin allerdings etwas erstaunt, weil ich erst 32 Minuten nach der Bot-Meldung mein Glück mit der Founders versucht hatte (vorher war es mir wegen Kind nicht möglich). Da der "In den Warenkorb"-Button aber noch orange hinterlegt war, klickte ich einfach mal auf gut Glück drauf. Es bedurfte allerdings vier oder fünf Versuche, weil der Button zuerst nicht reagierte. Erst dann ging der Button und ich hatte die Karte im Warenkorb. Und weil ich nicht bei NBB angemeldet war, entschied ich mich für Amazon Pay. Die Bestellung ging glatt durch.
Die AB sieht aber so aus, als ob sie ausgedruckt und noch einmal eingescannt wurde. Man sieht eine Art Knickfalz :haha:
Ich freue mich :-)
Dachte ich auch erst, aber der obere Teil ist einfach nur weiß und der untere unter Auftragsbestätigung ist leicht grau, deshalb wirkt das so. Hab gerade auf meiner auch nochmal nachgeschaut.
Obwohl die RTX 4080 und RTX 4090 noch nicht lange erhältlich sind, wurden seit Mitte November bereits mehr als 160.000 Karten ausgeliefert.
habe keine zahlen und auch keine ahnung, aber ist das jetzt viel oder wenig, was war zu 1xxxer, 2xxxer und 3xxxer karten zeiten so drin?
Dachte schon, der Praktikant war wieder am Werk... ;)
Bin gespannt wann dann eure rausgehen .. ich hatte Freitag Abend bestellt und meine 4090 Strix wurde noch nich verschickt allerdings hatten sie ja auch in der Mail darauf hingewiesen das es bis zu 3 Tage verzögerung kommen kann.
Seit Freitag Abend steht meine 4090 Strix auf :
Eigentlich kostet die 4090 Strix ja "nur" 2266 Euro aber 90 Euro Shop Scalper Aufpreis war für mich noch vertrettbar
Das witzige is das die nur etwa 50 min von mir weg ihr Laden haben .. meine Auftragsbestätigung kamm aus D-31157 Sarstedt
Aber da mein 5 Wochen Urlaub eh erst ab dem 21.12 losgeht hab ich da noch die Ruhe weg das eillt bei mir nun nich :d
Bin mal gespannt, ob noch was kommt. Hab über Amazon Pay bestellt, weil bei allen anderen Möglichkeiten immer Fehler kamen. Normal dürfte ich dabei eingeloggt gewesen sein, bekommen hab ich noch garnichts, im Kundenkonto auch nichts hinterlegt. Immerhin bei AmazonPay ist die Zahlung noch in Bearbeitung, gab Zeiten, da wurde ich dort als erstes über ne Storno informiert.
Im ersten Monat wurden 2,8 Millionen PS5 verkauft und wie wir wissen war es sowas von nicht genug ^^
Ne ist nicht die Welt gerade bei der 4080 , aber bei den Preisen ist das auch nicht Massentauglich .
Mittlerweile sind schonmal die Luxxer bedient wie es scheint. Werden auch viele bei ihrer 3000er bleiben , weil die waren schon teuer in der Anschaffung
und da werden die Ottonormalverbraucher die 3060-3080 gekauft haben sicher nicht upgraden und nochmal viel Geld in die Hand nehmen.
Die Masse spielt auch eher FHD oder mittlerweile auch viele WQHD und da tuts auch die letzte Gen. für die meisten games.
Wir sind da eher ne Ausnahme .
Klasse, danke dir für die Info.
Das hatte ich schon befürchtet.
Wieso gehen die erst bei 33 Grad wieder aus?
Da pustet das Ding ja ewig, bis nach ner Zocksession die ganze warme Luft raus ist.
Ziemlich sicher würden die Lüfter bei mir dauerhaft laufen.
Und da die scheinbar Minimum mit 1000 Upm laufen, werden sie gut hörbar sein.
O je - ich bin ein absoluter Fan von silent PC Komponenten.
Für 500 eur Preisunterschied von der 4090 FE zur MSI Suprim X kann man allerdings unter Umständen so Einiges an Lüftergeräusch ertragen.
1st world problems...
Ich nehme mal an, die minimum Lüftergeschwindigkeit und die cut off Temperatur bei der die Lüfter ausgehen, sind hard coded in der Firmware?
Und sogar wenn man die Firmware anpassen könnte, würde man beim Flashen die Garantie verlieren.
Oder weiß jemand wie man die Lüfter der 4090 FE anderweitig unter 1000 regeln kann?
Jemand mit AmazonPay der weder nen Storno noch Bestätigung erhalten hat? Ich habe immer noch nichts und bei AmazonpPay steht in Bearbeitung?!?
Ich konnte heute auch nur per Amazon Pay (express) bestellen.
Bei Paypal (express) kam immer nur die Meldung, dass meine Adresse nicht beliefert werden kann.
Allerdings wurde ich mitten im Bestellprozess bei NBB ausgeloggt (wieso?!).
Nach dem 2 Stunden später noch keine Mail kam, habe ich den NBB Kundenservice angerufen.
Der Mann dort, hat mir erklärt, dass meine Bestellung storniert werden würde, weil sie diesmal ausschließlich Kreditkarten akzeptieren und die Paypal/Amazon express Buttons (unter dem Kassen-Button) nicht dynamisch von der Webseite entfernen können und dadurch alle Kunden die darüber bezahlen eine Storno erhalten.
Im Kassenbereich auf der Webseite war tatsächlich nur KK und Finanzierung aufgelistet.
In meinem Amazon Pay Konto ist die Bestellung seit 20:00 Uhr storniert.
Es ist nun die 7. Woche in Folge und wieder kein Glück. 😭
Ähnliche Themen
Antworten
7K
Aufrufe
541K
