[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es ist ein Fehler aufgetreten, bitte versuchen Sie es später nochmal.
Mit dieser Kreditkarte ist aktuell keine weitere Zahlung möglich. Bitte wähle eine andere Zahlungsart.
Mehr gab es bei mir nicht.
Fragt sich nur, wofür du noch ne zweite 4090 brauchst^^
Weil der Wasserblock für die Reference PCB Karte erst kurz vor Weihnachten kommt und die FE die einzige 4090er Karte ist, die ohne Wasserblock ins Case passt 🥲
Anscheinend gibt es jetzt eine Vorbestellmöglichkeit? https://www.notebooksbilliger.de/nvidia+geforce+rtx+4090+founders+edition+783170
Zu meiner Bestellung vor 20 Minuten hab ich direkt eine Eingangsbestätigung erhalten, noch keine Auftragsbestätigung. Es steht aber schon dabei das die Aufträge manuell einzeln geprüft werden und die AB später folgt.
alter schuh, gabs schon beim letzten mal :fresse: ist dann aber nach kurzer Zeit wieder weg
AB kommt meistens erst gegen 19 Uhr.
die AB kommt meist nach ca. 2-4h
Denkt ihr ich kann mit gutem Gewissen die 4090 FE an einem 750W laufen lassen? Hab nichts besonderes dran, auch die CPU läuft nicht Übertaktet (11700K).
ja das sollte funktionieren, wenn nicht machst Du das PT auf 70-90%
Heute kam mein Cablemodkabel an, bestellt am 17 November. Die Stifte sind unterschiedlich tief drinnen. Auch wenn ich am kabel andrücke kommen sie nicht weiter vor. Macht das was aus?
Kann eigentlich gar nicht sein, weil die Mitarbeiter und unter der Hand verkauft, und NBB bekommt keine mehr, und nur noch verlost... :lol:
So wie die Bestellung heute ablief, haben die definitiv Regeln verschärft. Also möglicherwiese schieben sie der Scalperei und internen Mauscheleien jetzt einen Riegel vor so gut es geht.
Sieht nicht so gut aus, würde lieber den original Adapter nehmen.
Mein im Oktober bestelltes Kabel ist immer noch in Shenzhen im Van
Ja das ist ja genau das was nicht sein sollte. Cablemod anschreiben die schicken dann ersatz nachdem du das jetzige zerschneidest.
@hwk
wtf? frag da mal nach.
Mein bestelltes (konfigurator) am 21. november ging heute in den Versand
@hwk
Warum sollte das nicht sein? Was ist daran gefährlich?
Lg
Läuft hier bis Dato astrein (y) Hatte mit Stock getestet und UV läuft aktuell.
Finde gut, dass der Euro wieder etwas stärker ist. Macht den Preis deutlich attraktiver aber da geht noch was!
Hmm... letzte Woche eine MSI 4090 Suprim X bei Scalpernate für 2360 eur bestellt.
Jetzt grade mal ne 4090 FE für 1867 EUR gesichert (wobei ich nur bei den Vorbestellern dabei bin).
Das wären satte ca. 500 EUR Unterschied!
Die MSI Suprim X (bzw. früher Trio X) ist seit der 1080er meine Lieblingskarten-Serie.
Der leistungsstarke Kühler und vor allem der Zero-Fan-Modus haben es mir angetan - die Lüfter fangen erst bei 65 Grad GPU-Temperatur an zu drehen.
Bei der 4090 FE habe ich etwas Bedenken was die Lautstärke angeht.
Scheinbar sind die Lüfter ja Brummkreisel und man muss ne 2000 EUR-Karte etwas modden, damit die erträglich werden. (Vlies kleben oder 2-3mm anheben, was ich hier kürzlich las.)
In diversen Reviews steht zwar, dass auch die 4090 FE einen Zero-Fan-Modus hat, aber kann mir jemand sagen, ab exakt wieviel Grad die Lüfter angehen?
Ich hatte mal eine ASUS Strix 3090 da.
Bei der springen die Lüfter ab 55 Grad an.
In meinem Case hat die Karte leider immer diese Temperatur erreicht.
Was passierte war, dass der Lüfter >55 Grad angesprungen ist, dann ein paar Sekunden lief, wodurch die Temp. wieder unter 55 kam.
Nach 1 Minute ist der Lüfter dann wieder angesprungen.
Also ständig an-aus-an-aus-....
Das war extrem nervig.
Die 3090 Suprim X hat dann bei 58 Grad vor sich hingeschmort, aber die Lüfter sind im Dekstop-Modus nie angesprungen.
Hmm, also ich finde langsam drehende Lüfter im IDLE besser wie ganz aus oder besser gesagt ständiges an/aus. Sogar bei meinem Netzteil hab ich den Semi-Passiv deaktiviert.
Da würd ich die 500 euro easy nehmen
Zero Fan ist doch super, meine 3080 ist immer aus wenn ich nicht zocken. Ist doch klasse wenn sich der Lüfter nicht unnötig dreht / verschleißt. Konnte nie erkennen das der Lüfter ständig an und aus geht (.. und der PC steht direkt neben mir).
Hach ist das wieder toll, da liegt man schon krank daheim aufm Sofa rum, das Handy direkt neben sich und dann ist die free-trial Zeit der Pushover App seit gestern abgelaufen und man erfährt erst vom FE Drop als es mal wieder zu spät ist :wut:
Dann nimm doch Telegram mit FE Part Alert oder Datenheim, damit verpasst du keinen Drop mehr :-)
Ich hatte das Vergnügen, dass der Telegram Bot anschlug während ich an der Kasse beim Netto stand. Die ersten Versuche mit Paypal Express liefen schief und da sonst nur Kreditkarte ging (habe keine) gab ich erst mal entnervt auf. 10 Minuten später, habe ich es nochmal probiert, kam immer wieder der selbe Fehler bei NBB:
Also habe ich es über Amazon Pay (Express) probiert und siehe da, Bestellung ging durch. Allerdings hatte mich NBB zu diesem Zeitpunkt wieder aus meinem Kundenkonto abgemeldet - warum auch immer.
Zumindest hatte ich schlau reagiert und das Random-Konto mit der Passworteingabe registriert. Seltsamer Weise habe ich aber überhaupt keine Mail zu irgendwas erhalten - weder Amazon noch NBB.
Bezahlung steht aber im Amazon Pay Konto drin und Screenshot von der Bestellnummer habe ich auch. Oh maaaaan, ich hoffe das geht durch. Nach 7 Wochen des Wahnsinns bin ich so langsam aber sicher erschöpft. 😔
-> Tip: installier Dir Telegram und binde den HWL GPU Verfügbarksthread ein.
Die App war ja super bis gestern ^^ aber dass genau 1 tag vor drop die trial zeit abläuft kotzt mich ja schon leicht an gerade :d
@xl_digit hatte in der pushover dank @ralle_h den best deals thread hier drin, aber wechsel jetzt dann doch mal zu telegram ;)
Weiß hier jemand wie genau das funktioniert wenn man nach Kauf bei NBB ein Kundenkonto registriert hat? Ich versteh nämlich nicht, wie ich mich in dieses Konto einloggen soll, wenn ich doch nur ein Passwort vergeben konnte. :unsure:
Mit dieser Aktion geht es jetzt den Scalpern an den Kragen, die werden ihre überteuerten Karten jetzt nicht mehr los.
Da man noch Rückgaberecht bis 31.01.2023 hat bei NBB könnten ehemalige FE-Käufer ja vielleicht einen Rabatt einfordern.
Ähnliche Themen
