[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
weniger als 24 stunden noch und sie hat noch nicht die 3k mauer durchbrochen, was da los :d? ... hätte ich das geld würde ich mitbieten, da die strix die einzig wahre karte bei den 4090 zu sein scheint ;)
Bleib mal locker warum gleich so pissig ? Is doch nur ne normale Diskussion und kein Angriff von mir
Schau einfach in den Sammelthread, verstehe hier noch nicht mal den Sinn der Diskussion.
Deine Behauptung: Wakü bringt nicht viel bei einer 4090 ?
Dann schaue mal in den Sammelthread. Statt dessen soll jetzt das Youtube Video als Beweis her halten? Ziemlich dünne Statistik.
... wie da nun die Gehäuse Luft is weiss ich nich da hab ich kein Temp Sensor .. jedenfalls is meine Zimmer Temp immer so 19-21 Grad und mein Wasser beim Zocken
Dafür das Du nicht viel messen tust, stellst Du ja ziemlich viele Behauptungen und steile Thesen auf. Bei 400 W mit einer luftgekühlten Grafikkarte ist die Gehäusetemperatur 3 - 6 K höher. Hängt natürlich von der Anzahl der Lüfter etc. ab.
Ich schrieb nicht umsonst Pullover. Denn bei 20 °C Gehäusetemperatur ist die Zimmertemperatur deutlich kälter. Natürlich nicht wenn man einen kurzen Benchmark mit einer Minute macht. Man sollte aber unter den gleichen Voraussetzungen testen.
Wie viele von euch treten ihre RTX 4090 bis zum letzten FPS?
Also ich lasse sie schön undervolted in Kombi mit dem 5800X bei maximal 117 FPS bei UHD und 120Hz laufen. Reicht mir dicke. Temperatur ist meist nie über 60°C.
Zum einen hab ich nur 1 Beitrag an Thunderburne geschrieben und du bist dann in die Disku eingegestiegen wegen den 60 Watt bei 400 Watt bei Luft seiner 4090 Strix
und fragtest welche Karte und kammst dann halt mit Gehäuse Temp usw an obwohl es da grad nur um die GPU Core Temp ging und dadurch wurde die Sache halt einfah nur komplexer.
Und zum anderen sag ich garnich das Wakü nich viel bringt ( nutze ja selber eine .. siehe bilder weiter oben ... und meie 4090 Strix geht dann ja auch unter wasser )
sondern das sie bei der 4000er weniger bringt als bei der 3000er da die 4000 Kühler größer sind von Haus aus und somit effektiver aber das ne Wakü bei ner 4090 nix bringt hab ich nie gesagt.
Lediglich vermutungen wie es sein könnte bei seiner Strix mit Wakü basierent auf meine Amateur haften Erfahrungen mit meiner Karte und 400 Watt sowie werte einer 4090 FE @Stock und mit EK Kühler :
8-15 Grad bringt es grob .. also für mich lohnt sich das halt schon und hab auch nie was anderes behauptet
wenn du den verlauf unseres Gesprächs dir mal anschaust wirst du jemand anderen finden der sagte das Wakü nix bringt bzw unnötig is .. denke mal du hast mich mit dem verwechselt
Ich glaub du nimmst das nur alles etwas zu ernst ... ich hab lediglich ne schätzug abgegeben wie es bei der 4090 strix mit wakü bei der GPU Temp bei 400 Watt sein könnte
und wollte da keine Wissenschafft draus machen und dann kammst du halt dazu mit den ganzen anderen Kramm ders viel zu komplex gemacht hat
Nochmal : ich bin kein .. ich wiederhole .. kein Wakü Profi !!! Und habe da bei dem Beitrag auf den du reagiert hast lediglich ne schätzung abgegeben
Bin immer wieder erstaunt über die Agressivität mancher User hier im Forum .. ihr müsst mal lockerer werden die Welt is schon scheisse genug da drausen
Super cool story bro.
Ich checke einfach denn Sinn nicht von mehr FPS als das Display an Herz zu bieten hat. Deshalb frage ich.
Würde zB auch nicht meinen 5800X gegen einen 5800X3D zum selben Preis tauschen, weil mir das absolut nichts bringen würde.
Hauptsache die 4090Ti kommt auch auf dem Founders PCB, dass wenigstens der Wasserblock noch passt ;)
Mit 24 GBps Speicher, vollem Cache und 18xxx shadern, selektiertes Silikon mit 2.8 Ghz stock boost, da geht schon noch was.
Dass wir auf der 4090 aktuell nur Ausschuss bekommen siehst man doch an den Profikarten mit 10% mehr Einheiten und 350W.
Die Frage ist, wie viele gute AD102 kann NV für >5k an Datacenter und Workstation-User absetzen. Solange man da keinen krassen Überschuss hat, gibts keine 4090Ti.
24GB 🤔...
Schau mal was ich habe...
Meist stimmen die Infos auch am Ende aber nicht immer, da sie bekannterweise vom Hersteller kurzfristig geändert werden können.
Amazon hat gerade meine Zotac 4090 AMP Extreme storniert, Freitag bestellt und jetzt wieder verfügbar für 600€ mehr. Ein Schelm wer böses denkt. Da freut man sich doch:d
Verkauf & Versand von Amazon?
Bei MM oder Saturn bekommst Du sie hier über den Bot meist auch ganz preiswert zu nem akzeptablen Preis ... gerade vorhin wieder für 2269 €.
Verkauf und Versand von Amazon!
Preis war 2119,12€
Hab natürlich mal angerufen und gefragt weshalb storniert wurde. Die Antwort war: unbefugter zugriff. Hab gefragt wieso dann der XXL Wäschesack und kleinkram für meinen Säugling nicht auch direkt storniert wurde. Kam das typische blabla :d Kriegen halt alle den Hals nicht voll.
Ja hatte die Karte vorhin bei MM gesehen, war aber schon ausverkauft
Oh, ok ... das war natürlich ein richtig niedriger Preis.
Ärgerlich, hat vielleicht wieder ein Azubi den Preis falsch angelegt gehabt? Hab ich bisher zumindest noch nie so niedrig gesehen. Meine erste hatte vor knapp 3 Wochen noch 2189 € gekostet, die zweite vorletzte Woche dann 2199 €. Dann kam der Sprung auf 2269 €.
Wenn Du mal die ersten Reviews der Karte von Oktober liest, wirst Du 2279 € als angekündigten UVP sehen :unsure:
Ah okay (y) .. die Abkürzung kannte ich noch nich .. hoffentlich vergess ich die nich wieder .. werde sie aber weiterhin ausschreiben gibt schon genug verwirrungen um abkürzungen.
Ohne ABP nehme ich an?
Mit ABP stelle ich mir den Ausbau extrem aufwändig vor, um an den sch… Entriegelungshebel zu kommen
Also ja ohne Aktiv Backplate nur die ganz normale Version mit Passiver Backplate wirds bei mir werden für die 4090 Strix
Bei meiner 3080 Strix hab ich garkeine Backplate drann weil beim Standart EK Pack die Backplate damals nich mit dabei war und ich sie auch nich für sooo wichtig halte und Optisch is das auch kein Problem
da ich nen Vertical Mount hab. ... bei dem neuen Block is die Passive ja aber gleich mit dabei und werd die dann diesmal auch drann machen denk ich.
Schätze mal das ne Aktive auch nur ein paar Grad bringen würde und die Karten haben hinten kein VRAM mehr wie noch die 3090 wo das noch mehr Sinn machte als jetzt
wo die Karten hinten kein VRAM mehr haben.
Aber spricht natürlich auch nix dagegen wenn Leute die mit Akitver Backplate nehmen ich gehöhre aber nicht zu diesen Leuten mir reicht es Blank oder zumindest mit Passiver Backplate
Problem ist oft, dass sie dann schon weg sind.
Man sieht dann lagernd/versandfertig und kann die dann aber nicht im Warenkorb einfügen.
Naja, kommen auch wieder Tage dann sind die durchgängig verfügbar 😃
Der EK 4090 Strix Kühler is halt 26cm lang sind halt 3cm mehr und kommt wohl daher da EK hinten noch son Schwarzes Plastik Teil drann hat also der Block is etwas größer
als die eigentliche Karte daher is der halt 3cm länger ... aber dennoch is ja 26cm besser als 36cm ... bei mir is halt bei 33cm die Grenze wegen meinem AGB .. wird nächste Woche
lustig die 4090 Strix erstmal Provisorisch in meinem Gehäuse unterzubekomen da mir mein AGB halt sehr viel Platz wegnimmt ich ihn aber nich umsetzen will daher wird das
erstmal bis ich den EK Block hab ne Frankenstein Aktion bei mir um die 4090 Strix in mein Gehäuse zu bekommen ... aber is ja dann nur für ein paar Tage oder max ein paar Wochen
je nach lieferbarkeit des EK Strix Blocks ud je nachdem ob meine 4090 Strix was das fiepen angeht für mich okay is.
Ich kann halt nur sagen wie es bei mir is und ich bin auch kein Wakü Pro sondern nutze Wasserkühlung erst seit 2018
mit 400 Watt so bei etwa 32 - 35 Grad ( gemessen durch meine D5 Next Pumpe ) und die 7 x 140mm Lüfter drehen auf 1200 - 1500 Umdrehungen je nachdem und meine GPU Core bei 48-52 Grad
Is halt nich das beste Wasserkühlsystem was ich hab aber das hab ich auch nie behauptet und ich raff nun auch nich was dein Problem is und warum du gleich so pissig bist ?
Mein Aktuelles System noch mit der 3080 Strix ( Nächste Woche dann mit der 4090 Strix )
... nich besonders schick aber Funktional. .. Case is das Cooler Master Cosmos 700M ( Ohne die Front die hab ich abgemacht is dann ne Mesh Front )
--- Anhang anzeigen 824405--- Anhang anzeigen 824407
Es ist schon so, dass sich WaKü für die GraKa nicht mehr so sehr lohnt wie bei den 3000ern oder 2000ern, wo Karten auch gern mal bei 75-85G unter Luft landeten.
Durch die „fetten“ Kühlkörper und mehr Anpassungen hat man mMn sehr gute Temperaturen mit den 4000ern Karten.
Und das sage ich, der auch 2 Mora 420er an einem System betrieb. 😊
Heißt halt nicht WaKü ist sinnlos. Aber wenn die 4090 mit 60-70G bei Volllast läuft (bei erträglicher Lautstärke) , ist der Umbau weniger lohnenswert wie zu „damaligen“ Zeiten. Gibt genug Spiele die lasten die 4090 eh nicht aus und man kann 70-80% PT einstellen und erreicht seine Ziel-FPS dennoch 😬
Klar wird es genug geben, die für die 10-15G bessere Temperaturen umbauen werden und der idR leiseren Geräuschkulisse.
Oder halt wenn man einen 13900K/12900K(S)/13700K mitkühlen will. Da macht es sicherlich Sinn, CustomLoop zu gehen und alles unter Wasser zu setzen.
Lass dich hier net ärgern 😃
Hab jetzt bei MM gerade eine bestellen können.
Ja war lt. Geizhals tatsächlich einer der günstigsten Preise. Pech gehabt würde ich sagen :d
Bei mir gings bei der 3080 Strix und 400 Watt mit Luft ( 72 Grad ) halt mit Wasser auf 48-52 Grad mit 400 Watt ... sind in meinem Fall mit meinem Wasserkühlsystem so 20 Grad weniger
bei ner 4090 wären es geschätzt dann auch wieder so 48-52 Grad da ich in beiden Fällen auf 400 Watt limitiere allerdings packt die 4090 Strix unter Luft
( bei gleicher zimmertemp wie bei mir ) wohl so um die 60 Grad bei 400 Watt was dann statt 20 Grad nur noch 10 Grad unterschied sind. ( Hypotetisch in meinem Fall bevor sich wieder jemand angegriffen fühlt :d )
Ich schätze halt hier nur.
jup manch einer ( wie ja zb Thunderburne ) überlegt ja auh schon auf Luft zu bleiben da der Luft Kühler eben ne Gute Leistung bringt
Eben ... Sinnlos isses absolut nich nur wie du schon richtig sagst nun weniger Lohnenswert wenn man nun nur auf die Temps achtet.
Bei mir sinds wie ich jja schon sagte nich nur die Temps sondern das Basteln macht mir auch spass und das RGB sieht besser aus ( is geschmackssache das is klar )
und niedrigere Temps auch wenn es nur 10 Grad sein sollte bringen die eine oder andere Taktstufe höher sowie Stabileren Takt und ich hab eh schon nen Costum Loop
daher geht meine 4090 Strix die diese Woche bei mir ankommt dann auch unter Wasser
Ja manche scheinen halt echt richtig bock auf Stress machen zu haben is nich nur in diesem Thread so .. versteh solche Leute halt nich und sowas hilft auch niemanden weiter
wenn wir uns hier gegenseitig anfeinden.
Ja der Luftkühler macht sogar in Dying Light 2 wo überwiegend 440 Watt Verbrauch anliegt einen echt guten Job . (Tuf OC)
Da ist die Graka komplett gefordert wegen Raytracing ähnlich wie auch in CP 2077 und da liegt der Vebrauch @ Stock 420 Watt.
Da hat Nvidia auch gut das PL dimensioniert und die Karte hält sein Taktraten vom PL her gesehen.
Habe daher entschieden gehabt die Custom mit Mora 420 abzubauen und zu reinigen und erstmal in den Keller in Kartons zu räumen.
Mir ist da der Luftkühler zu schade den abzumontieren und für meine CPU reicht eine AIO @ 360er sowas von aus selbst mit OC.
Zudem habe ich schon bei der 3090 gemerkt , dass das Wasser immer wärmer wird. Früher sagte man 30°C wären warme Brühe,
aber erreichte dann schon 32-33°C Wassertemp um diese Jahreszeit und im Sommer dann schon 36-38°C Wassertemp.
So da hatte aber die 3090 noch eine Delta von 14 Kelvin und hier bei den 4090er fängt das erst scheinbar bei 20 Kelvin an^^.
Der einzige Vorteil bei einer groß dimensionierte Wakü ist halt , dass man das System wirklich silent bekommen kann.
Dennoch auch mal schön den Mora 420 mit HK Tube D5 hier nicht noch sepparat rumstehen haben zu müssen, aber das allerschönste ist vorallem
nicht die Warterei auf den Watercool HK GPU Kühler zu haben. Das ging mir schon bei der 3090 auf den Keks , weil da war der Luftkühler unterdimensioniert .
Das Leben mit einer gut gepflegten IL ist einfach viel entspannter 🙈🙉🙊
Bleiben ja mehr als reichlich vernünftige, sachliche & sympathische Leutchen übrig, da der kritische Anteil "oller Stinker" weit unter 5 % liegen dürfte (y):d
Falls es das hier schon gab, sorry, hab das ganze Wakü Zeug geskipped :d
Man muss sich ja auch gegen die "bösen" Boardpartner durchsetzen können :d
Die tuen mir echt teilweise leid . Irgendwann gibt es wirklich nurnoch Nvidia only , wenn das so weiter geht .
Yeah die Preise sinken schon. :LOL:
Bis nächstes Jahr komme ich eh derzeit nicht zum Zocken (wüsste auch derzeit nicht wirklich was).
"Warum sollte Nvidia denn Anpassungen des Preises bei Kursschwankungen des Euros machen? Die verkauft sich doch trotzdem"
Weiß zwar nicht wen Du da zitierst, aber ich sehe das genau so. Wenn das wirklich offiziell ist, dann verstehe ich den Move von NVidia nicht. Die Karten sind zumindest in Europa stets sehr schnell ausverkauft. Klar, nicht überall wie in Deutschland binnen Sekunden, aber nach ein paar Stunden sind die auch in Frankreich etc. verkauft. Vielleicht schieben sie dafür ja ein paar mehr Karten in den Markt. Sind die Ampere Karten alle an den Mann gebracht?
Aber gut für uns Kunden natürlich. Eigentlich müssten die Vendoren dann nachziehen?
Ja, auf der Basis hats auch meiner Meinung nach keinen Sinn.
Einzig um im Vorgriff auf den Release der 7900 XT(X)-Karten (etwas) besser aufgestellt zu sein, wäre für mich eine Erklärung für die Anpassung.
Ja also notwendig nach Verkaufszahlen war die Senkung maximal bei der 4080, wobei die FE auch wegging.
Aber warum beschweren, ist doch an sich gut :d
Absolut richtig, möchte nur Dinge gerne nachvollziehen können. Aber gut, da müsste man wahrscheinlich inne Vorstandssitzung mit Lederjacke reinhören können. :fresse:
Hoffe aber dann dass sie wirklich ein paar mehr Karten in den Markt schießen.
Für die nächsten paar Jahre werde ich extremes Nachsehen haben 😭😭😭
Was ein Biest und man sieht die GEIL aus!!! 💔😭
Zu Recht die beste RTX 4090 Version!
Aber, 😏...
Meine Gigabyte Gaming OC hat einfach mal 4 Jahre Garantie und das ist ein sehr gutes Argument für das Weiterverkaufen, was ich machen werde bevor ich mir eine RTX 5090 besorge 😆 MUAHAHAHA 👏
Ähnliche Themen
