[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Is doch keine Panik die du verbreitest sondern ein ganz normales Gespräch über Möglichkeiten .. ich sehe halt nur die Vorraussetzungen noch nicht erfüllt sodass diese Möglichkeit eintretten kann.
Auch Preislich währe eine 4090 Ti momentan ziemlich Hart das wird noch dauern.
Aber wie du schon sagst : Warten wirs ab :d
Mir wäre das relativ egal , wenn da in paar Monaten ne 4090 TI käme . Die 3090TI hat mich auch nicht gejuckt . Mehr als 10% Mehrleistung sind da eh nicht drinne höchst wahrscheinlich.
Hoffentlich behältst Du mit den ca. 10 % Recht - sonst würde ich schon wieder unruhig 😅
Nur 10% hätte den Vorteil, dass man seine 4090 noch relativ gut verkauft bekäme also eventuell....
Hätte es direkt zum Start ne 4080 Ti gegeben hätte mich selbst die 4090 nich gejuckt so wie mich die 3090 schon nich gejuckt hat nur lag das daran das die 3080 nich weit weg von der 3090 war
daher wurde es damals bei mir die 3080 Strix die mit OC so schnell war in manchen Games und in 3D Mark wie ne 3090 Stock
Und ne 4080 Ti währe sicherlich dann auch nich so weit weg von ner 4090 sodass ich in dem Fall dann ne 4080 Ti genommen hätte aber so wurd es bei mir nun die 4090 Strix
da ich nich auf ne 4080 Ti warten wollte die sicherlich im laufe 2023 rauskommt
Das is 2022 ja nun anders und die 4080 kommend von der 3080 zu schwach und die 4090 zuweit weg von der 4080 sodass da nur die 4090 interessant is.
Aber eine zukünftige 4090 Ti interessiert mich persönlich nun auch nich da die 4090 Strix dann für 4 Jahre in meiner Kiste bleibt.
nach keine Ahnung, 6 Wochen ist das CableMod 3x8Pin auf 12HWPR angekommen(Seasonic Netzteil)
Damit konnte Ich das Provisorium endlich auflösen
vorher:
nachher:
Danach konnte Ichs auch nicht lassen, und habe auf die GameRock auch gleich das Gamerock OC Bios draufgemacht. Damit sind 50 Watt mehr möglich.
Für Platz 1 mit dem 5800x3d in DE reichts :) World Wide Platz 5
Sogar für die HOF hats gereicht:
Gibt es ein Palit/Gainward Bios mit 600Watt? Will kein Asus/Gigabyte/MSI nehmen wegen der Lüftergeschichte
Gibt es eigentlich irgendwo Reviews zur Manli oder PNY?
Zur PNY gibt es zwei Reviews.
Frau spielt Assassins Creed und ich hab grad bisschen die Strix gereizt… 😅
Also Powerlimit auf 120%, bekomm ich 590W durch…
Ohne Spannungen zu verändern bin ich bei 3005/1470 noch FSE stabil, bei allem drüber friert der PC ein…
GPU dann allerdings bei 75 Grad, Wasser 38…
Hab ich Gestern Abend auch gemacht nur halt etwas Spannung runter genommen und mit den Settings gezockt bei 0,975V.
Eben mal den Speedway laufen lassen sieht echt okay aus denke ich für 2790 mhz schön kühl den Ram etwas angezogen .
Aber auch nix optimiert diverse Hintergrund Programme wie Experience liefen mit.
Denke für etwas UV ist der Score noch in Ordnung.
Später noch mal kucken was da noch geht bei Ram und GPU.
Hab Gestern auch Calisto Protokoll ausprobiert und dann wieder zurück gegeben .
Es gibt da immer noch beim Betreten neuer Abschnitte kleine Ruckler .
Aber allgemein bringt das Spiel die 4090 an die Leistungsgrenzen .
Es gab stellen da scheint es nicht für 60 FPS zu reichen hätte da zwar 90%GPU Load aber auch nur 47 FPS glaub nicht wen ich 100% gehabt hätte das für 60 an der Stelle gereicht hätte.
Von wegen wie manche geschrieben haben die hat Leistung im Überfluss .
Für 4K kann man nicht genug Power haben!
Ach mit FSR2.0 irgendwie kaum Leistung da zu gewonnen vielleicht auch broke da muss DLSS rein!
Dann noch Mal Dark Tide ausprobiert ist auch Witzig mit Frame Generation zeigt der Graph eine glatte Linie läuft aber extrem unsauber.
Die pny klingt von der kühlung her interessant. Bin auf deinen bericht gespannt. Schickst du die fe erst ein wenn die pny da ist? Btw. Von nbb höre ich nix mehr bzgl. der fe. Ist schon seit montag da und die haben es nicht geschafft die rauszuschicken. Meine 4080 ist schon seit vorletzten freitag da. Höre ich auch nix von, dass es mal angekommen ist und das es geld zurückgibt. Beim nächsten launch behalte ich die erste karte mit der ich zufrieden bin. Auf der hinterherrennerei habe ich nicht nochmal lust. Wenn die pny echt so leise und kühl ist wäre sie wohl meine erste wahl gewesen. Aber hinterher ist man immer schlauer.
Von wegen wie manche geschrieben haben die hat Leistung im Überfluss man kann für 4K nicht genug haben.
Viele games bringen sie an die leistungsgrenze. Watch dogs legion, cyberpunk, plague tale uvm. Die raytraceleistung ist vielleicht 10% höher. Der größte performanceschub wird nur über rasterization erreicht. Wird wohl doch noch eine 5090 /6090 werden müssen um 4k ausreizen zu können. Und die reden von 8k 😅
Nee also die FE geht raus sobald ich das RMA Etikett von Nvidia habe. Aber ich werde trotzdem genau vergleichen können. Ich meine wir haben einige Videos (Deine geben das Brummen ziemlich genau wieder) gemacht und ich habe sie ja wirklich auf Herz und Nieren getestet. Habe mir auch ein paar Testpunkte notiert (also Stelle in Spielen, Verhalten in Benchmarks), wann der Lüfter wie anläuft.
Das einzige was ich heute noch testen und notieren werde ist, wie weit sich die Karte @ Stock Voltage übertakten lässt. Die PNY ist ja bei 450W begrenzt, das dürfte ein großer Nachteil sein. Die FE hatte ich schon mit PT auf ganz rechts im AB bei 500+W.
Außerdem kann ich diese ganzen Lobeshymnen auf die PNY noch nicht so ganz glauben. Lasse mich aber gerne eines besweren belehren). Die Karte sieht in Reviews extrem billig aus und allein dass die Kabel sichtbar raushängen ist für meinen Case mit Fenster ein No Go. Aber wenn sie wirklich auch unter Last leise ist, was ich bisher bei meinen Nvidia Karten nur bei EVGA und Asus hatte, dann ist das natürlich das Entscheidungskriterium.
Kann mir DEN mal jmd ausleihen? Ich will was heißluftlöten... :ROFLMAO:
Damit werden Bauteile nicht nur entlötet, sondern auch gleich das ganze PCB leergeblasen :haha:
Den Gerüchten zufolge hatten die "Ghostbusters" das Ding damals benutzt :ROFLMAO:
Oder gleich auf die TI warten, soll ja im Januar kommen.
Ja, sag ich auch jedem, der die 4090 zu teuer und die 4080 zu "billig" findet. 😂
Fakt ist die RTX 4080 Ti wird kommen 👍
Zurzeit geht im Internet eine Fehlinformation rum wonach die RTX4090 schon wieder ein VBios braucht, für den Support vom Neuen Need For Speed Spiel.
Diese Fehlinformation ist dazu zurückzuführen das EA erst selbst vom einem VBios Schrieb inzwischen aber zurück ruderte und nur noch vom einem Mainboard Bios spricht.
Flashing/Blinking Display - High End PCs
We've seen reports of Flashing/Blinking Display issues with folks on high-end PCs (Nvidia RTX 40-series). After testing, we've found a solution is to upgrade the motherboard BIOS. Please refer to your motherboard manufacturer’s support page to obtain the latest system BIOS.
If you continue to experience this issue - please report this via the Bug Reports section with details about your system (CPU, make/model of your graphics card, driver dates, video card bios/firmware.
Previously, the fix was incorrectly listed as a graphics card VBIOS update.
Ups... :oops:
Hotspot ~87°C - richtig?
Hauptsache die 4090Ti kommt auch auf dem Founders PCB, dass wenigstens der Wasserblock noch passt ;)
Mit 24 GBps Speicher, vollem Cache und 18xxx shadern, selektiertes Silikon mit 2.8 Ghz stock boost, da geht schon noch was.
Dass wir auf der 4090 aktuell nur Ausschuss bekommen siehst man doch an den Profikarten mit 10% mehr Einheiten und 350W.
Die Frage ist, wie viele gute AD102 kann NV für >5k an Datacenter und Workstation-User absetzen. Solange man da keinen krassen Überschuss hat, gibts keine 4090Ti.
Zu erst wird es die 4080Ti geben .
Als Konter zur 7900XTX
Die 4080 TI wird dann den Preis von der 4080 einnehmen und die 4080 wird auf 1000-1400 gesetzt!
Die 450w ist aber nur in einigen extremsituation ein kleines problen. In der regel reicht es. Ja sie sieht billug aus. Aber viele andere karten auch. Und dennoch sind viele lauter und wärmer. Jetzt braucht nv tage um ein rma ticket zu schicken. Wie lang ist dann blos die karte weg? Ich werde den fanmod machen falls die karte mal wiedekommt. Fighting falcon berichtet ja gutes.
Ich hab gerade schön Darktide gezockt um die 56 -58 °C bei ca. 300-350W mit 2805mhz @0,975 V +1000 auf dem RAM .
Das Kärtchen ist echt ein träumchen im Silent Mode.
Ich verspüre irgendwie keinen Reitz auf Wasser umzubauen .
Je nach Game wen es Mal in Richtung 380-400W geht auch Mal knapp um die 60°C rum bei ca.1000RPM .
Division war da mit 416W Peak das höchste!
Die meisten Titel aber ehr so um die 300-375 W rum.
Ich verspüre irgendwie keinen Reitz auf Wasser umzubauen ... um die 56 -58 °C bei ca. 300-350W ... 380-400W geht auch Mal knapp um die 60°C rum
Mit Wasser hattest du im Bereich 300 - 350 Watt sicher dann 48 Grad oder weniger statt 58 Grad mit Luft und mit 380 - 400 Watt hättest du so 50 Grad statt mit Luft 60 Grad
10 Grad unterschied is nun nich viel aber können schon ein paar Taktstufen sein aber wenn dir das Aussehen der Strix so gut gefällt spricht ja auch nix dagegen auf Luft zu bleiben
Bei mir kommt halt noch der Platzmangel dazu ( neben den niedrigeren Temps ) da der Wasserkühler kleiner is und ich mag die RGB Beleuchtung der Wasserkühler lieber und es macht auch Fun die Hardware auf Wasser umzubauen auch wenn man jedesmal dabei Bammel hat was kaputt zu machen.
Bei mir ist es ehr das ich keine Lust habe alles wieder zu zerpflücken .
Vielleicht überkommt es mich ja im neuen Jahr aber die Karte ist so unauffällig bezüglich Lüfter das es mich halt nicht reizt.
Interessant würde es aber sein wen man nun 3GHZ anpeilen würde für das Gaming weil das geht @ Air dann nur noch mit Drehzahl und dann auch mit Peaks in Richtung 600 W .
Aber wen man sich das so ansieht dann bekommen die Leute da kaum noch mehr Leistung raus. .
mit Peaks in Richtung 600 W .. Aber wen man sich das ansieht so dann bekommen die Leute da kaum noch mehr Leistung raus.
Ich werde auch bei 400 Watt Sense machen bei meiner zukünftigen 4090 Strix .. hab aktuell bei meiner 3080 Strix auch bei 400 Watt Sense gemacht obwohl die ja 450 Watt könnte
Ja is erstmal ne Überwindung aber ich freu mich schon drauf das dann bei meiner zu machen.... wen meine 4090 Strix nich zu laut is kommt da dann bald der EK Kühler druff.
Ähnliche Themen
Antworten
7K
Aufrufe
488K
