[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hättest mal Vorkasse genommen. Die Bestellung ist fixer durch und dann ca 7 Tage reserviert.
Hätte Dir den Bammel erspart.
Funktioniert bei den meisten Shops aber nicht, da das Warenwirtschaftssystem immer die "Echtzeitzahlungen" wie Kreditkarte oder Paypal bevorzugt. Würde mich wundern warum das bei NBB anders sein sollte.
lieber nicht
Bloatware des Jahrtausends
Habe damit keine Probleme bis Dato. Und nutze das schon ewig.
Schwanke auch noch ob die MSI da bleiben soll, bin ja irgendwie der Hoffnung das es vielleicht mit der Zeit besser wird. :unsure:
Angenommen du tust es nicht. Wie wird es weiter gehen? Die neue Karte bestellen und dann auch zurück wenn es so ist? dann das nächste Modell ? Wie lange willst du das Spiel denn spielen? Irgendwann vergeht einem doch die Lust.
War da nicht was mit Viren ?
Das Problem mit der Asus Armoury Crate is halt nur das es viele laufende Prozesse im Taskmanager erzeugt die hier und da etwas Ressourcen klauen ( war zumindest damals so als ich die mal ausprobiert hab )
und wenn man die Crate Deinstalliert bleiben dennoch reste auf dem System ... aber Viren gibts da nich das Ding Zeckt sich halt nur zu stark in dein System fest.
Das war damals noch besser als Asus Aura noch ne Extra Software war wo man nich die Crate für brauchte .. man kann die alten Aura Versionen zwar noch nutzen
aber die funktioniert dann mit neuer Hardware nich mehr ... ich nutz sie aber noch Extra also ohne Crate ( Aura Lighting_Control_1.07.71 ) is aber ne alte Version von 2020 rum
aber die reicht aus um mein Aktuelles RGB System zu steuern... und bei der 4090 Strix die nächste Woche bei mir dann im PC steckt werd ich ja auch wieder auf nen Wakü Block gehen
der sollte dann auch wieder mit der alten Aura Version von 2020 laufen sodass ich die Crate nich brauch
Echt Schade das Asus das umgestellt hat das man für neue Hardware dann die Crate brauch ... aber so wie ich das mitbekommen hab hier im Thread damals gibts auch
andere Tools glaub "OpenRGB" oder sowas wo man auch die Asus Karten mit einstellen kann
Habe bisher erst eine Karte zurück geschickt, daher sehe ich da kein Problem drin. Wenn ich 2300-2500€ für eine Karte ausgebe darf man auch mal Wählerisch sein.
Wenn die Karte zurück geht, kommt wieder eine Gamerock nonOC oder OC rein.
Beste Grüße
Dann eventuell doch die RGB Stecker ab ziehen
Gin Open RGB nicht nur bei der TUF irgendwas hatte ich hier Mal gelesen!
Kannst du natürlich auch machen ... ich Persönlich würde es dann aber eher durch Software lösen
Das is ein Open Source Projekt und wird stetig verbessert wie zb auch Color Control ( LG OLED ) was ja auch ein Github Tool is das du schon kennst
Vor einigen Wochen hatte hier jemand geschrieben das die TUF dort nun auch unterstüzt wird und vor 5 Tagen kamm die Version 0.8 raus
sollte die Strix jetzt noch nich dabei sein is sie es sicher bald.
Ich selbst hab das Tool noch nich genutzt da bei mir alles über die Aura Version von 2020 einstellbar ist möchte aber halt nur Alternativen aufzeigen
Das hört sich doch gut an. Schwanke auch noch ob die MSI da bleiben soll, bin ja irgendwie der Hoffnung das es vielleicht mit der Zeit besser wird. :unsure:
Beste Grüße
Die dir am besten gefällt würde ich nehmen immerhin legt man hier einen Batzen Geld auf den Tisch.
Gruß.
Optisch die MSI, aber diese gefiepe. Mein Gehör ist leider noch zu gut :(
Beste Grüße
Hat jemand Ahnung wie ich das Rog Strix Auge an meinem Dark Hero Board ausstellen kann? Also NUR das Auge. Es wird nämlich fast komplett von der RTX 4090 abgedeckt und das sieht doof aus von vorne xD
Nee, da nehm ich wieder ne Palit, 2 Stück waren Top. Mal schauen wan die wieder Richtung UVP gehen.
Beste Grüße
Oder gleich auf die TI warten, soll ja im Januar kommen.
Es war immer klar das die normale 4090 nicht der Vollausbau ist, pcgh hatte unlängst darüber berichtet, die TI kommt, allerdings keine Titan. Aber es stimmt, als Release ist Januar noch ein Gerücht, NV wird sich da vermutlich nach dem rdna3 release konkret zu äußern.
Naja mal sehen aber warum sollte NVIDIA solange den Vollausbau zurückhalten?
Man will auch im neuen Jahr Geld verdienen und die Fans scharren sicher schon mit den Füßen nach ner TI .....
Weil ne Ti meisst erst kommt wenn AMD der normalen Nvidia Karte näher kommt und sich Nvidia so wieder etwas weiter von AMD absetzten kann.
Aber es gab in der Vergangenheit sicherlich bei Nvidia da auch schonmal ausnahmen wo ne TI schon vorher kamm aber meisst is das eher ne Reaktion auf AMD.
AMD macht ja ähnliches mit den xx50er karten .. Katz und Maus spiel halt :d
Aber ne 4080 TI is sehr wahrscheinlich und wird sicherlich nächstes Jahr kommen da AMD der 4080 nahe kommt oder gar überholt sieht man von Ray ab aber ne 4090 Ti is wenn dann noch sehr weit weg
da noch keine AMD Karte an die 4090 rankommt.
Von wann bis wann ist denn das Geschäftsjahr von Nvidia?
Nvidia hat aktuell die schnellste Karte und alle kaufen die 4090 / wenn AMD die 7950xtx bringt dann vielleicht. Ansonsten kommt die erst in 1,5 Jahren wie die 3090ti
Die 3090ti ist seinerzeit viel zu spät gekommen den Fehler wird nv vermutlich nicht wieder machen.
Aber warten wir ab, wollte hier keine Panik verbreiten. ;)
Die Entscheidung dürfte auch massiv von der Ausbeute in TSMCs Fertigungsprozess beeinflusst sein. Wenn sich die voll funktionsfähigen Chips bald stapeln, dann klar, warum keine Ti… dürfte wahrscheinlich nur nicht der Fall sein :d
Is doch keine Panik die du verbreitest sondern ein ganz normales Gespräch über Möglichkeiten .. ich sehe halt nur die Vorraussetzungen noch nicht erfüllt sodass diese Möglichkeit eintretten kann.
Auch Preislich währe eine 4090 Ti momentan ziemlich Hart das wird noch dauern.
Aber wie du schon sagst : Warten wirs ab :d
die ti war
einmal aufgepumpt und dann doch nix dahinter auser blitze im stromkasten
Ach so das alte Ding .l
Ja die wird kommen aber das wird noch etwas dauern glaub nicht vor Ende Mai wen überhaupt.
AMD hat doch nix was der 4090 gefährlich wird zur Zeit.
die ti war
Nvidia hat Ihr Preisphilosophi mit der 3090ti für 2300 Euro schon angekündigt und mussten dann um 1000 Euro ein halbes Jahr später reduzieren :) ja so ist nvidia aktuell und der vollausbau kostet für Firmen 8000 Euro und ist viel rentabler. Die gamer sind für nvidia nicht mehr so wichtig wie früher
Mir ist bei dieser Amazon PNY 4090 aufgefallen, dass da eine für 2.800€ sogar in Stock ist. Die, die wir für 2.094€ bestellt haben, aber eben erst am 14.Dez verschickt wird,. Ist doch echt ne Sauerei. Gibt's bei Amazon für sofort verfügbare Ware jetzt n Aufschlag?
Ähnliche Themen
Antworten
7K
Aufrufe
488K
