[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibts jetzt eigentlich schon ne Möglichkeit die Lüfterkurve softwaremäßig zu verändern? MSI AB ignoriert die FE zB komplett
Warum kaufen eigentlich alle bei CableMod?
Ich hab mit www.moddiy.com eigentlich die beste Erfahrungen. Das Kabel war in weniger als 2 Wochen da, ich konnte die Länge und Farbe nach Wunsch anpassen, und das Kabel ist wertig.
Wirkt sehr billig, vertraue cablemod da mehr
Guter Monitor zu nem krassen Preis. (y)
Ich warte derzeit auf den 42" LG OLED als Gaming Monitor, primär weil mir der ASUS PG42UQ total überteuert vorkommt.
Ab funktioniert perfekt mit der fe.
Naja, perfekt nicht ganz. Der Kurveneditor spackt schon rum, aber das tut er schon immer. Und er ist auf 3GHz begrenzt. Die Vergleichs-Kurve der Standardeinstellungen (die dünne Kurve) spinnt auch total rum. Beim Übernehmen der Einstellungen springt die Kurve manchmal völlig unmotiviert auf völlig andere Werte (und nein, nicht einfach nur auf die diskreten, zulässigen Frequenzwerte).
Unwinder scheint sich fast nur noch auf den RTSS zu konzentrieren. Die Unterstützung von Lovelace ist bestenfalls rudimentär.
/Edit: Es gibt ein inoffizielles Update, welches einige der Probleme löst: https://forums.guru3d.com/threads/msi-ab-rtss-development-news-thread.412822/page-189#post-6073429
Habe auch Probleme mit der AB Lüfterkurve mit der 4090 FE. Und die Gainward zuvor hat auch nicht richtig funktioniert. Bleibe jetzt auf der Standard Lüfterkurve, da mich die eigentlich nicht wirklich stört. Es ist schon generell eine massive Verbesserung wie ruhig der PC jetzt bleibt mit meiner neuen AiO auf der CPU und 4090. Vorher mit der Gainward 3090 und komplett Luftkühlung war das schon teils extrem laut.
Moin zusammen, ich habe das Thema lange nicht verfolgt und es ist jetzt erst wieder aufgeploppt durch einen Kollegen der eine 4090 kaufen will. Gibt es auf dem Markt nichts gescheites das auch zu ordenltichen Preisen verfügbar ist ? Irgendwie ist das schlimmer geworden. Die ganzen Händler sind nur Ebay und co.
Meine Vermutung: egal was du da angeben musst. Zum Schluss kommt raus dass du irgendwas falsch gemacht hast und deshalb selbst Schuld bist. Man kann dir nicht helfen.
Du hattest Recht :-). Auf mein DHL Formular kam nie eine Reaktion und die Ware ist jetzt bei NBB angekommen. Hatte mit denen gerade nochmal telefoniert und er versicherte mir, dass ich das gleiche Paket zurückbekomme. Was wir von Support Aussagen halten können ist ja nun auch bekannt. Ich lasse mich mal überraschen was da kommt :-)
Den Kurveneditor kannst DU in der INI Datei selbst definieren, kannst dann von 300-3200 z.b. angeben.. Kann es Dir gerade nicht zeign da ich nicht an meinem PC bin.
Findest aber hier im Forum wenn Du danach suchst.
Die Kurve sprang auch schon bei der 3000er Generation. Liegt an der grafischen Oberfläche die auch ins Raster der GPU CLock Taktraten passen muss. Ist aber meiner Meinung nach absolut zu tolerieren.
Schick mal ein Screenshot wo Du das einstellst? Habe damit die Tage rumgespielt und es funktionierte mit der FE perfekt.
Zuerst im AB auf die Kette klicken damit du 2 Lüfter hast.
Dann in die Settings gehen und Lüftersteuerung aktivieren.
Dann Firmwaresteuerung wählen
Dann hast DU FAN 1 und 2
Dort hast Du ein Kurve bei der Du 3 Punkte setzen kannst.
Im Prinzip reicht es die Kurve so zu lassen und nur den Punkt über 83° zu senken oder zu erhöhen.
Ich habe bei meiner FE den Punkt von Fan 2 (oberer Lüfter) auf 41 gezogen. So dreht der obere Lüfter nur bis 1100rpm.
Beachte! 30% sind in dem Kurveneditor 40%!
4090 ist Mangelware. Musste halt einen Webmonitor auf günstige Produkte setzen. FE oder TUF im Asusshop. Bei EK gehen die FE's auch nicht mehr schnell weg. Würde zwar nicht beim Scalper kaufen aber auch dort kannst Du zu UVP eine Tuf OC kriegen oder eine FE ab 2100..
Wer einmal als Empfänger einen Transportschaden bei DHL hatte, weiß was er von dem Verein zu halten hat. Und wenn ich das mit dem kombiniere wie DHL mit Paketen umgeht... ach egal.
Also ich muss sagen, dass meine Paketlieferanten immer nett und ordentlich ausliefern. Aber wer weiß was in den Weitertransportlagern abgeht.
Geh einfach mal in so ein KEP Lager wenn du die Gelegenheit hast (Ich hatte mal Logistik und SCM im Schwerpunktfach ). Und dann schau dir an wie die "Übergabe" von Transporter zu Transporter gemacht wird und wer das macht. Die Branche ist hart, die Margen und Gehälter nicht üppig, die die dort arbeiten machen das nicht weil sie sich nix cooleres vorstellen können. Nicht umsonst gibts Verpackungsrichtlinien die dir im Grunde sagen dass das Paket aus großen Höhen fallen können muss und auch mal jemand mit einem Stapler anecken können muss ohne dass dem Inhalt was passieren kann. Aber egal. Offtopic.
Ich habe damals übergangsweise in einem GLS Lager gearbeitet und da war es gang und gäbe die Pakete extra hart in den LKW zu werfen wenn "Vorsicht Glas" oder so drauf stand. Denke bei anderen Anbietern sieht es nicht viel anders aus. Seitdem klebe ich solche Hinweise lieber nicht auf meine Pakete.
Das sind leider die negativen Resultate einer MArkwirtschaft. Jeder will der günstigste sein. Made in Germany it tot!
Cool, danke, und eigentlich auch zu erwarten. Hätte ich auch drauf kommen können.
Dass die Kurve manchmal unmotiviert springt hat aber nicht nur mit den zulässigen Taktraten zu tun. Das ist schon noch ein anderer Effekt. Allerdings kann es auch sein, dass das gar nicht am AB liegt sondern am Treiber. Denn das Verhalten scheint sich mit der Treiberversion zu verändern.
Meinen erfahrungen nach ändert es sich nach belieben. Aber wie gesagt, mich juckt's nicht ob ein Punkt der Kurve 15Mhz höher oder tiefer ist. Im gesamten arbeitet der AB super und macht sein Ding ob OC oder UV. Und zur Not erstellt man die Kurve nochmal. Selbst nach einem Neustart sieht der VErlauf anders aus. Aber alles im Toleranzbereich. Ist ja nicht so, dass Du 2700Mhz einstellt und die Karte nur 2650 macht.
Am Ende sehen die DHL-Pakete bei mir immer am besten aus und es war noch nie eins beschädigt (>100). Bei Hermes und DPD sind gefühlt immer irgendwelche Dellen drin. Das Pakete nicht einzeln auf Samthandschuhen getragen werden ist aber wohl auch klar. Bei dem Volumen und der Arbeitslast muss man die Pakete eben irgendwie bewältigen. Ist dann auch nicht nur der Verdienst, sondern einfach zu wenige Arbeiter. Abgesehen kann ich mir auch vorstellen, dass z.B. gerade zur Weihnachtszeit auch einige Arbeiter einfach mal die Nase voll haben oder einen schlechten Tag haben.
Zum Afterburner: Habe Power Limit auf 80% gesetzt und gespeichert. Aber irgendwie steht es häufiger wieder auf 100% nach einem Restart. Manchmal behält er aber auch die 80%.
Das ist komisch. Meist behält er denn zuletzt gespeichertetn und aufgeführten Slot.
Hast Du im Afterburner Autoprofile gesetzt? 2D / 3D
Ich kann es mir schon vorstellen. Bei dem Lohn und der Behandlung der Mitarbeiter ist es kein Wunder...
Afterburner installiert - Power Limit auf 80% gesetzt - gespeichert - Start mit Windows -> bleibt nach Restart auf 80% und irgendwann nach einem Restart wieder 100%
Sonst ist alles auf default bzw. nichts verändert. Habe auch nochmal unter Profill1 die 80% gespeichert. Gleiches Verhalten.
Das meine ich gar nicht so sehr. Wenn man beim UV die Punkte nach rechts markiert (mit Shift) und dann die markierten nach unten zieht, sollte nach dem Übernehmen alles vom markierten Punkt aus zu einer wagrechten Linie werden.
Jetzt geht das auch wieder so, aber bei meinen Versuchen vor drei Wochen oder so, ist die Kurve da wild umher gesprungen. Völlig unbrauchbar. Da es jetzt geht, ist mein Verdacht, dass es am Treiber liegt, denn sonst hat sich seit dem nichts geändert.
Dass die gesamte Kurve oft beim Übernehmen um einen gehörigen Betrag nach oben oder unten rutscht, ist irritierend, weil sie das Feinoptimieren auch erschwert. Da fummelt man ewig rum, nur damit dann mit einem Klick wieder alles kaputt geht. Ich weiss, dass man den Takt nur in 15 MHz Schritten ändern kann, und bei der 3090 hat das auch immer sauber funktioniert, aber bei der 4090 ist das Verhalten oft sehr eigenartig...
Die OC Einstellung im AB wird per Scheduling Task gesetzt (Windows Aufgabenplanung). Schau da mal nach, ob der Task immer gestartet wird. Es darf dort auch nur einen Eintrag für Afterburner geben. Du kannst ihn auch noch manuell verzögern, das könnte auch die Probleme beheben.
  • Danke
Reaktionen: AyC
@Grestorn
Haste Mal den Thread von HisN gelesen und das Vid angeschaut? Wichtig ist m.E. auch die Kurve im Idle einzustellen und anschließend zu testen ob man den Wunschwert erreicht hat. Bei Temperatur Veränderung springt die Kurve zwar dann noch immer z.B. nach einem Neustart etc. aber die Volt und der Takt im Betrieb also ingame bleiben so wie vorher eingestellt wenn auch nicht an der Kurve selbst.
Ich denke da Du die Werte oberhalb von 3000 nicht markiert hattest ist s wild gesprungen.
Ich erinnere mich, dass es die Sprünge bei der 3090 auch gab. Einmal sah die Kurve so aus und ein anderes mal so...
Warum fummelst Du da wie wild rum? Entscheidend ist doch der Maximalwert von Clock / Volt.
Wobei das dann einfach auch schon böswillig ist. Ich hab auch schon Scheiss Jobs gehabt und deswegen nicht irgendwelche Ware absichtlich beschädigt. Also sorgloser Umgang, ja absolut. Man hat weder Zeit noch fühlt man sich entsprechend gewürdigt. Aber absichtlich Glaspakete zu zerstören hat dann nix mehr mit dem Unternehmen zu tun. Das Problem ist wohl eher der "Fach"kräftemangel, man muss halt nehmen, was man kriegt. Da ist ein sauberes Auswahlverfahren nicht mehr möglich.
Unabhängig davon sind meine Pakete jedoch auch stets unbeschädigt angekommen, hatte noch nie einen Schaden am Produkt selber. Eingedellte Verpackungen ja, aber ansonsten nix, egal ob Elektronik oder Porzellan.
Seasonic Lieferung ist da... maaann ist das hochwertig. Und gut biegbar, das sollte ohne 90 Grad Adapter gehen.
An alle mit Block auf der 4090…
Wieviel Temperatur-Differenz zwischen Wasser und GPU-Hotspot habt ihr? Bitte auch die Last in Watt angeben
Schaut du: https://www.hardwareluxx.de/community/threads/sammelthread-für-temperaturvergleich-4090-kühler.1326685/
das ASUS/Seasonic cablemod cable was versendet wurde und nicht ging ist wohl laut cablemod eins für EVGA PSU´s gewesen?
holy macceroni.
Auch ne Lösung. Ich werde jetzt ebenfalls ein neues bekommen das hoffentlich funktioniert. Das bereits hier angekommene sollte ich entwerten.
Nachtrag: Seasonic Kabel ist drin und läuft. Es klickt beim Einrasten deutlich. Enger Biegeradius ist kein Problem im Gegensatz zur Nvidia-Kabelpeitsche. Halbe Länge würde zwar auch genügen für meinen kleinen Tower aber ich will mal nicht motzen. Danke Seasonic!!!
Ähnliche Themen
Antworten
7K
Aufrufe
541K
