[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Geht die Halterung vom Torrent nicht?
Alternative (hatte ich so bei der 3080): die Lüfter sind ja idR einblasend montiert das bedeutet dass du etwas in die Mitte der Lüfter stellen kannst. Wenn sich das ausgeht, schau mal ob du am vordersten Lüfter irgendwie den Standfuß ansetzen kannst. Ging bei meiner 3080 die auch nur 1-2 cm kürzer war.
ich hab natürlich mir nur den von KFA angeschaut weil beleuchtet ;-) den anderen suche ich mal
hat zufällig jemand das Fractal Design Torrent Gehäuse und eine 4090 (KFA) verbaut? ich bekomme den Ständer nicht ausgerichtet, weil ja unten die Gehäuselüfter im Boden sind
Du kannst solche Ständer auch auf die Lüfter stellen, die halten das locker ab.
Das meinte ich als Alternative - danke für das Bild!
Mal ne andere Frage zur 4090FE
In spielen mit leichter Last gehen doch irgendwann die Lüfter an, und bleiben bei 1100U/min obwohl die Karte keine 40°C hat.
Versuche ich die Lüfter über Afterburner zu regeln gehn die Lüfter entweder aus, oder bleiben trotzdem bei Minimum 1100U/min.
Das nervt ein bisschen....
ich hab jetzt nach längerer Bastelei den Torrentständer genommen...
sie läuft und löst die 1080 Amp ab
bei der KFA war noch ein extra Lüfter für die Rückseite dabei, falls man will
jetzt muss ich nur noch irgendwie die Karte einstellen, bzw UV, PXL_20221123_162024694_copy_1020x768.jpg
Hab jetzt auch das Corsair-Kabel:
Sieht gut verarbeitet aus, ist auch generell recht rigide selbst ohne den Mantel am 12-Pin Anschluss. Etwas nervig ist das die 2 Sense Pins Parallel zu den 12 normalen Leitungen laufen, komplett gesondert.
Damit ich mein Panel schließen kann musste auch ein ganz schöner Bend her, Kabel sitzt aber nach Kontrolle immer noch gut.
So habe jetzt endlich auch mein bequiet Kabel, ziemlich steif das Teil wie soll ich das nicht knicken/biegen. ^^
So oder so, je nach Platz zur Seitenscheibe. Es hilft den Stecker vorne festhalten damit Du die Kabel nicht rausziehst.
Mein be quiet Kabel war bzw. ist einwandfrei verarbeitet.
Meine sind auch top und habe 3 Stück hier!
Mein Corsair sah ebenfalls so perfekt aus :)
Meins auch...
Aber so sollte es nicht aussehen :d
Warum so viele? (Manche sogar 4)
Meins auch...
2 Stück zu Release bestellt, um 1 für Ersatz zu haben und 1 kam noch von einer Bestellung bei beQuiet, welche ich vergessen hatte.
Lässt sich halt dadurch das das nicht noch zusätzlich ummantelt mit Gewebe oder irgendwas anderem sind sehr stark und ohne Beschädigung knicken bzw anwinkeln .
Natürlich vorsichtig sein aber dadurch das das alles einzelnen Litzen sind kann man durch festhalten kurz vor dem Stecker biegen ohne die Litzen aus dem Stecker zu ziehen oder zu beschädigen.
Das Corsair ist Top hab heute mein zweites bekommen dachte haben ist besser wie brauchen!
Find das Mega gut das ich kein neues 5.0 Netzteil brauche!
Das HX1200i hat jetzt gerade mal 2 Jahre runter .
Mein CableMod Custom Kabel ist heut auch aus China per FedEx angekommen (80cm ModMesh 4x 8pin vom Fractal Ion2 auf 12VHPWR, am 28.10.22 bestellt)
Sieht soweit erstmal ganz vernünftig verarbeitet aus, vorallem auch die Stecker.
Die zwei Sens Leitungen hätten sie aber ruhig in einem Sleeve verstecken können, statt den Klingeldraht über die gesamte Strecke einzeln mitzuführen.
Einbau mach ich aber erst am Wochenende, wenn ich auch bereit bin für einen Lichtbogen :fresse:
Meine ASUS 4090 TUF ist heute aus Braunschweig zurück gekommen da diese am "send it in, get one free" Programm teilgenommen hat. https://www.alphacool.com/shopware.php?sViewport=ticket&sFid=141
Nach dem reverse-engineering dort hat man die TUF mit besserem Material und/oder handwerklich besser zusammen gebaut als ASUS ab Werk. Auf Rückfragen kam promt eine Antwort auf die sehr zusammen gerückten Temperaturen von GPU, Hotspot und Memory. Insbesondere der Speicher war vorher etwa 10°C wärmer.
Anhang anzeigen 820360 Anhang anzeigen 820359 Anhang anzeigen 820361
Sag ich doch. die Thermalpads der Tuf sind teilweise zu klein und decken nicht die ganze VRAM Fläche ab. Falls ich meine Tuf behalte bekommt die auch einen Thermalpadmod. Die haben jetzt ulraweiche genomme. Ich hatte an harte gedacht da die doch angeblich besser leiten sollen? Am liebsten noch ein Coppermod für den VRAM. Lächerlich was die Fachfabriken da bei 2000 Euro zusammenklatschen. Irgendwie denkt keiner mehr langfristig an seinen Ruf sondern nur noch an den schnellen Profit.
Kannn es aber auch sein, dass deine karte nun kühler ist weil der fussboden nun jetzt auch winterlicher ist?
Ich nominiere dich für den Kühlschrank Award!
Meine Gaming OC idled nach einer gewissen Zeit so zwischen 39° und 41° C. Aber ich habs auch eher warm in den Räumen. Ich schätze so 23-24° C. Ich müsste mal wieder die Batterie vom Raumthermometer laden.
Bei mir ähnlich. Meine FE idled so bei 38° bis 42°.
@pajonk Sehe ich ähnlich, aber es gibt auch wohl große Unterscheide in der Fertigung. Ab Werk in Taiwan werden die Karten im Akkord zusammen gekloppt. In meinem Fall hat ein Alphacool Mitarbeiter in Deutschland die Karte sorgfältig auseinander und mit eigenem Material wieder zusammengebaut. Ich mal er hatte viel mehr Zeit das sorgfältig zu machen und auch Zugriff auf bessere Pads/Paste. Das dürfte aber auch übertragbar sein auf Enthusiasten hier die Karten selbst, und sehr gewissenhaft umbauen.
asus hat auch bessere pads und zeit, wenn asus will..
@pajonk Sehe ich ähnlich, aber es gibt auch wohl große Unterscheide in der Fertigung. Ab Werk in Taiwan werden die Karten im Akkord zusammen gekloppt. In meinem Fall hat ein Alphacool Mitarbeiter in Deutschland die Karte sorgfältig auseinander und mit eigenem Material wieder zusammengebaut. Ich mal er hatte viel mehr Zeit das sorgfältig zu machen und auch Zugriff auf bessere Pads/Paste. Das dürfte aber auch übertragbar sein auf Enthusiasten hier die Karten selbst, und sehr sorgfältig umbauen.
Kann es evtl. auch sein, dass deine karte nun kühler ist weil der fussboden nun jetzt auch winterlicher ist gegenüber damals als Du getestet hast?
Jap, ist leider so. Geht mir auch auf den Sack.
Die Karte ist wirklich super wertig, aber alles in Bezug auf die Lüfter ist kompletter Müll.
Das ist aber gar nicht so verkehrt. Die Karte wartet ab ob die Karte die Temperatur senkt und schaltet erst dann die Lüfter ab. Hast Du jetzt ein Lite Game laufen und die Lüfter würden ausgehen würde die Temperatur langsam steigen. Dann würden die Lüfter wieder anspringen um sie runterzukühlen... dann wieder ausgehen.... und das immer wieder... Von daher lässt sie die Lüfter auf 30% laufen und wartet bis sie sicher ist, dass die Temperatur abfällt. Und wenn sie einmal auf 30% laufen hört man sie ja kaum. Besser als an aus...
Nein, das schließe ich aus. Das Zusammenrücken von den GPU, Hotspot und Memory Temperaturen zeigt das der Kühler ideal funktioniert bzw. die Paste/Pads annähernd optimal sind und auch so verbaut wurden. Das ist schon eine Sache die uns Enthusiasten umtreibt ;)
Ähnliche Themen
Antworten
7K
Aufrufe
539K
