[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gabs nicht vor so 250 Seiten schon bei der ersten Charge Probleme mit dem BQ Kabel? Auf jeden Fall enttäuschend.
Also der erste kam von Computeruniverse gestern an, ohne dem Hinweis Aufkleber. Kann mir aber nicht vorstellen dass es Kundenrückläufer ist.
Der heute aus dem be quiet shop, mit Hinweis Aufkleber sieht gar nicht so verkehrt aus.
Klar, der Grat an der Schnittfläche ist nicht schön aber geht halt nicht anders, dafür ist er halt einfach zu "micro".
Mein Corsair macht da einen sauberen Eindruck!
An die FE Besitzer: springen bei Euch auch manchmal die Lüfter an, obwohl alles auf idle ist und die Temps bei unter 40° liegen (Hot Spot 45°, MEM 38°)?
Ya. Schalten sich up bei ca 34°C. Karte wird idle langsam wärmer, Lüfter starten dann bei ca 54°C, Temp dropt dann wieder auf 34°C, dann wieder Lüfter aus, usw...
abstrakte Kunst....
Ich werds trotzdem Samstag verbauen. Ich liebe die Gefahr
habe es ebenfalls verbaut, die Muffen sollten nicht reinrutschen beim Verbinden..., allgemein sollten die Kabel beidseitig gesichert werden mit den Klammern, alleine durch das Gewicht des Kabels biegt sich der Stecker leicht.
Hab hier auch zwei Corsair - die sehen für mich ganz gut & vertrauenerweckend aus.
Hab mal eine frage wurde vieleicht auch schonmal beantwortet
Die 4090 tuf mit nvidia 4x Adapter hat im ausgeschalteten Zustand eine rote LED geleuchtet nun habe ich die Direktverbindung mit dem seasonic Kabel mit dem 2x PCIe direkt am Netzteil und die LED leuchtet nicht mehr im ausgeschalteten Zustand
Bin auch mit dem Corsair zufrieden und man hört bisher auch garnichts schlechtes über deren native Kabel .
Ihr dürft euch von den teilweise leicht schrägen Crimpkontakten im Steckergehäuse nicht verwirren lassen. Das ist ganz normal und kein "Fehler", die teile zentrieren sich beim einstecken. Wir haben in der Firma auch eine Produktion die solche Kabelbäume produziert. Das bekommt man optisch selten super perfekt hin. Die haben ja generell Spielraum und bewegen sich. Denkt an die ollen Molex Stecker von früher..
Zuerst werden die Kontakte an einen Leiter gecrimpt, dabei bohrt sich der Kontakt ins Kabel. Danach wird das ins Gehäuse gesteckt und ist etwas lose drin.
Sowohl Corsair wie auch BeQuiet scheinen ja zumindest diese U-förmigen Buchsen zu benutzen. Bei manchen Adaptern waren es ja diese zweiteiligen. Funktioniert sicherlich, die U-förmigen machen aber den stabileren Eindruck.
Mein CableMod Kabel funktioniert bisher auch ohne Probleme. Sieht auch gut aus, nur leichte Franzen am Gehäuse der Steckverbinder:
Habt ihr eigentlich ein vernehmbares klicken eurer Stecker?
Hier ist der Be quiet Stecker an ner Gaming OC auch perfekt verarbeitet, wenn es absolut leise im Raum ist hörst Du ein ganz leises "Klack" beim einstecken. Da musst aber schon gute Ohren dafür haben 👂 👍
Also für den Umstand, dass BeQuiet bei den Steckeruntersuchungen von Igorslab dabei war und sicherlich auch die Kritik bezüglich der Verarbeitung mitbekommen hat finde ich das BeQuiet Kabel etwas unschön. Man erkennt Grate an den Kunststoff-Führungen und die etwas wobbeligen Kontakte... naja, vielleicht ist das nicht unbedingt ein Drama. Aber mein Asus bzw. Seasonic Kabel sieht da insgesamt besser aus.
Ich sage nicht dass das BeQuiet Kabel nix taugt. Es überrascht mich nur etwas - ich hätte mir da mehr erwartet.
Ich hatte jetzt bewusst den Preis weggelassen. Aber ja, das macht es im Endeffekt noch schlimmer. Schade eigentlich. Aber auch gut zu wissen - danke für die Fotos
+500 Euro zum Releasepreis im gleich Shop für die gaming trio ;) na cyberport möchte geld verdienen . Die Nachfrage erhöht den unfassbar teuren Preis noch mehr :)
Die Pins Anschluss (grafikkartenseitig) sind nicht nur schief, sondern auch stellenweise unterschiedlich hoch und tief. Werde ich so auf keinen Fall verwenden.
Hast du den Support von BQ dazu mal angeschrieben?
Mein BQ Kabel war einwandfrei dagegen.
ich habe noch 2228,-€ für die Amp Extreme bei MM bezahlt, und durch die Finanzierung 0% gejagt, hat funktioniert:fresse2:
@slind kannst du mal ein Foto posten?
Ich hab letzte Woche 2189 € für die Amp Extreme Airo bei MM gezahlt ... die spielen schon wieder alle Preis-Pingpong :motz:
Na schöner Mist, ich wurde von einem Nvidia Entwickler (Level 3?) mit Rückfragen angeschrieben…
Wenn in den nächsten Tagen ein neuer Treiber erscheint, wird der BlackScreen Issue nach dem Energiesparmodus des Monitors wohl nicht behoben sein :(
Sonst würden die mich wohl nicht weiter ausfragen.
Ich setze mich aber morgen dran - jetzt hab ich auch keine Lust mehr und will langsam :sleep:
Ich bin noch dabei den Shice zu testen.
Zusammgefasst: Mit 522.25 keine Probleme. Mit 526.61 Probleme. Mit 526.98 Probleme.
Nun in Testphase: 526.98, 2ter Monitor abgesteckt bevor der Monitor-Energiesparmodus akti4t wird.
hat zufällig jemand das Fractal Design Torrent Gehäuse und eine 4090 (KFA) verbaut? ich bekomme den Ständer nicht ausgerichtet, weil ja unten die Gehäuselüfter im Boden sind
Ähnliche Themen
Antworten
7K
Aufrufe
541K
