[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe jetzt mal einen Noise Canceler für die brummende FE gebastelt.
Ich vermute, dass es doch eine leichte Unwucht des Lüfters und nicht der Windzug durch die Finnen ist.
Mehr im Video:
Ich nicht :-) Bei 4k 120FPS habe ich kein fiepen vernommen. und ich bin sehr akustiksensibel. Wie man ja an meinen FE Video sieht.
DIY
Mein noise Mod für die Suprim und deren Lüfter Geräusch an den Lamellen..
Sensor im Rechner reicht.
Schade dass Du Deine beiden Grakas abgegeben hast.
DAS wäre doch genau Dein Benchmark gewesen^^
Gegen Frühjahr gibt es wieder ne 4090, oder ne 4090ti? Dann lass ich den mal laufen.
Beste Grüße
Der Alphacool wirkt da deutlich edler .
Aber zu klein :cry:
Ich hoffe, dass das nicht bei allen Karten so ist
Der erste AC-Block, der mir gefällt (ohne Trillionen O-Ringe)
Das war eher darauf bezogen, dass das einer der Benches ist, der AFR unterstützt^^
@kmwteam
Oder was das ein anderer User, der zwei 4090 im Rechner hatte?
Ich hab noch keine 4090 Strix bzw wie im Video zu sehen war FE ... das war alles Material aus dem von mir in dem Post verlinkten Youtube Video.
Aber der Typ aus dem Video hat die normale Version ohne Aktive Backplate ... ne Aktive wird hier auch nich mehr viel bringen da die neuen Karten ja
hinten kein VRAM mehr haben der gekühlt werden muss so wie es ja noch bei der 3090 der Fall damals war
Achso okay, habe ich wohl überrissen, sry :fresse:
Ich denke auch nicht, dass die Aktive Backplate all zu viel macht, aber einen direkten Vergleich fände ich doch mal ganz nett. Durch das PCB geht ja doch auch einiges an Wärme weg.
Nee, das war ich nicht. Wäre aber mal nen Test wert. Ich warte jetzt wieder auf ne Palit zu OVP, die war gut.
Beste Grüße
gestern Nacht aus Shanghai losgeflogen
Dann kann es das cabelmod ja nicht sein :) die kommen mit brieftaube das dauert
Habe gestern mal ne Mail an die geschrieben wozu man bei cabelmod EU bestellt wenn eh alles von da kommt und weiter wo die Kabel bleiben wenn ein Set am 7. Und eines am 18. An den versanddienstleister übergeben oder nur Label erstellt.... Beide bewegen sich nicht
Antwort von cabelmod
We do apologize for the delay. Your order is currently in transit, once it arrives in the EU your DHL tracking will update. This usually takes around 10-14 days. Since you're at the 10-14 days it should be updating soon.
Dann kann das was am 18ten raus ging ja noch dauern.... Saftladen, seasonic hat keine 4 tage gebraucht
Was anderes gibt es eine Alternative rgb Software die ich bei der Asus tuf nutzen kann?, will nur rgb fest oder ausstellen...
Beste Grüße
Habe auch Berichte gelesen, dass die Lüfter sehr laut seien. Hast du wohl eher nicht gemacht die Erfahrung oder?
Aber zu klein :cry:
Wie meinst du zu klein ?
Wird es ja führ mehrere Karten geben wie es scheint !
Die PCBs sind halt so kurz !
Jetzt ist die TUF auch weg, ne Stunde oder mehr hat sie aber fast gehalten, btw ist die Strix OC exakt 7€ günstiger geworden :sneaky:
(habe noch 2290,70€ bezahlt)
Meine Strix non-OC hat noch 2340€ gekostet :heul:
Beste Grüße
4090 Ti im Frühjahr wäre aber irgendwie schon ein Dickmove von Nvidia :d Die Enthusiasten, die in dieser Preisregion eine Karte kaufen haben doch mittlerweile alle eine 4090 und fühlen sich verarscht von einer so frühen Ti. Und der Otto-Normal Gamer, der auf eine 4070 oder 4060 (Ti) wartet fühlt sich noch mehr verarscht. Ich denke es wäre vom Produktmanagement sehr unklug eine 4090 Ti zu bringen bevor man das 40er Lineup nach unten hin komplett hat und wirklich brauchen tut man sie eigentlich auch nicht, da AMD dieses Mal ganz oben nach eigener Aussage nicht konkurrieren wird. Rechne frühestens Q3 2023 mit einer 4090 Ti. Aber naja, es ist immer noch Nvidia :ROFLMAO:
Das Referenz PCB ist etwas kürzer als das PNY im Video. Darum steht dies halt hinten einen Zentimeter über. Ansonsten finde ich den Kühler auch sehr ansprechend.
Heute kam die Info uns Sendungsnummer von Alphacool das meine ASUS TUF auf dem Rückweg zu mir ist. Vielleicht gibt es dann zu Weihnachten den passenden Strix/TUF Block. Zudem bin ich mal gespannt welche Paste bzw. Pads die da in Braunschweig meine meine TUF gebaut haben. Werde ich auf jeden Fall mit den ASUS Werten vergleichen.
Auch ein ziemlicher Hardwarefreak
Vielleicht für die Wassermänner unter euch interessant
Bei ASUS haben sie die Preise für die Strixen auch "ein klein wenig" nach oben hin angepasst...
Wir waren doch schon mal beispielsweise bei der OC bei 2.260 bis 2.290 Euro (je nach Tageskurs EUR/USD).
@HisN wie waren deine AB Einstellungen genau?
Ich hab ein ganz miserablen Chip.
3Ghz Core und +1500 RAM.
Aber ich glaube es ist normal, das man nur einmal Senden drücken kann. Dann ist "Quit" oben rechts angesagt und nochmal neu.
Allerdings ist die Einstellung für den "Haupt-Screen" auch völlig CPU-Limitiert. Ich bekomme da die Graka zu keiner Zeit auf 100% Last, was mit 2 Mio Objekten kein Problem ist. Nicht dass daher meine paar Pünktchen mehr kommen.
Die kommt nicht so schnell. Die 4090 ist schon konkurenzlos. Aber du hast recht. Bei dollar jensen weiß man nie.
Jemand auf der Suche nach einer PNY? Gab es eben beim großen A für 2.095 Euro.
Konnte eine bestellen und würde meine Bestellung wieder stornieren, sodass vielleicht die Chance auf diese Karte besteht, wenn man schnell genug ist.
EDIT: Werde um Punkt 18.15 Uhr stornieren, falls jemand interessiert ist.
EDIT [18.15 Uhr]: Storniert. Viel Erfolg!
Gab es heute nen Strix Drop?
Nö. Nur die 4090 TUF OC gab es über eine halbe Stunde lang.
Warum bestellt Du sie Dir wenn Du sie nichtmals einmal haben möchtest?
Aus Nächstenliebe für die Enthusiasten hier im Forum oder solche, die auf der Suche nach genau dieser Karte sind 😇
Früher wurden hier ab und an Warenkorb-Cookies getauscht. Das geht ja bei Amazon eher schlecht.
Ich werde meine 4080 FE nichtmal zum UVP los :ROFLMAO:
Gegenfrage: Wieso hast du die denn bestellt, wenn du sie wieder loswerden möchtest?
Ähnliche Themen
Antworten
7K
Aufrufe
541K
